Old 03-05-2021, 06:40 PM #31
TravelingTaco TravelingTaco is offline
TravelingTaco is on a distinguished road
Originally Posted by thennen View Post
Its seemingly a trend with Toyota design to have improper gearing from the factory.
Ever consider that Toyota (and others) has legal constraints related to corporate average fuel economy, driveability, etc., that might at least play a tiny part in their selections of gearing and other things? No automaker makes its vehicles simply to please the whims of its various owners. They have thousands of requirements for each and every vehicle. Sometimes they miss their target. Toyota is the best at hitting those targets, but they run the risk of irritating their most demanding buyers(us) when they do so.
If people place the same demands on all other manufacturers that they place on Toyotas, I think they will find that, overall, the others are worse. Excellent quality is expected from Toyota/Lexus. With many other manufacturers, it's an unexpected bonus.
Of course I've considered that. However, individuals who have regeared actually reported better gas mileage. From the factory the transmission almost never goes into 6th gear (on the tacoma). After regearing, it frequently uses 6th gear like its supposed (over drive gear) to and also shifts a lot less, keeping the rpms from skyrocketing. Either way, gear manufacturers are thankful Toyota geared the Tacoma's so improperly that they are making a killing. I have seen the owner of a gear company say, "Toyota really threw us a bone with this one."
TravelingTaco is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 06:46 PM #32
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I have a 2019 TRDOR 4Runner that averages 21MPG over 64k miles. Creeps up to 22 in the summer (winter gas vs summer? I don't know). So these guys who re-geared and reported better MPG, did they go past 22MPG on their 4Runner?
thennen is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 07:39 PM #33
Well I was referring to the Tacoma.
Old 03-05-2021, 09:05 PM #34
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
Regarding your suggestions to either get a pedal commander or regear is part of my issue with the 4runner. I don't want to have to buy a vehicle then immediately begin moding it for it to act properly. I would want to correct the nose dive (suspension), and I certainly don't want to regear a brand new vehicle and void my warranty. The tacoma has its fair share of issues too, and many regear that as well. Its seemingly a trend with Toyota design to have improper gearing from the factory.
No one needs a pedal commander. The 4R is not sluggish.
Put your foot into it and it will move with a purpose.
The throttle mapping is actually very precise, and allows you to apply precise increments of power to the wheels at low speeds, such as when crawling over rough terrain. This provides better traction off road and also on wet/icy conditions on pavement. Think of it as using an extra long breaker bar to bust free a seized bolt. It's much easier to apply the precise amount of torque necessary to turn the bolt with a long bar compared to using a short breaker bar that you practically have to jump on with your full weight to get the bolt to finally turn.
As far as needing a regear, it's totally unnecessary unless you plan to install huge tires after a lift. Stick with oem size or 33" tires, and you'll never need a regear.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 09:10 PM #35
4R4Pazzo 4R4Pazzo is offline
4R4Pazzo is on a distinguished road
Several mentioned the Bronco, but be prepared to wait and possibly pay a premium when they come, especially if you do not have a reservation/order in now. Looking at 2022, maybe late 2022.
For your intended use, the 4R would be perfect. And if you want to to any long highway trips, then the choice is clear = 4R
4R4Pazzo is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 09:53 PM #36
thennen's Avatar
thennen's Avatar
Ok, understood.
Old 03-06-2021, 12:45 AM #37
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I would disagree, it's a noticeable dead spot; the "precision" curve at the beginning of travel is unnecessary in my opinion. Having driven 4th gens with both engines and the 5th gen regularly, there's no need for that level of "precision" besides trying force drivers to either treat the pedal as an on/off switch from a stop light or drive the vehicle like a Prius. The 5th gen is slower off the line compared to a 4th gen V6, simply because of this built in "precision," despite the 5th gen having more oomph on tap technically. There's plenty of precision to control the throttle without artificially hampering the ECM logic to basically ignore the first 1/4~1/3 of pedal travel. The Tundra is a good example of this, it's a very sensitive pedal (we've had some older folks complain about it before), but it's not that hard to toe-in with it and get just the right amount of power you need.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 03:08 AM #38
Tuco S.'s Avatar
Tuco S.'s Avatar
The 4Runner throttle map sure makes it easy to drive up on Rhino ramps. If there was this "dead zone" as you describe it, it would be very tricky to do this.
I drove VW TDIs for years with manual transmissions. Those little 4 cylinder diesels had so much low end torque, even at idle without boost, that it was always tricky getting traction on slick roads from a stop. Even with brand new tires and traction control, it was tricky to avoid spinning the wheels on slick roads just by putting it in gear and releasing the clutch. I'll take the 4Runner throttle mapping over that any day. I actually like it.
The pedal commander and sprint booster seem to be pretty popular, no doubt, but I can think of a lot better ways to spend $300.
Old 03-06-2021, 03:44 AM #39
SilverTEP's Avatar
SilverTEP SilverTEP is offline
Real Name: Luke
SilverTEP will become famous soon enough SilverTEP will become famous soon enough
SilverTEP's Avatar
Real Name: Luke
Agreed, there is def a dead spot in acceleration / torque with the 4runner. I'm sure it's all made for MPGs.
I drove a early 2000s Pathfinder with 3.5 engine and that thing just pulled like crazy, just pressing the gas pedal your car would lurch forward, it felt great... but the difference was 9 mpg vs 4runner's 16 mpg city driving.
2018 TRD ORP w/ KDSS, Hefty Front Bumper, Ironman4x4 Pro Foam Cell, RSG Sliders, Nitto RGs 285/75/17 E, Victory 4x4 full steel armor, Diode Dynamics Fogs
SilverTEP is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 05:43 AM #40
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Originally Posted by Pedro367 View Post
I've owned both. A 2016 JKU and now my 2018 ORP. If you don't need the capability I'd stick with the 4Runner. It's a much more solid vehicle, more comfortable, more reliable (your experience is very uncommon), and has much more room inside. It also still has a great aftermarket.
But, if you are looking to try something new a JL Rubicon is an amazing vehicle and will get you anywhere you need to go right out of the box. There isn't a more fun driving experience than top/doors off and the community is pretty great too. FCA reliability is still questionable, but it's gotten much better in the last few years. Just don't get an angry grille please....
Yes please no angry grille.....
Based on the OP's description of his/her vehicle needs, I would say 4runner. It's going to be the more comfortable DD but still very capable offroad, and have more gear capacity. I don't think my lifted 5th gen 4runner on 33s and fully armored is sluggish. Definitely could use a bit more torque but even when I'm loaded and heavy there's still enough under the hood to keep me moving.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 06:00 AM #41
Thats funny, it seems that many owners disagree with this. I talked to a local guy last week who has 10k on his T4R, and he said he would not buy it again for precisely this reason. Loves everything else about it but its a "dog". His words.
I'm not expecting the 4Runner to be a race car but any means but compared to the wrangler (any of the 3 engines offered), it feels considerably more sluggish.
Old 03-06-2021, 11:42 AM #42
thennen's Avatar
thennen's Avatar
I'm with Tuco on this. Pedal electronics may help to make it feel different, but they don't make it faster. You can duplicate the maximum acceleration with your foot. As for acceleration, 0-60 in 7.5 seconds is plenty for a 4500-pound truck unless you want to race someone. If that's what you want to do, then I suggest selecting another vehicle.
Old 03-06-2021, 11:47 AM #43
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Hi 4Runner enthusiasts!
I purchased a new 2021 Toyota Tacoma TRD Pro in lunar rock last October. Turns out, its a lemon and Toyota is buying it back. Now I need to decide between a JL Wrangler Unlimited Rubicon and a 4Runner (ORP or TRDP).
Has anyone owned both/or came from the wrangler platform?
I'll be getting a hard top and installing some sound deadening in the event I go the wrangler route.
4Runner Pros: Larger storage space, sliding down rear window (for the dogs), readily available, great aftermarket, capable off road, best looking SUV of all time, and more plush for a DD.
4Runner Cons: Dated tech and sluggish compared to the Jeep. I can't believe it doesn't even have blindspot! I'm not a fan of the stock suspension and will change it.
Wrangler Pros: More off road capable. Top and doors off. Better tech/features. Larger aftermarket.
Wrangler Cons: Cost. Its louder on the highway. Potential reliability issues (but I can't say I'm thrilled with Toyota at the moment).
Background info: Will be used as a DD on a 9 mile each way commute. Also used on the weekends for overlanding/camping. Not serious wheeling. Plan to do some minor mods like rock sliders, lights, bumper/winch, full spare, and possibly suspension on the T4R.
I'm actually a Jeep guy and have had 5, but none of the JL's. I picked up a Pro after my last Rubicon had death wobble. Its easy for me now. One drives well and the other doesn't. So I will be sticking with the one I enjoy driving the most. I've recently had two friends say that I never complain about the 4R, but I used to always hate something about my Jeeps. I thought about it and its true. My biggest complaint of the 4R is the aftermarket support which is nothing like the Jeeps and the ease of changing bumpers or lights on a Jeep is way better and way cheaper. I don't want to waste the money modifying my vehicles as much anymore.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 02:38 PM #44
Tuco S.'s Avatar
Tuco S.'s Avatar
I guess some folks don't like having to depress the gas pedal an extra few mm's, I don't know. The pedal commander doesn't add any hp or torque, it just makes the pedal more sensitive.
Compared to my wife's Forester, which has full-time symmetrical awd, my 4R is considerably easier to get up on rhino ramps in rear wheel drive. If you're not super careful with the Subaru, using 1 foot on the brake pedal, 1 foot on the gas pedal, and a hand on the hand brake, those rhino ramps can easily become a launch pad (ask me how I know). I think it may be because her Forester has a cvt, which has a tiny "gear ratio" (equivalent) to help with low end power. All you have to do is barely touch that gas pedal and the car will lurch forward. I hate it.
Old 03-06-2021, 06:44 PM #45
My wife has a forester too, I love it. Great all around vehicle.
4runner , cons , top , toyota , wrangler
help me decide on a 4runner for cabo CaboTruck 3rd gen T4Rs 4 09-06-2013 08:18 PM
buying 4runner , help decide between nu24runner 4th Gen T4Rs 5 12-18-2011 12:08 PM
How Did You Decide to Buy a 4runner? lezavw90 5th gen T4Rs 75 12-15-2011 05:21 PM
Can't Decide: GY Wrangler SA vs General HTS tires malmgren Engines / Suspension / Wheels / Tires / Audio / Accessories 17 01-09-2011 09:09 AM
