Originally Posted by tls3601
Thanks for this. Going to order this setup here pretty soon. I have an Alu Cab RTT, 270 awning and roof tray up there. In cargo area I have a fridge as well and of course loadout gear. I am planning on going with the +400 lbs load leveling rear spring as RTT is up there all the time. What do you think, guy at Eibach thinks the +250 might be a little light when fully loaded up? Thanks for your response. Tom
It’s tough to say without calculating the actual weight added above stock. I’ve got goose gear drawers, tools, Gobi rack, and recovery gear that adds ~240 lbs. So I went with the 250 lbs/inch (middle of the road) spring. That’s just one data point, but you obviously have a lot more weight than that so I would guess that the heaviest rate spring would probably work fine. The nice thing is, it doesn’t have to be a perfect match, because you’ll have 1.5” of adjustment from the threaded perch. And if you put a few thousand miles on it and decide you want a softer ride, the springs are cheap and easy to swap out.
