02-27-2021, 06:22 AM
#16
Real Name: Chris
Real Name: Chris
Originally Posted by Kamalani Mahie
Do you turn your wheels at all or just drive straight
Street driving only obviously but yeah no issues. People fail to realize rubbing issues are self inflicted. People want wide wheels with aggressive offset and I get it but that’s the problem. Running the correct wheel is key to not rubbing. 1.5” front 1.5” rear 295/70/17 on FX Pro wheels. No BMC, just a fender liner mod, no rubbing.
02-27-2021, 07:08 AM
#17
3M grip tape from Lowe’s will nicely hide those Tyger logos.
02-27-2021, 10:57 AM
#18
Pic attached hopefully
02-27-2021, 12:20 PM
#19
I’m running 285 KO2s on the stock rims on my 19Pro. Zero rub and mudflaps are still on and no BMC. Have 2” lift and SPC arms.
02-28-2021, 09:53 AM
#20
285s (Pirelli Scorpion AT+) on PRO wheels. No lift (backordered) no spacers. no uca. No bmc. Totally stock truck. Pushed the liner and trimmed the corners off the front bumper before install (maybe an inch of plastic tops) you would never know it isn't factory. Removed front flaps. Zero rub on the street. Put the flaps back on to minimize rash on the rockers. Minor rub on the flaps when turning in reverse or over bumps. Truck is dd. Been avoiding hard wheeling until suspension shows up but I do mash up and down local dirt roads and hit some bumpy rocky spots. Zero rub unless I'm turning over a bump where it will graze the flaps.
If you're gonna scream, scream with me. Moments like this never last.
Raptor lights. eBay PRO grill. Pedal Commander. Plasti dip valence. Very limited edition overlanding stickers and headliner patches.
02-28-2021, 12:14 PM
#21
I'm thinking current trim determines some things and that's why people give different answers; Assuming all 5Gen's should be the same. I have a Pro so I think I have a little more clearance than say a Limited.
02-28-2021, 12:33 PM
#22
So what your saying is the clearance is limited on the Limited.
02-28-2021, 09:27 PM
#23
thx repped
i guess i gotta find someone with a venture who put 285s to see if its like your experience which is very good btw lol
03-01-2021, 01:55 PM
#24
Or that the clearance is unclear?
03-01-2021, 03:46 PM
#25
Originally Posted by Gouranga
thx repped
There is no way to know for sure whether it will rub or not. Every truck is different.
I’m running 285s on pro wheels with a 2.5” lift. Leaving front flaps in was not an option - immediate rub. I also had to do a BMC (no rub on street but would rub stuffed). By the way, this is with Icon UCAs and just shy of 4 degrees positive caster.
03-01-2021, 05:59 PM
#26
Hehe.. I gave up. Some ppl hear only things they want to hear...
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
03-01-2021, 09:06 PM
#27
Same here except with SPC UCA and spidertrax spacers. The spacers probably don't help me haha but that stance.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
03-01-2021, 11:48 PM
#28
Yeah. It definitely made rubbing slightly worse after I added spacers. But that happened after I trimmed all the plastic and BMC. At this point I just stopped caring
PS: Hopefully it will go back to normal after I relocate the King' expansion tanks and get rid of the spacers. But that's fine too if not
03-02-2021, 08:14 PM
#29
Ya good luck! It really depends on suspension geometry and backspacing and offset and every vehicle seems to be a bit different.
03-03-2021, 03:25 AM
#30
Real Name: Ryan
Real Name: Ryan
But did Clarence get the Clearance? Over?
2020 PRO
1987 SR5
1988 DLX long gone, but not forgotten
