Old 03-07-2021, 10:59 PM #1
ltsatch ltsatch is offline
ltsatch is on a distinguished road
2021 TRDOR high beam replacement to LED?
Has anyone found a plug and play LED bulb to upgrade to?
ltsatch is offline   Reply With QuoteReply With Quote
Old 03-07-2021, 11:51 PM #2
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
Yup, works awesome. Half bright with DRL on and no flicker. It came from retro solutions but they aren’t around anymore. Been running it since 2018 with 0 issues
2021 TRDOR high beam replacement to LED?-05d9aa67-5e13-48be-a092-e77241b8f18c-jpg  2021 TRDOR high beam replacement to LED?-9837c1db-9621-4b58-9fec-13944209513b-jpeg  2021 TRDOR high beam replacement to LED?-ff6d9b15-fbef-462f-8c7c-9ca0531b0d64-jpeg
Axix23 is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 12:18 AM #3
Any name or make? I am really looking for working plug and play LED's for the 2021 headlights, which are new this year, it has LED low beams stock, and Halogen high beams. Thanks for the reply.
Old 03-08-2021, 01:02 AM #4
Axix23's Avatar
Axix23's Avatar
one of the best quality led bulbs on the market and very reasonable priced. Very very bright! I ran them in my low beams and fogs since 2018 before I swapped in 2021 headlights.
Here is a link:
GP-H11-CR-HL-IV
Old 03-08-2021, 02:11 AM #5
Cobratuner182 Cobratuner182 is offline
Cobratuner182 is on a distinguished road
Another '21 owner here. Basically any 9005 led will work. Just depends on quality you want. The few ive tried have all been dim while on the DRL setting and bright AF on high beam. The problem is that the DRL brightness is still really bright during the day and still looks like your high beams are on. Theres also a slight flicker with most leds under $100.
If you check out the next few pages here theres a couple other threads discussing the same topic over the past couple weeks
Cobratuner182 is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 12:12 AM #6
aweaver65 aweaver65 is offline
aweaver65 will become famous soon enough
SV.4's from Headlight Revolution work for me
I've shared this in other threads, but just in case you haven't run across those posts:
I have a 2020 TRD Pro and replaced my stock lights with LED's from Headlight Revolution right after I bought it last April.
If you google Headlight Revolution, you'll find them. These are the SV.4's.
As far as I'm concerned, they are worth every penny so far.
2021 TRDOR high beam replacement to LED?-sv-4-high-beam-jpg
2020 Army Green TRD Pro, RSG Flat Sliders. SV.4 LED's from Headlight Revolution, RAM Mount for Cell Phone (got my cup holder back!), Deleted Roof Rack (sold). Canvas Back full Cargo Liner (for my Dog "Donkey")...
Icon Stage 2, Body Mount Chop, Method MR305's and BFG KO2 285/75/17's (34 Inch Tires) (No rubbing at all), East Coast Gear 4.56 Diffs Front/Rear
aweaver65 is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 12:14 AM #7
Rjayy505 Rjayy505 is offline
Rjayy505 is on a distinguished road
nice!
Rjayy505 is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 12:26 AM #8
Only problem with these is that the 21's are LED from factory and they're actually built into the unit. Stock output is pretty amazing in my opinion... But your headlights look killer too.
Old 03-09-2021, 10:45 AM #9
Are the high beams LED on the 21's? I was thinking it was only the low beams or maybe I have that backwards?
Old 03-09-2021, 10:51 AM #10
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Only the TRD Pro and Limited trims have LED high beams. The other trim levels only have LEDs for the low beams.
Regardless of whether or not they have LED high beams, all trim levels still use an incandescent halogen bulb in the traditional high beam location as a DRL bulb.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 01:29 AM #11
What he said. My 21' ORP came with halogens in the high/ DRL. Pro and Limited low/high share the same projector.
Old 11-09-2021, 03:08 AM #12
AUXITO.COM AUXITO.COM is offline
Real Name: AUXITO AUTO LED LIGHTING
AUXITO.COM is on a distinguished road
AUXITO has a complete 2014+ Toyota 4runner LED bulb upgrade kit, all bulbs are plug and play without any modifications.
If you think the LED bulbs in the kit are not bright enough, you can choose our brightest headlight bulbs from the Y13 series.
AUXITO.COM is offline   Reply With QuoteReply With Quote
beam , high , led , replacement , trdor
2005: Current HIR options for low beam (9006) & high beam (9005)? Iron Chef 4th Gen T4Rs 6 03-15-2021 09:07 AM
2021 high beam problem after Viper DS4 install Sgt. Rock 5th gen T4Rs 6 01-08-2021 08:52 PM
Headlight high beam position now low beam, low beam position no lights. dogtail 3rd gen T4Rs 5 03-28-2020 07:35 AM
HID (Low-Beam Xenon/ High-Beam Halogen) -H4 5000k 55w on Projectors Cuco 3rd gen T4Rs 7 08-07-2016 11:17 PM
question regarding my high beam/low beam pokits 5th gen T4Rs 2 05-21-2015 02:14 AM
