02-26-2021, 08:35 PM
OEM Puddle Lights don't work
I noticed a thread on Puddle Lights upgrade and I'm like Hmmm, never noticed my mirror lights turning on. Just did a key fob test and mine don't shine.
Is this some kind of setting or do i have to deal with my Dealer?
I'm Jones'n to do something new/simple mod and this should be easy. Except I'm thinking there's no power getting to the OEM lamps.
That problem won't be easy to solve,for me.
I'm not expert with electricity. Torque questions?.... Bring em. Need photos.
02-26-2021, 09:06 PM
Banned
Real Name: Mark
Banned
Real Name: Mark
What year, and trim is your 4Runner?
Bought it used and never noticed them working?
Driver and passenger side?
Do your external mirrors look like this?
02-26-2021, 10:24 PM
Do they turn on when doors unlock ?
02-26-2021, 10:42 PM
They can be turned off, via a programmer. Carista can do it, so dealer can also.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
02-27-2021, 12:36 AM
Not all trims come with puddle lights.
02-27-2021, 07:49 AM
Its a 2021 Limited, so yes the mirrors look like ElecrtoBoy's image.
Neither lamp lights up on unlock.
02-27-2021, 08:25 AM
Sorry guys,
They're working.
Now I'm wondering why they're even there.
My test was from my house window.
The lights basically aren't bright enough to be seen except if you put your hand 3" away from the mirror.
02-27-2021, 09:58 AM
agree on the brightness.........I owned the 4runner since new (2014), and never noticed them until one night about a year ago - it happened to be locked in the garage.........which I never do, I had the fob in my pocket and was going to my other car and it was 100% dark in the garage, and leds in the bottom of the mirrors activated.. I was shocked..............blahahhah
02-27-2021, 10:10 AM
Sorry guys,
They're working.
They’re intended to illuminate the ground when it’s pitch black. Mine work well for that.
Any low light situation and they really aren’t necessary anyway.
JMO
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
02-27-2021, 12:46 PM
Just switched my 14's to 10-13 mirrors , larger surface ! Mine was a model with no puddles (Old Red to the rescue) & of course Lasfit bulbs really light it up better than oem bulbs !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
02-27-2021, 02:30 PM
There are LED upgrades for the puddle lights to make them brighter, but they are really difficult to install. There is a thread here on the 4Runner forum on how to do it.
02-27-2021, 02:52 PM
Banned
Real Name: Mark
Banned
Real Name: Mark
Not real difficult. But a little nerve-wracking the first time you take the front top trim cover off. Try that method versus the mirror pull-off method. And wait until the weather warms up or your truck is in a heated garage, so the plastic is more compliant.
Check out this thread:
https://www.toyota-4runner.org/3361074-post116.html
You can replace the dim incandescent bulb with a brighter LED, or get a MESO puddle light kit.
4 Runner Puddle pods
– MESO CUSTOMS LLC
If you’re talented you could cut a bigger hole and glue in the actual VLEDS diode array MESO supplies in his kit.
Puddle Lights - Shop Products
