02-02-2024, 03:19 AM
Trying To Decide Between Michelins Or Continental
I want to replace the OEM Dunlops on my new to me (bought in November) 2022 SR5 Premium 4WD.
I'm trying to decide between the Michelin ATX A/T2 in SL (Standard Load) rating, or the Continental Terrain Contact A/T in the SL (Standard Load) rating.
I'm sticking with the stock size: 265/70 R17.
I won't be going on rough off-roading. Mainly expressway / highway driving, city, country roads, and some gravel roads occasionally. I'm thinking I don't need the heavier "E" rated for my expected type of driving.
I'd like to hear from anyone who's running either one of these two brands of A/T tires, as to how you like them, or anything bad to say about either brand.
A couple of my big concerns would be- handling in the rain / wet roads, and the propensity of either one of these tires to retain small stones, pebbles, or gravel in their treads after driving an unpaved dirt / gravel road.
Whichever brand I ultimately decide to go with, they will be purchased from my local Discount Tire dealer.
Thanks for reading.
02-02-2024, 08:19 AM
Michelin sweats the details like no other. Michelin all the way! All tire companies have duds, but your chances are better w/ Michelin, from my experience.
02-02-2024, 10:15 AM
michelin defender LTX M+S is a better overall daily driver than the ATX
I've offroaded with my defenders and even my XICE winter tires which are michelin as well. they both handle mud, snow and rain just fine with the winters being much better in extreme cold
for your use case the defenders will be a better tire
02-02-2024, 01:09 PM
I have BFG KO2 tires, but they are probably overkill for your type of driving. BFG are made by Michelin, so they generally have the same quality. There are other BFG tires that are not as an aggressive as the KO2 tread that may also work well.
02-02-2024, 01:38 PM
Yes, Michelin bought BFG and Uniroyal many years ago to round out its portfolio. And there has been technology sharing across the 3, mostly downhill from Michelin to the other 2. Some BFG models at least were designed at MARC (Greenville, SC). About 25 years ago there were big deltas between the 3 makes in terms of overall performance, but how narrow the gap is now I don't know. It is amazing how many things are considered in tire design, and Michelin usually reserves its top technology for itself, until it becomes counterproductive to continue doing so. The C3M process is an example of a technology originating w/ Michelin, and maybe eventually filtering down to the other 2. They may have even licensed this technology to Pirelli I think, but don't quote me lol.
02-02-2024, 02:18 PM
Out of those 2 options I would lean toward Continental for a better all around tire for the 4R. Not that Michelin is bad (had them on my Expedition), just that they make better car tires and the side walls tend to be thin.
I personally wouldn't buy Michelin except for there super sports for a car.
02-02-2024, 03:12 PM
Real Name: Dave
Real Name: Dave
Another vote for the Michelin LTX M+S
On my 2nd set of the Michelin LTX M+S on my 2012 TE 4R.
I like the ride, & no problems in snow, & they last a long time.
My $.02.
02-02-2024, 04:37 PM
I had Michelin LTX A/T2 tires, stock size, installed on my 4Runner as soon as I bought it. No idea of the difference between Michelin ATX and LTX tires...but my LTX Michelins have been excellent. They DO pick up gravel/pebbles; I can hear them coming off the front tires and pinging off the running boards. Which is one of the main reasons I have running boards - to protect the rocker panels.
02-02-2024, 07:44 PM
I have been running Michelin LTX A/T2 tires, SL in stock size for over 80,000 miles with still plenty of tread left. They do pick up small pebbles when off-road but they fling off once you hit the pavement at speed. They work well on wet or dry pavement, balance well, get good traction aired down in deep sand and moderate rocks. Pretty quiet on pavement. I have no real complaints. I have been researching other tire brands for my next set this year but the reviews and test results point out all the flaws in them. Like noisy on pavement, hard to balance, bad traction when wet, tread wears out too fast, etc.
So I’ll probably get another set of Michelin LTX A/T2 tires.
02-02-2024, 07:52 PM
Continental has beefier side walls than Michelin. it may be same thickness, but Michelin more flexible. That's what I feel compare used tires at local tire shop.
02-02-2024, 08:33 PM
For that kind of driving, go for the LTX M/2 (or the new M/S3). It’s a better all around tire.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
02-03-2024, 01:08 AM
They are both pretty close on paper. The Continentals are rated for better wear, and come in a lot cheaper, at least on tirerack. I have Continentals on three of my vehicles (not the ones you are asking about though) and have nothing but good things to say about the brand. I doubt you'd notice much difference.
02-05-2024, 09:03 AM
Alrighty. I appreciate everyone’s time and input. Thank you!
02-05-2024, 10:03 AM
You will not go wrong either way. Have had Continentals and Michelins on many cars and they are both very solid. Personally, it is probably more important that you get a tire suited to your local climate and where you drive than focus too much on the brand in this instance, given again how good they both are.
I might also add Bridgestone into the comparison as well and just see what is the better deal or on special.
02-05-2024, 11:50 AM
I won't be going on rough off-roading. Mainly expressway / highway driving, city, country roads, and some gravel roads occasionally. I'm thinking I don't need the heavier "E" rated for my expected type of driving. Most of my driving is city and highway- the Continentals have been exceptional for me.
Thanks for reading.
I have the Continental A/T All Terrain Contacts on my 2015 TRD Pro , and so far have 45K miles on them with 5/32 tread depth remaining. No way I will get more than 50K miles from the Continentals, with wear being very even across all four tires.
I live in Houston, so not much ice or snow LOL. But lots of rain . For me, the number one criteria for a tire is wet road performance.
The tires are outstanding comfort wise, and hold the road very well in rain.
I am pleased with the tires, and the fact they are A/T tires can go off road. I don't do rock climbing, so the Continentals are fine for all my use.
I will be replacing my tires soon, and most likely will replace with the exact same Continental tires.
