Originally Posted by DougR
I have the Lisle boot clamp pliers, and yet haven't had a need to use it on the 4Runner. If you can reach the clamp with the tool perpendicular to the boot clamp, then it would be fine to use. If the boot is not leaking, I would tighten the clamp a little bit more and check it once a month for 3 months.
It's leaking, but looks like because the strap is too loose, this axel is brand new, there are no tears.
I'll crimp it until it kinda ears out, same as pic. If it continues leaking I'll switch to warm drive clamps.
