Old 11-10-2019, 05:52 PM #1
moshie's Avatar
moshie moshie is offline
Real Name: Josh
moshie will become famous soon enough moshie will become famous soon enough
moshie's Avatar
Real Name: Josh
Snorkel or No Snorkel?
Help me decide. Should I put a snorkel on my 5th Gen or not? I don't do many water crossings, but I have heard that they do help with cleaner air (can anyone attest to this)? Give me some pros and cons.
I asked on another site, but they said to do it for #OverlandPoints. I don't want to add anything on for aesthetics. Thanks in advance.
moshie is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 06:24 PM #2
AINOMOATACO AINOMOATACO is offline
AINOMOATACO is on a distinguished road
You answered your own question 😂😂😂
AINOMOATACO is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 06:28 PM #3
moshie's Avatar
Real Name: Josh
moshie's Avatar
Real Name: Josh
Thanks, haha!
Old 11-10-2019, 07:14 PM #4
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Stock a 4Runner can run in water up to the top of the tires with minimal risk to ingesting water into the intake (pop your hood and the air filter box open and see where the intake draws air from the passenger side fender). When doing water crossings with a 4Runner, be sure to let your differentials/transmission/etc. cool by letting the vehicle idle a few minutes before entering the water. The water temperature can cause the oil/fluids of the systems to shrink due to thermal expansion/contraction (I was in the pool!), and there are one-way check valves that when submerged in water go closed. This can pull a slight vacuum on seals and can cause them to leak if there is too great of a deltaT.
Have you seen a dirt problem in your intake downstream of the air filter? If not, then you're good as is (hint, that's what air filters are for).
If you're doing water crossings 'hot' (desert sprints and then crashing into water crossings), then think about extending the 'one-way check valves' into high point 'breathers'.
If you're doing water crossings above the top of the tires, then think about a boat.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 07:26 PM #5
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
When is the last time you drove through water over your bumper, and would you consider driving through water that deep or deeper?
Deep
water crossings bring all kinds of problems other than sucking water in the engine air intake. Are you willing to deal with things like soaked interior carpet, water mixed with diff oil (if you don't have breather tube extensions, electrical system problems, etc. ?
Snorkel installation is permanent--unless you replace the fender, you will have an open 4-6 inch hole in your fender if you decide to remove the snorkel.
To me they look like black PVC drain pipes with an elbow fitting at the top.
All negatives,but I can not think of a really useful purpose for most drivers.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 07:39 PM #6
moshie's Avatar
Real Name: Josh
moshie's Avatar
Real Name: Josh
Deep
So I am not doing any major water crossings, but like I said I have heard that they do help with colder air and better air intake. Other than that reason, I truly have no reason to get one. They are like the same price as the cold air intake. Just trying to make my 4Runner the best I can.
Someone told me they get better gas mileage but I don't believe that one..
I agree that they aren't pleasing to the eye.
Old 11-10-2019, 08:09 PM #7
Off-choader's Avatar
Off-choader Off-choader is offline
Off-choader is on a distinguished road
stock is the way to go, provides plenty of clean air and costs nothing. There are no noticeable mpg or performance benefits to going with snorkel or cai unless your going hella deep in water.
Off-choader is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 08:25 PM #8
TOYO74's Avatar
TOYO74's Avatar
I really doubt that the air coming in through a snorkel is significantly cooler than through the stock air intake. I have read claims (vendors) but have never seen any data to show that.
Old 11-10-2019, 08:31 PM #9
phillyd2's Avatar
phillyd2 phillyd2 is offline
Real Name: Dave
phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough phillyd2 is a jewel in the rough
phillyd2's Avatar
Real Name: Dave
Your truck will always tell you exactly which mods it requires and it’s not at all shy about how bluntly it tells you. That the question was asked as it was means that your truck doesn’t need it.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
phillyd2 is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 08:44 PM #10
moshie's Avatar
Real Name: Josh
moshie's Avatar
Real Name: Josh
@phillyd2 @TOYO74 @Off-choader @mo_mo @AINOMOATACO
Thank you all for your help! Much appreciated
Old 11-10-2019, 10:26 PM #11
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I just ran mine through 37 inches of water. My starter has been acting up since. I wouldn't put a snorkel on personally. It will get you through deep enough water without it but you will want to avoid deep water as much as you can anyway. Not worth it.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 11-10-2019, 10:38 PM #12
bsa70 bsa70 is offline
bsa70 is on a distinguished road
I hate the looks of a snorkle but... sounds like you have a vaild reason to have one. If I were putting my baby through water and there was a slighest chance of sucking up water, I would have one.
bsa70 is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 10:43 PM #13
Whippersnapper02's Avatar
Do you want it: Get it
You don't want it: Don't get it.
Old 11-10-2019, 10:50 PM #14
moshie's Avatar
Real Name: Josh
moshie's Avatar
Real Name: Josh
Thanks! I'm definitely not going that deep into water. Hopefully
I'm hoping that the deepest I go is like up to the middle of my tire..already done that...
I don't want one, but if there were actual reasons to have one (other than water crossings). I would get one.
Old 11-11-2019, 01:57 AM #15
Originally intended to reduce dust inhalation by the engine. If your in an area that's very dusty then it will help because most dust stays fairly low to the ground. Even then most people do not run one and are just fine. I'd run one in our deserts though especially since I'm usually following someone faster.
The water capabilities were a secondary gain from adding a snorkel but the rest of the vehicle is not sealed so you can't go into submarine mode.
asked , cons , give , pros , snorkel
New cheap snorkel on the market: the eBay “ARB Safari” snorkel Atomic6 3rd gen T4Rs 108 08-19-2021 03:15 PM
Safari Snorkel confirms snorkel for 4th-gen coming 4WDToyotaOwnerMag 4th Gen T4Rs 488 11-01-2020 10:46 PM
Safari Snorkel releasing snorkel for 3rd-gen 4Runners 4WDToyotaOwnerMag 3rd gen T4Rs 127 03-28-2020 07:56 PM
To Snorkel or Not to Snorkel..? That is the question! Big Country VA 5th gen T4Rs 19 08-24-2018 09:45 PM
snorkel? rustbucket Classic T4Rs 35 09-30-2013 12:10 PM
