Old 02-22-2021, 10:47 PM #1
umidkusername umidkusername is offline
umidkusername will become famous soon enough
Plastic oil filter cap change/mod
Has anyone replaced their plastic oil filter cap with an aluminum or metal one? You can use a scion one and mod the inner support tube (switch it out with the tube from the plastic one).
I’m more so talking about the Toyota filter (scion) and not an aftermarket one like Dorman. There are so many mixed reviews on those, I would never use those.
I’ve had 3 oil changes so far at the dealership and no issues with the plastic filter cap reported. I know some people say they eventually will crack though and some even crack when doing the recommended torque.
Also, if you do switch to the aluminum one does the torque specs change? What I have so far for the plastic stuff:
Filter cap - 18 ft/lbs
Filter drain - 9 ft/lbs
Bonus: Oil drain plug - 30 ft/lbs
umidkusername is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 11:33 PM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
this is an extremely common mod. I just hand tighten my "metal" toyota one and snug tight the filter drain.
Old 02-22-2021, 11:49 PM #3
4Reak Show's Avatar
4Reak Show's Avatar
My 2011 corolla has the similar cartridge filter and at 130,000 miles I’ve changed its oil religiously at 5,000 miles. So that’s 26 times it’s been on and off without incident, as an example of the design’s durability. I think if you’re easy on it, use the right tool (I own the actual Toyota brand tool and it fits both our 2016 4Runner and the 2011 Corolla) and lubricate the o-ring when you install it should last just fine. I go til it stops spinning without force and then do just a touch tighter and that’s it. Never have I ever pulled out a torque wrench for an oil change and I’ve literally done thousands in my life.
But as far as the plastic vs metal goes, if you’re doing the oil changes yourself, I would leave it OEM. If you’re having a shop do it and they’re incompetent, Metal might be a better bet.
Old 02-23-2021, 12:13 AM #4
Saker's Avatar
Saker Saker is offline
Saker's Avatar
As stated, this is a common mod.
All it takes is to drop the plastic one and it land just right, not notice the hairline crack and ....
I did this mod on my 2014 and just did it Friday on my 2021.
Toyota Aluminum Oil Filter Cap Installed
Best Regards,
Saker
Old 02-23-2021, 11:30 AM #5
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
Well said
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 12:11 PM #6
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
I normally am not this guy, but have you searched? There's probably a dozen threads on this already with multiple pages of posts.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 12:17 PM #7
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
You don't have to use a scion cap, there are 4Runner direct replacements.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 12:42 PM #8
Whippersnapper02's Avatar
No issues with my OEM cap but changed it anyway to avoid future issues. I also don't let the dealer do maintenance on my truck because they are no better than Jiffy Lube.
Old 02-23-2021, 01:39 PM #9
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Just did this on my last oil change, there are a dozen or so threads about it
Old 02-23-2021, 02:55 PM #10
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
I like all them Holes
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 08:11 PM #11
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
For the plastic cap you tighten to those specs.
With the metal cap you just tighten until it stops turning. It reaches full closure and you can’t tighten it any more. It’s a strange feeling but it works.
For the filter drain plug 9ft-lbs is about right.
Consult other threads for more info like this mega thread;
Oil Change 5th Gen: How To- LOTS of PICS!
Old 12-27-2021, 11:18 PM #12
Johnnyg182 Johnnyg182 is offline
Johnnyg182 will become famous soon enough
Anyone have a Toyota part number for the filter housing DRAIN PLUG that goes on the 15620-31060 housing? Stripped my original one tonight when the o ring slid out of position. Gonna swap to a metal housing but also need to buy a new drain plug for it. Thanks for any help you can offer.
Johnnyg182 is offline   Reply With QuoteReply With Quote
Old 12-27-2021, 11:33 PM #13
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Go to Toyota Parts Factory - #1 Source for Genuine OEM Toyota Scion Parts & Accessories | Camelback Toyota Parts
Enter your oil filter housing part number 15620-31060
Scroll down to "Also Purchased" to find Filter Housing Plug 15643-31050
Click on the Plug, scroll down to "Also Purchased" to find the o-ring 96723-35028
DougR is offline   Reply With QuoteReply With Quote
Old 12-28-2021, 01:03 AM #14
Thanks! Gonna see if dealer has this all in stock tomorrow otherwise ordering online:
YOUR CART
2005-2018 Toyota Filter Cover
Product ID: 15620-31060 Remove
$27.55 × Quantity $27.55
2005-2020 Toyota Plug
Product ID: 15643-31050 Remove
$3.91 × Quantity $3.91
Old 12-28-2021, 12:51 PM #15
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Same deal with my previously owned '13 FJ Cruiser. Bought it new and did every oil change myself every 5k miles until I sold it with 140k miles. Never had any problems with the OEM plastic filter cap.
I've been doing all the oil changes (every 5k miles) on my current '19 T4R ORP and again, no problems with the OEM plastic filter cap.
I never used a torque wrench on them either. I just tighten it until the metal tab on it catches one last time before the filter cap bottoms out. Never had any leaks and never had it loosen on me.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
cap , filter , ft/lbs , oil , plastic
Plastic Oil Filter Assembly Parts #? linkfeeney 5th gen T4Rs 2 02-19-2021 12:39 PM
Stupid dealer, plastic oil filter assembly callihan_44 5th gen T4Rs 58 11-11-2019 03:06 AM
Plastic Oil filter housing replacement JLTD 5th gen T4Rs 25 10-18-2019 03:44 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
V6 oil change tip - plastic Coke bottle Gecko123 4th Gen T4Rs 33 01-17-2011 08:44 PM
