Old 02-23-2021, 05:35 PM #1
HeelsFan72 HeelsFan72 is offline
HeelsFan72 is on a distinguished road
Slow Idle/near stalling on startup
2018 SR5, ~41k miles.
Read a bunch of threads with similar but different issues- posting here in hopes of some help.
Recently I started noticing an issue when cranking up my 4R. On cold starts, it will crank strong, engine starts, then for a split second it kind of lugs down and the RPMs drop. Almost like it's going to stall, but doesn't actually get there. After that first initial drop, RPMs come back up and it idles fine. If I shut the 4R off immediately and crank again, there's no issue. Battery seems fine, and I feel like it's too new to have an alternator issue, plus if it were, it should happen every time I figure.
Does it regardless of fuel level (this morning was half a tank), but wondering if it could be something with fuel pressure on startup? Also wondering if it could be a MAF issue? Haven't noticed any issues while driving, throttle response seems normal, no idle issues when stopped at lights, etc. Just this weird startup issue. No lights on the dash.
Any help is greatly appreciated.
HeelsFan72 is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 05:48 PM #2
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Any modifications, such as an aftermarket air filter?
waypoint is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 07:13 PM #3
No aftermarket air filter, or any other performance mods that could affect throttle, airflow, fuel, etc.
Old 02-24-2021, 12:12 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Most likely the idle speed control motor in the throttle body.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 08:23 AM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Clean your throttle body and MAF first.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 10:22 AM #6
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
There isn't one.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 11:39 AM #7
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
Not sure if it’s common with this engine, but with a good throttle body cleaning or induction service sometimes an idle relearn is required, usually depends on how dirty it is prior to cleaning
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 02-24-2021, 11:48 AM #8
Originally Posted by 08TxRunner View Post
There isn't one.
There has to be a way to control the idle speed. According to the factory repair manual (TOYOTA 2016-2019 4Runner Repair Manual RM27F0U) the throttle body does have a "throttle actuator" motor in it for that purpose, whether you call it an idle speed control motor, or a throttle actuator motor, it doesn't make any difference.
The trouble shooting procedure for low or unstable idle speed is shown on page 3280 of the factory repair manual.
Procedures for cleaning the throttle body start on page 3786 of the factory repair manual.
Old 02-24-2021, 01:23 PM #9
spartacus's Avatar
spartacus's Avatar
The ac compressor cycling if the defrost is on or any aftermarket accessories amp draw at startup. If you are still under warranty you can have the dealer check it out.
Old 02-24-2021, 04:02 PM #10
08TxRunner's Avatar
08TxRunner's Avatar
It does make a difference because there is no IAC motor on the throttle body, which is what you told him to look at. Idle is controlled by the same motor that actuates the throttle blade.
Old 02-24-2021, 04:09 PM #11
waypoint's Avatar
waypoint's Avatar
There has to be a way to control the idle speed....the throttle body does have a "throttle actuator" motor in it for that purpose, whether you call it an idle speed control motor, or a throttle actuator motor, it doesn't make any difference.
I'd agree with you, but then we'd both be wrong. The throttle actuator motor's purpose is to...actuate the throttle blade in response to either accelerator pedal input (via the ECM) or ECM-controlled engine speed inputs. Much more than simple idle speed control as you proposed.
With that said, fully agreed on cleaning the throttle body (and MAF using specialized MAF cleaning spray) as next steps.
Old 02-24-2021, 04:39 PM #12
Jivewalker's Avatar
Jivewalker's Avatar
Here you go, I did it a couple months ago...
Throttle body / MAF sensor cleaning
I am fragile.
Not like a flower.
But like a bomb.
crank , drop , issue , rpms , startup
Bad Idle & Stalling gamefreakgc 3rd gen T4Rs 25 09-30-2020 10:21 PM
Stalling with high outdoor temps and slow speed shamrock94 3rd gen T4Rs 7 07-25-2018 02:53 PM
Nearly stalling out after startup [T4R 2001] mikeySA 3rd gen T4Rs 3 12-31-2017 10:42 AM
2000 3.4 weak or slow startup Y2K-4runner 3rd gen T4Rs 8 07-12-2013 01:04 AM
Stalling out, won't idle dkovac 3rd gen T4Rs 1 06-16-2009 08:47 AM
