Old 01-27-2023, 01:07 PM #1
PNW_Red4Runner PNW_Red4Runner is offline
PNW_Red4Runner is on a distinguished road
Anytime Backup Camera Wiring/Switch Panel Question
Hi All -
I have finally reached the point where I am running out of switch blanks and starting to look into switch panels/wiring options. I was wondering if you guys had thoughts on 2 things:
First - Has anyone wired their anytime camera setup to a switch panel? I've tried looking, but couldn't find anything, but I'm a bit of a noob when searching these forums.
Second - I see a lot of reviews/opinions on various switch panel, but haven't seen much around the switch panel options from Nilight/Rough Country, and wanted to see if anyone has thoughts/experiences to share.
Nilight: Amazon.com: Nilight 6 Gang Switch Panel Universal Circuit Control Relay System with Fuse Wiring Harness Automatic Dimmable ON-Off LED Switch Pod for Cars Trucks Boats ATV UTV SUV, 2 Years Warranty : Industrial & Scientific
Rough Country: Muliple Light Controller | 8 PANEL | Rough Country
Cooper Discover AT3 4S (265/70/17) on Matte Black TRD | Baja Designs S2 Pros (white & amber) | Baja Designs S2 Sports (amber) | Dobinson's IMS 2.5/1.5 w/ UCAs | DRT Hitch Skid | Apex Overland Recovery Points | Meso dual color Map/Dome LEDs | XD LED fog lights (amber) | RCI skids (engine, transmission, cat shield, filler) | BP Fabrication Pet Barrier | Sherpa Crestone
PNW_Red4Runner is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 02:48 PM #2
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
First.....I would not put the anytime camera on an auxiliary switch panel....the camera rocker switch is wired into the harness that is at the back of the head unit. You would have to run those wires to the engine bay (where an auxiliary switching resides) in order for it to have control. The part of the auxiliary switch that is in the interior is just a control interface that sends a signal to the unit under the hood. you also have to consider that the camera rocker switch is a 3 position switch that handles two circuits. If you were to use the auxillary panel, you would have to use two buttons to accomplish the same functions.
Second...dont know anything about those, but i have an 8 switch Auxbeam and its been great for the last two years.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 11:13 AM #3
Auntie Soshul's Avatar
Auntie Soshul Auntie Soshul is offline
Auntie Soshul is on a distinguished road
I installed an anytime backup camera switch using @Antman s how-to that’s contained in the stickies. I installed it in the overhead console, but I don’t see why it wouldn’t work just as easily in a switch panel. It would be a matter of running longer wires. One thing, though: the how-to may only apply to pre-2014 models with the camera display in the rear view mirror.
2013 SR5 Mag Gray, Pre-leveled, Non-nosedive edition
Plastic license plate frame
Auntie Soshul is offline   Reply With QuoteReply With Quote
Old 01-28-2023, 03:53 PM #4
Thanks! To be honest, I tend to heavily lean on trail4runner.com - and when they wired their ABC, it seemed suggestive that it was simple/possible.
Also, glad to hear that the Auxbeam is working out for you. Again, some of the comments I heard on their Auxbeam install scared me away, but maybe I should reconsider. For the most part, I really wish there as room for just one more switch (1 for amber, 1 for whites, 1 for chase, 1 for ABC), but with only 3 switch blanks, I'm not considering a switch panel.
I've been searching high/low for a switch that would fit in either 1) center console where seat heater blanks are, or 2) switch that would fit in right panel of the steering column. I've only seen USB outlets that would fit
Appreciate your input
Old 01-28-2023, 03:54 PM #5
Thanks for the lead - I'll check out his post, but based on the previous comment, seems like it may not be suitable. Will take a look thought - appreciate it!
Old 01-29-2023, 10:35 PM #6
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
As the anytime harness is behind the radio a convenient location for a switch is in the OEM single switch opening in the dash panel to the right of the steering column. Remove the blank and insert a switch. Good convenient location without taking up a spot in multi switch panel. This is where I mounted my switch.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
anytime , camera , options , panel , switch
Anytime Backup Camera/Front Camera Group Buy ***CLOSED*** bRYANT619 Group Buys 161 06-05-2021 07:36 PM
Anytime Backup Camera and Front Camera - February 2017 Group Buy bjohnston115 Group Buys 101 05-06-2020 11:39 AM
