02-24-2021, 06:22 PM
GPS Problem
I had the touchscreen replaced on my radio/navigation unit. After reinstalling the GPS showed my location several miles from my actual location. I recalibrated the unit so that the cursor (car icon) showed my actual location. I used my cell phone GPS (longitude and latitude) to be sure that both agreed. My problem is that it won't stay calibrated. I have to recalibrate every 2 or 3 days. Has anyone had this problem or know how to solve it?
02-25-2021, 12:27 AM
Real Name: Steve
Real Name: Steve
Mine has been doing this for over a year. Took it to the dealer and they said to update the map, which I did but that didn't do squat, as expected.
So, most of the time it thinks I'm cruising through a lake somewhere, but every once in a while I will look and its correct. But it doesn't last.
I just don't use it, but yeah it's annoying and I would also love to find a solution (other than replacing the unit).
_________________________________________
'14 Mag Gray 4Runner TEP
No More: '11 T4R SR5 - '98 Lexus GS400 - '98 T4R Limited - '87 T4R
02-25-2021, 03:45 AM
I don't use mine hahaha sorry I'm no help
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
02-25-2021, 10:17 AM
Real Name: Troy
Real Name: Troy
Your position is correct the map itself is off , probably the area you are in has not been updated
Troy
2016 limited midnight metallic black
68k | LED headlights/fogs | remote start | block heater | LED interior
New to me
02-25-2021, 12:06 PM
I tried to use the OEM nav for the first two years of ownership. I did get a new map card. The OEM navigation is just really bad. I stopped using it and my life has much less frustration in it since I made that choice. I use a Garmin suction-cupped to he windshield. Sure, we paid for navigation and it should work. But it doesn't, OEM navigation is so bad its dangerous. For safety's sake, stop using it.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
02-25-2021, 04:40 PM
Real Name: Buck
Real Name: Buck
I quit using mine because it somehow got the Poll's mixed up; North is South and South is North. Very frustrating if traveling cross country.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
02-25-2021, 06:02 PM
That's what calibration does. I moved the map to my position. I have a 2010 model and it has been great for the last 10 years, until I had the digitizer screen changed.
02-25-2021, 09:34 PM
Check your time and date to make sure it’s correct. I don’t recall if that can be set in the software or not. If it’s not correct, it may cause issues with calculating your position.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
02-26-2021, 12:26 PM
Hit the "setup" button, go to "Navi", then "Advanced settings". Then use the "tire change direction" arrows to change the way your vehicle is facing.
