Old 03-09-2021, 01:09 PM #16
ahtoxa11 ahtoxa11 is offline
ahtoxa11 will become famous soon enough ahtoxa11 will become famous soon enough
Originally Posted by SilverTEP View Post
, I found that fronts should be at 38-40 range and backs 36-38 range with chalk test.
What size tire did you have when you did the chalk test and what load rating -- C or E?
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 01:54 PM #17
SilverTEP's Avatar
SilverTEP SilverTEP is offline
Real Name: Luke
SilverTEP is on a distinguished road
SilverTEP's Avatar
Real Name: Luke
Those were 275 in E.
2018 TRD OffRoad Premium w/ KDSS, Ironman4x4 Pro Foam Cell lift, Toyo 285/70/17
2016 Trail KDSS Premium, Dobinsons Lift, RSG sliders, RCI armor, KO2s 275/70/17 *RIP*
SilverTEP is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 10:31 PM #18
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is just really nice BlackWorksInc is just really nice BlackWorksInc is just really nice BlackWorksInc is just really nice BlackWorksInc is just really nice
Originally Posted by mrblah View Post
beads do not work. I tried that too and it also made a mess later on when I changed rims.
What do you mean mess? I have beads in my 35's (bought the wheels and tires pre-installed with sensors and the company I got them from uses beads on 35+ tires), after about 20~25k the balance is getting a bit off on the Toyo RT's and I've been debating if I should throw another pack of beads or go through the trouble of demounting them, cleaning everything out, and then road-forcing them.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 12:23 AM #19
Southpaw07 Southpaw07 is offline
Southpaw07 is on a distinguished road
Wanted to give an update as I seem to have gotten the issue resolved.
Per the recommendation of re-balancing and giving a few places a try, I found that Discount Tire got it right. Although the 60 MPH steering vibration is gone, Iím now noticing a slight clunkiness in the front suspension or steering...almost as if something is loose. From one issue to another 😫
Southpaw07 is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 05:18 AM #20
mrblah mrblah is offline
mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of
I could never get my tires to balance correctly when I had them in my ko2's, Also the balance was always a little off, depending if the vehicle sat to long, or i would get a weird shimmy for the first few miles, then it would go away, then come back. The balance was never horrible, but it was never fixed either. It was enough to be an annoyance.
One day, I Forgot to tell the tire shop that I had beads in the tires, so when they went to move my tires on to new rims, resulted in a mess on the shop floor....oops my bad.
Went back to standard lead weights on my new rims w/ old tires, and no more balancing issues. Not sure if the balancing issues were due to the tires being hard to balance, or the stupid beads, or changing rims, or a combination of all of the above.
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of overlanding stickers and sponsored stickers. faking it with the IG crowd since 2016.
Old 03-10-2021, 12:12 PM #21
rjmckay99's Avatar
rjmckay99 rjmckay99 is offline
rjmckay99 is on a distinguished road
rjmckay99's Avatar
Iíve had the issue on and off since my first change to a heavier off road tire a few years ago. Different brands of tire (Cooper ST Maxx, Goodyear Duratrac), all on factory trail wheels. It was always good when it leaves the shop but creeps in over time as the tire wears.
Now, new wheels and tires and a road force balance and it seems good. The plan now is to be more vigilant with tire rotation and getting it in at the first sign of vibration to avoid uneven wear.
I think the core issue is the 4runner is just sensitive to slight imbalance in tires as they wear and a lot of tire shops donít quite get the balance right in the first place. Road force takes some of the guessing out of things so I believe thatís why people have better luck with it.
Black 2011 Trail - Icon Stage2, Rocky Road Outfitters rack,285/70/17KO2's, Konig Six Shooter 17x8, Crappy tire stubby antenna, Canvasback Liners .
rjmckay99 is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 10:25 PM #22
meltdown meltdown is offline
meltdown is on a distinguished road
For a temporary fix, try rotating your tires. I had the vibration but wanted to wait on replacing my nearly worn tires before I took it to a shop. Rotated my tires and the vibration got better. Also noticed some uneven wear on my driverís front tire. Still havenít gotten new tires. These Falkens have been wearing like iron the last 3000 miles.
2014 MGM TEP - Toytec front spacers, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 10:59 PM #23
I have only ever dealt with a few balance bead tires (my own included), but never had the opportunity to break them down (customer didn't like the labor cost for us to clean out the tires and re-balance, not that I blame them). I have noticed those odd imbalance quirks; particularly getting on a curved on-ramp; it takes a bit for the beads to move from being flung on the sidewall.
Yeah, I'm leaning closer and closer to just dismounting the tires and doing a proper road force balance one of these weekends I guess.
Thanks for the response!
alignment , expected , steering , vibration , wheel
steering wheel vibration from 40-60...sometimes Climber 3rd gen T4Rs 26 08-22-2020 10:17 PM
Steering Wheel Vibration rnguyen95 5th gen T4Rs 4 08-30-2015 07:15 PM
Steering wheel alignment off after body lift -prior to having it aligned. tehCoop 4th Gen T4Rs 7 10-01-2013 08:59 AM
Steering Wheel Alignment w/ Steering Column UncleOOPS 3rd gen T4Rs 2 07-13-2012 04:17 PM
Vibration in steering wheel danieladrian 3rd gen T4Rs 1 08-26-2007 12:59 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
