Old 03-03-2021, 11:43 AM #16
Jemplyr77's Avatar
Jemplyr77 Jemplyr77 is offline
Jemplyr77 will become famous soon enough Jemplyr77 will become famous soon enough
Jemplyr77's Avatar
I’m really leaning to this having something to do with the prop shaft harmonics or similar.
Jemplyr77 is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 09:24 AM #17
raab02 raab02 is offline
raab02 is on a distinguished road
This thread and the TSB are why I finally committed to sound-deadening the back half of my truck.
My '18 with 55k had a little whine even after a fluid change and prop-shaft greasing. But mine happens when I let off the throttle and is fairly noticeable.
I'll get around to posting pictures if folks want but I ended up using butyl rubber and closed-cell foam over a lot of the rear floor and wheel wells. Very happy with the results. I no longer hear the whine and tire noise is significantly reduced. A Saturday well spent.
raab02 is offline   Reply With QuoteReply With Quote
Old 03-04-2021, 11:23 AM #18
T4RT's Avatar
T4RT T4RT is offline
T4RT is on a distinguished road
T4RT's Avatar
I have a low audible whine which I just started noticing at higher speeds on slip stream paved sections of interstate at constant high speed. I hope it is just the fact my tires are warn and need to be replaced. After I went though a drive shaft failure shortly after purchasing my 4runner used (TSB Saved the day on the replacement) I have been very attentive to greasing the drive shaft with each oil change. Diff oil levels are correct as I did the change myself 20K ago. Maybe what I am hearing is what you guys are talking about. Guess I need to change these tires and see if things quiet down.
2012 Toyota 4Runner SR5 - Blizzard Pearl-Black Leather-Navigation
T4RT is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 09:47 AM #19
SurferUK's Avatar
SurferUK SurferUK is online now
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
I noticed this on mine the other day, cruising on a very light throttle at about 60mph. It's not overly loud, I think anyone who is not interested in vehicles/mechanics wouldn't even notice it.
Seems like it's nothing to worry about if the TSB fix is sound deadening. I will turn the radio up.
Cheers everyone who posted on this thread.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is online now   Reply With QuoteReply With Quote
Old 01-09-2022, 10:55 AM #20
BlakeA BlakeA is offline
BlakeA will become famous soon enough
I posted earlier about the dealer replacing the differential and it making absolutely no difference in the whine. I have since put on a Gobi rack which makes enough noise to partially mask the differential whine. LOL
BlakeA is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 12:08 PM #21
SurferUK's Avatar
SurferUK's Avatar
That's pretty conclusive proof it's no big deal!
Old 01-09-2022, 12:33 PM #22
Spec-7 Spec-7 is offline
Spec-7 is on a distinguished road
I just got accustomed to the whine and forgot about it.
I recall reading somewhere that the whine was related to the cut of the differential gears and nothing to be concerned with.
2018 T4R Silver SR5 4x4
Spec-7 is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 12:35 PM #23
SurferUK's Avatar
SurferUK's Avatar
That's interesting thanks! I don't mind it at all, as it is a truck driveline basically, just with a lovely smooth V6 engine up front. I was just worried for a second it meant something was wrong.
accelerating , end , experiences , noise , threads
Rear differential whine? Kmvreter Problems & Warranty Issues 23 03-31-2022 11:31 AM
Rear DIFF WHINE!!! Need Help toyota1979 4th Gen T4Rs 9 06-29-2012 09:33 AM
Rear whine/noise mjtien 4th Gen T4Rs 6 06-14-2012 09:39 PM
Rear end whine? Panhead Jim Classic T4Rs 2 10-22-2008 04:34 PM
Rear axle whine 4Rman 4th Gen T4Rs 9 09-28-2007 10:19 AM
