Old 03-07-2021, 02:32 PM #1
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Need Advice - Transfer Case weeping? See Photo!
I have a 2019 with 32k miles; I was doing my Utah/Road trip maintenance and noticed were the driveshaft come out of the Transfer Case there is a little drop of oil. It’s not dripping on the ground but it’s there.
I’m leaving for the Grand Canyon/Utah on Tuesday and need some input on what this could be? I’m in the Florida/Georgia area so round trip is usually 5.5-6k miles. I’ll be off grid for about 25 days and don’t need to get stranded.
Any Help is greatly appreciated.
Need Advice - Transfer Case weeping? See Photo!-470acecc-08e3-4dbe-85c6-7af0695d80c0-jpg
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 03:25 PM #2
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
I would get it checked BEFORE your trip as it is under the 36k mile warranty. They can at least document it and get it covered, even if you wait to return. Its likely just a seal.
But don't wait till the warranty is up.
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 04:56 PM #3
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
1 drip could be anything; but agree with getting it documented. Assuming you won't get it fixed prior, I'd carry a quart of TC fluid just in case the leak gets worse.
Also - worst case, figure out which dealer you will take it to at each point in your trip.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 05:18 PM #4
Islabellefisher Islabellefisher is offline
Islabellefisher is on a distinguished road
I had the exact same thing happen on my 2018 at ~22k last summer. Looked identical to your picture. Toyota replaced the transfer case rear driveshaft seal (rear output seal) under warranty.
I believe there is another thread detailing this problem and fix. Best of luck!
Islabellefisher is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 05:26 PM #5
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
It looks like the rear output seal is leaking a bit. I'd call your local Toyota dealer tomorrow morning, and see if they can fix it immediately. It's not a hard job at all. It shouldn't take more than a half hour if the tech is competent.
It's not too likely to start losing lots of gear oil, But I'd want it fixed before a long road trip if it were me.
The VF2A T-case has been used by Toyota for decades. I had the same T-case in my '97 4Runner. You can use any 75w90, which the '97 was speced for.
Of course your '19 specs Toyota's special 75 gear oil for a fraction more MPG. But the components inside the T-case haven't changed.
02SE is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 07:02 PM #6
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
I think it should be covered under the 5yr/60k mile powertrain warranty, so it shouldn't be a super urgent thing to get documented I wouldn't think.
But I would at least pull the fill plug and make sure it's topped off before the trip.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 08:17 PM #7
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Solid advice, thanks you very much.
Old 03-07-2021, 08:32 PM #8
Jeremy556's Avatar
Jeremy556's Avatar
Wipe it off and see if it comes back.
Worst case it is the output seal, which even not under warranty is a $12 part and 15 minute install.
Old 03-08-2021, 04:49 PM #9
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Fixed under warranty first thing this morning; pulled in before 6am to get that first spot. Had the rig back by 9am. Thanks again for all the good advice.
Old 03-08-2021, 05:17 PM #10
Glad you got it fixed quickly. It likely wouldn't have started leaking profusely, but you never know. It's one last thing to worry about during what sounds to be a great trip.
I fixed quite a few of those rear output seals on VF1A and VF2A T-cases back in the day. No big deal, and it likely won't leak again.
Old 03-09-2021, 04:33 AM #11
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
It’s good that you got it done to your satisfaction. I was poking around the TIS repair manual online recently and it’s interesting what Toyota considers a failed seal. They show photos of what they consider normal and what is in need of repair. It’s normal to have some seepage that collects some dirt and dust. But if it’s a drip, like yours, that needs repair.
Old 03-10-2021, 02:04 AM #12
the_economist's Avatar
the_economist the_economist is offline
the_economist will become famous soon enough
Related thread here. This is a known 5th gen issue on some percentage of T cases: Transfer Case Leak
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
the_economist is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 01:50 PM #13
Glad it's fixed before your trip....now you can enjoy with no worries!
Between outfits.
Old 03-12-2021, 05:09 PM #14
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
Transmission fluid service notification at 34K miles?
Ok guys, i’m out west in Arizona and Utah hitting the trails and I got this service transmission fluid notification from the forerunner’s on board computer. This seems a little premature to me considering it has just over 34K miles. I’m not too hard on this thing but I’m not delicate on it either, i’m definitely not heavy on the pedal in my daily driving. Cruising down the highway I’m usually running 77, and this is only my second trip with it out west.
I usually do my transmission fluid changes at around 30-40K miles, so I was planning on doing this when I got back from vacation. So the question is, do you think The fluid can handle another 3K? Second question is has anyone seen a transmission fluid service notification at 34K miles?
Need Advice - Transfer Case weeping? See Photo!-3a36f85b-6a88-4b61-930f-503769b8c75b-jpeg
case , it’s , i’m , transfer , trip
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
FS 3rd Gen '01-'02 Transfer Case Actuator $50 + Transfer Part Out, Idaho Falls, ID BanditJunior For Sale: T4R Items 1 05-01-2019 01:57 PM
RCI Transfer Case Skid doesn't have Transfer Case Drain Hole boyfester RCI Metalworks 1 01-09-2018 08:35 PM
WTB: 4th gen V6 transfer case shift motor/transfer case drewskie88 Want to Buy/Trade 0 01-11-2016 12:41 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
