03-04-2021, 11:20 PM
Magnets as mounts on frame
Has anyone ever used magnet(s) to mount something (e.g. rock lights) on their frame instead of drilling?
It seems like a good way to get a solid mount for a light in a way that's non-destructive. I'm just wondering if it is likely to lead to any premature rust or the like. I can't see how it would be a problem - the ones I've found are all powder coated - but figured it could not hurt to ask.
Reason: Mistake
03-04-2021, 11:24 PM
The magnet would weaken over time or a hard hit would jar it loose. Don't forget direct hits.
03-05-2021, 12:04 AM
I like the idea for temporarily mounting rock lights or something, that's a pretty cool idea. Pop them off when you're just daily driving, but when you go out throw them on.
If you are concerned about the strength of magnets, our frames have a lot of pre-threaded holes you could probably just run a single bolt in snug to hold lights on and then pop it out when you don't want them. BUndle up the wiring and disconnect from some sort of 12V quick disconnect like an Anderson Connector.
03-05-2021, 02:18 AM
Lux rock lights use magnets for mounting.
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
03-05-2021, 02:44 AM
The frame has a lot of pre-drilled/tapped holes that might not be used that you can utilize. I used some rivnuts and existing holes to mount my rock lights. No drilling needed.
2016 White TEP
03-05-2021, 09:50 AM
i've seen people use cheap magnet mount lights for rock lights and even ditch lights and they worked fine
03-05-2021, 10:44 AM
official vendor
official vendor
I've had a set of rock lights installed for close to 3 years on my 3rd Gen with nothing more than magnets. They've never fallen off or even had to be repositioned. If you go this route use some N52 Neodymium magnets that are magnetized through thickness.
Mike
03-05-2021, 11:41 AM
Mike
Thanks
@ MStudt
- appreciate the reply. I bought two of these to experiment with (largely because they came powder coated).
Amazon.com: Magnet Adapter Kit for ORACLE car LED Rock Lights – Automotive LED Rock Light Kit Adapter for Easy Installation (Single) - Part # 5848-504: Automotive
But I think I'm going to to ultimately use some I found online that have a rubber boot so that there's less chance of wearing through the frame paint over time.
Do you recall how much "pull force" your have? The brackets I have are aluminum and the lights don't weigh a lot so it seems 40-60 lbs should be plenty to keep things seated.
The places I am going to put them are above the suspension, so I'm not too worried about them getting directly hit unless something catastrophic happens, in which case the rock lights wont be my worry :-)
03-05-2021, 11:50 AM
official vendor
official vendor
Originally Posted by rageandlove
The ones I used have a pull force of 70lbs, and were about $4 each. Here's what I'm using.
Mike
03-05-2021, 12:08 PM
Thanks for the link. How did you attach the light (assuming you were using a bracket or something) to the magnet?
03-05-2021, 12:16 PM
official vendor
official vendor
I cut some metal base plates that I attached the lights to, and sandwiched the magnet between than and the frame.
Mike
03-05-2021, 01:20 PM
I use magnets to hold my license plate onto the front bumper. Has never budged unless I pull it off myself. Though I would remove it prior to running through a car wash.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
03-05-2021, 06:57 PM
That's slick
@ ryguytheman
. I like the screw mount and the magnets appear to be covered w something. Is that rubber? I see a few kinda like it on Amazon.
(The brackets I made are aluminum, so I need to tweak the solution that MStudt shared a bit.)
03-05-2021, 07:32 PM
That's slick
@ ryguytheman
Yeah, it's worked out great. They are coated in some sort of plastic. Not shown in my above pictures is the felt I glued to the back of the magnets to keep them from scraping the powdercoat. I got them from the below website.
Got the idea from a member on this forum, Friggin Idiot.
K&J Magnetics: RX436DCSPC-BLK
Build Thread
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
