03-02-2021, 01:03 PM
2020+ Dash Cams
Hey everyone,
Just got my '21 TRD ORP. Just wondering what dash camera everyone is running on the newer years with the sensors behind the mirror? Also what everyone is doing for the rear cam?
Ive been eying one of the newer Black Vue cameras and the Viofo 4k Front and rear cam. Not a fan of the ones that hang down with a suction cup. I like the wedge style since theyre up and out of the way. Also where are people pulling power from on the new models? i know the older ones were getting power from the mirror.
03-02-2021, 01:13 PM
Blackvue with a Blendmount will pitch it to the left of everything.
03-02-2021, 09:12 PM
I run a Viofo A119V3 up front to the driver side behind the mirror. I did see on this forum someone was able to tap into the mirror power, but I personally just ran a power cable down along the windshield/headliner to the a-pillar and into the dash where I used an add-a-fuse to power it of an always on 12V (always on b/c I use parking mode with voltage cut off detection).
I was able to easily tuck the power wire into the headliner above the windshield, and then squeeze it into the the a-pillar as well. You can't see it at all.
03-03-2021, 12:53 AM
Did you get the hardwire kit that has a voltage level selector for the cut off? Was the recommended one I saw on the Viofo listing.
03-03-2021, 06:11 PM
Originally Posted by Cobratuner182
Hey everyone,
I’ve ran BlackVue for a while and really liked them as long as you never need customer service. I bought a Rexing and it’s mediocre. Having the hard wire option for both, I’d advise to do it and get the rear cam as it’ll record your truck while it’s parked. People are sketch about hit and runs
03-03-2021, 08:48 PM
Yep, got exactly that one. So far it hasn't left me with a dead battery yet!
03-04-2021, 03:15 AM
I recent installed a blackvue dr900s with the power magic pro hard wire kit. I like it so far. I wanted to mount it right behind the rear view mirror but there is a sensor right behind the left side. I ended up centering it right below the dot matrix. I havent installed the rear camera as I do not know where to mount it.
21' TRD ORP Nautical Blue Pearl | KDSS
XPEL PPF Full Front | XPEL Ceramic Tint | Weathertech Visors | Falken A/T Wild Peaks | NW2 Rocksliders | CROR Molle Panel | Full RCI Skids | Westcott Designs Rack | Roam Adventure Awning
03-04-2021, 10:55 AM
I run the same camera with the voltage sensing hardwire kit. Hasn’t left me stranded yet, and there have been one or two occasions when I know it’s turned the camera off so it appears to be working as designed.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
03-04-2021, 11:01 AM
Real Name: Jared
Real Name: Jared
I've been eyeballing these for a while now.
*'16 Trail - JBA UCAs, Toytec BL, Dobinsons FR, Radflo LT Rear, (~3.5F/4R total lift) 285/70 (/75s next), mix of HeftyFab/SSO steel goodies
03-04-2021, 12:33 PM
Any idea how long your parking mode will run before the voltage cut-off kicks in? I know this can also depend on weather, battery type/age, and other "always-on" accessories.
Basically, I'm trying to figure out if it is worth it to power 2-3 channels of dash cam (front,interior,rear) while parked. I don't park in a particularly high risk area, but the world is getting crazier. Just got some molle panels installed that I want to load up, not sure how much the dash cams would help me in the event of a break-in though.
2020 TRD Off Road Premium w/KDSS, Pro SEMA Wheels, Nitto Ridge Grapplers, Smoked LED Sequential Mirror Turn Signals, Suma Performance Mirrors with integrated LED Turns, GoRhino Tube Steps, Anytime BackUp/Front Camera, TRD Heritage Grill with amber marker lights, RAM Mount, Full interior/exterior LED swap, Accessorides Remote Start
03-04-2021, 01:56 PM
Pardon my ignorance but what sensors are these?
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
03-04-2021, 01:59 PM
Cruise control distance
For the rear ive seen several people make a small mount that goes in one of the holes for the clips holding the headliner up.
03-04-2021, 02:26 PM
I haven't measured it, but I know I can get 3-4 days no problem. A couple of weeks ago though I got into the truck and when I started it, the dash cam started up too so I'm guessing the low voltage cutoff kicked in. I have it set to 12v I believe, and it runs off my accessory fuse box with the rest of my aftermarket electrical.
As you noted, lots of different factors come into play in terms of determining the ultimate run time when in parking mode, including how often the camera detects motion and actually writes to the sd card, so it's pretty hard to give any sort of projected time.
