Old 03-08-2021, 06:05 PM #16
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Originally Posted by Adi4runner View Post
The Westcott setup retains the original geometry of the front suspension (but not the rear). You paid good money for those factory FOX, so the logic here is to keep that ride quality... at least in the front.
A spacer on top of the front spring retains the front suspension geometry too and allows same suspension travel as without, so I still don't see advantage of Westcott, more $$ and complex install seems to me.
Old 03-11-2021, 02:12 AM #17
V2009's Avatar
V2009 V2009 is offline
V2009 is on a distinguished road
V2009's Avatar
Originally Posted by LunarRock View Post
Here's my TRD Pro with a lift from Wescott Design on 285/70/17s. I have no clearance issues whatsoever.
Sent from my SM-G973U using Tapatalk
Hows the ride quality overall?
- 2018 4Runner TRD PRO
- 2017 Honda Accord - Sold
- 2012 Lexus ISF - Sold
V2009 is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 04:17 PM #18
smokeyfx4 smokeyfx4 is offline
smokeyfx4 is on a distinguished road
Westcott design is the way to go if you want to keep the factory fox system from the Pro. It will give you 2"+ in the front and about 1-1/4" in the back. They claim 1-1/2" to make sure that is what minimum it will lift. The Kit looks factory and solid. And install is not easiest but if you have the right equipment you can easily and safely do this in 5-6 Hr by yourself.
smokeyfx4 is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 05:49 PM #19
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Originally Posted by DallasTRDPro View Post
For comparison here is mine with Eibach springs which are way easier to install IMO and with 285's.
Before:
After:
Did you simply replace the OEM spring with a taller spring? If so, I'd argue that this is the proper way to get a suspension lift.
I did the same upgrade with my 2017 Pro - replaced the OEM spring with a taller spring (fronts).
perf0rmance is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 09:34 PM #20
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
Yes. The Eibach springs replace all four which I know the Wescott uses a spacer in the rear. I also think replacing coils would be the proper way.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 01:01 PM #21
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
As much as I would have preferred the Eibach front kit, I couldnt wait until September and ordered the front Westcott kit. I am definitely impressed with the initial quality of materials compared to the cornfed kit which I had and took off last year. (And swapped in the Icon 13" coils)
One question as it arrived yesterday. There are two bolts with lock washers and nuts in a seperate bag... what are they for?
Hoping to install it this weekend.. seems pretty straight forward in the video and have done other suspension swaps myself.
MGordo is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 01:51 PM #22
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
I was strongly considering the Wescott kit but was going to have them install. I don't off road and I am so back and forth about even touching my stock 2018 it's ridiculous. It's a lot of money, wheels/tires and lift, to look cool when I don't look cool outside the truck. But....I do like the ability to be able to go where I may need to.
I know yours will be great with the Wescott.
Swipter is offline   Reply With QuoteReply With Quote
Old 04-25-2021, 10:32 PM #23
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
How is the ride compared to stock?
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 04-28-2021, 01:53 PM #24
I honestly didnt notice a difference... Thats where the Eibach one and a slightly stiffer spring may be a better option.
Old 04-28-2021, 02:00 PM #25
matoolie's Avatar
matoolie's Avatar
Honestly I am really enjoying the stock ride compared to the Dobinson suspension on my ‘14. I would like a lift, but I do not want to stiffen up the ride. It appears the spring rate is higher with Eibach, but waiting on Eibach to confirm in the thread.
Michael
Old 04-28-2021, 02:52 PM #26
Its only slightly stiffer.
Old 04-29-2021, 09:37 PM #27
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
I was really set on the Eibach springs, but then I started reading about how superior the ride quality of Kings due to a lower spring rate. I also found an article on accutune off road about 4R and Tacoma spring rates and they also recommend lower, especially if you don’t have a bumper/winch up front. The accutune article seems to imply increasing preload would be preferred, as long as the shock/spring can support the new range of travel. This has me favoring the westcott kit a bit more because I am quite pleased with the ride on the ‘21 front coils, a little stiffer compared to my ‘19.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 03-22-2022, 08:57 PM #28
Magiriano Magiriano is offline
Magiriano is on a distinguished road
Did the front today, took about 2.5 hours. Was about to do the rear but used the wrong torque wrench.
750 lbs of torque turned out to be too much for my coil spring insulator, part# 4830235050
So now I'm driving with a nice Alabama squat. Took less than an hour to put the rear back together, so if I didn't screwed up I would've been done in about 4 hours total.
No idea how to upload pictures from my phone, I've tried .
Magiriano is offline   Reply With QuoteReply With Quote
Old 03-25-2022, 11:43 PM #29
awocsb awocsb is offline
awocsb is on a distinguished road
The Wescotts with 285/70R17 BFG TA/KO2 look perfect!
awocsb is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 11:21 AM #30
21TOR 21TOR is offline
21TOR is on a distinguished road
I was reading on Westcotts's site, that they can go up to 3" lift in the front without needing aftermarket UCA's to align it back to spec.
Not sure how that is possible when their spacer/collar, to me just looks like the same thing as an adjustable shock. I just dont get it.
2010-22' 4Runner SR5, TRD Off-Road, Trail, Venture & Premium Preload Collar Lift Kit - Westcott Designs
21TOR is offline   Reply With QuoteReply With Quote
designs , kit , lift , set , westcott
Lift Kit - Factory Fox TRD Pro by Westcott Designs Maka15 5th gen T4Rs 78 12-06-2021 05:57 PM
Westcott TRD Pro Kit Installed volfan615 5th gen T4Rs 13 09-27-2021 12:26 PM
Westcott Designs vs Eibach lift kit for trd pro alpaka5 5th gen T4Rs 11 10-27-2020 08:43 PM
New Baja Designs S8 LED Light Bar - Replaces Baja Designs Stealth - Now Shipping TotalAutomotiveLV Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-03-2016 08:24 PM
