Old 03-11-2021, 12:02 AM #16
sn_85's Avatar
sn_85 sn_85 is online now
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Originally Posted by Kamalani Mahie View Post
That's exactly what I was thinking. You're going to be looking down and to the right so it'll probably make that display useless. Just like the other options on the market.
I have the ICS fab one and I can still see the clock for the most part. A tiny fraction of the upper part of the first number get clipped a bit but I can always tell the time and the rest is visible. I am however only 5'7" so it's probably worse for taller people. I think of all of them the ICS fab is the least offensive and I doubt you can see anything on the Rago one. The EOE well that is a no.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is online now   Reply With QuoteReply With Quote
Old 03-11-2021, 12:57 AM #17
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie has a spectacular aura about Kamalani Mahie has a spectacular aura about Kamalani Mahie has a spectacular aura about
Good to know. I have no need for this as I've gone with another solution before these mounts were around, but they look cool and functional for sure.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 08:04 PM #18
Firesq14's Avatar
Firesq14 Firesq14 is offline
Firesq14 is on a distinguished road
Firesq14's Avatar
I almost threw up when he drilled into the panel. I will pass.
Firesq14 is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 12:55 AM #19
NorthPark NorthPark is offline
NorthPark will become famous soon enough
Just wait till your first set of pin stripes
NorthPark is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 01:19 AM #20
Lol I felt the same way 4 years ago when I bought mine. Now I've drilled through quite a bit BUT in inconspicuous places. I agree with you...this kind of drilling is probably not for me...yet.
Old 03-15-2021, 05:15 PM #21
mrblah mrblah is online now
mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of mrblah has much to be proud of
So quick review:
The Rago plate is legit. I'm pretty happy with it.
Pros:
1. easy to install with the video provided by rago. If you choose to ignore the video and go on your own and suffer, by all means do so.
2. low profile. The dash plate sits flush with the top of the dash. Even with the ram balls sticking up, it is no higher than drilling ram mounts into your dash.
3. NUTS.... The use of those allen screw nuts is a great idea. No more messing with bolts, washers, sockets, wrenches or whatever tool that will scratch the crap out of your dash. Just hand tighten and if you want to lock it down, just use a allen wrench borrowed from your ikea furniture set.
4. strong and sturdy: its bolted down at 4 points. It isn't going anywhere.
5. great fitment: My fitment was pretty spot on. Using the video, i was able to get everything flush by mounting the fasteners in sequence as in the video.
6. optional mounts/slidng rail: The RAM mounts dropped right in. There is also a sliiding rail behind the nuts, or you can use the nuts. You can also use magnetic mounts. I use all 3 options in the pictures below. If you don't want hard fixed mounts, you can use the sliding rail to position your dancing baby yoda.
7. Price: its the cheapest option of all the other dash kits out there. If you still want to cry about it, then don't buy it. Stop buying starbucks coffees for a month and not only will you save some money, you will prevent diabetes and your ever expanding waistline.
8. low profile and adjustable mic/phone mounts. Yes this is a big deal. While I love my previous DIY RAM mount, its not low profile and is either too long or too short due to the RAM extensions. With Rago's setup, you can move the mic mounts forward and backwards, so you can use ram mounts or magnetic mounts. In the pic below, i use both. the GMRS mic is on a magnetic mount, and the sat nav is on a ram mount. Obviously, you can magnetic mount your phone if you wanted to, and since the mount pivots back and forth (not up and down), to give you more flexibility.
9. unused ram mounts serve as a great place to hang your face diapers when not in use.
Compromises:
1. Drilling. Not really a con because there is no non-drilling solution to any of the dash kits. Compromises have to be made somewhere. It's easier to cry about it on the internet than come up with your own solutions. Until then, I'll buy it from Rago.
2. semi blocks the clock. You can definitely still see it if you are a midget. As for me, I have to tilt my head down to see the clock, not a big deal for me. Also, better than some of the solutions where the clock no longer is viewable.
3. Reaching the clock button. You can't anymore with your scrawny fingers. I have to use a pen or pencil head to reach it. Again, compromises are required to make this dash kit to sit flush with the top of the dash.
4. new solutions create new problems (not really a con). Having this awesome dash kit, and all the information you need at your fingertips when you are looking for the mall, means you will have a wiring mess to power all your cool guy gear. Luckily for me, i have a grandpa dash mat, so I tuck all my wires under there.
On to the pictures:
5th Gen 4Runner Dash Plate-dash-empty-jpg  5th Gen 4Runner Dash Plate-dash-full-jpg
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of overlanding stickers and sponsored stickers. faking it with the IG crowd since 2016.
mrblah is online now   Reply With QuoteReply With Quote
Old 03-15-2021, 07:46 PM #22
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie will become famous soon enough Teamoatmealpie will become famous soon enough
Mr. Blah - the with and with out accessories pics are great. Puts into perspective how clean the install looks when daily driving and how it can be kitted out for trips with Coms, Nav etc.
2003-SR5 V8 TRD Supercharger - 2016 SR5RR- 1998 454 Chevy Express 15 Passenger Van 4x4 Conversion
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 03-24-2021, 10:44 PM #23
Gonecamping's Avatar
Gonecamping Gonecamping is offline
Gonecamping is on a distinguished road
Anyone try mounting on the sides with 3m tape and not drilling? Maybe some threaded rubber feet under the top?
Just thinking of a no drill option.
I have one coming tomorrow (woot) and will most likely drill but was curious.
Gonecamping is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 01:12 AM #24
i probably wouldn't try mounting it with double sided tape and removable feet.
The kit itself is heavy. If it should fall off, its going to damage everything, and probably destroy whatever is mounted on it.
Only recommendation is watch the video posted by rago, and have some needle nose pliers handy. If you do it exactly how they do it in the exact order on which holes/screws to drill first. the reason you do it exactly how they do it, is they use the screws and the original drill holes as a way to make sure everything is flush,
If you don't, its gonna be difficult. Since i followed the video or had it playing while i was installing, it literally took me the same amount of time as the video.
Old 03-25-2021, 12:56 PM #25
ragin_cajun ragin_cajun is online now
ragin_cajun is on a distinguished road
There isn't even room for 3M VHB tape on the sides. The mount is extremely form fitting, you have to slide it over the center stack carefully.
Frankly - Let's look at this realistically. If you are the type of user that needs this for GPS, Radio, Phone, Tablet, Camera etc - You already have or will be drilling plenty of other holes somewhere along the line.
ragin_cajun is online now   Reply With QuoteReply With Quote
Old 03-25-2021, 03:52 PM #26
JerseyDevil's Avatar
JerseyDevil JerseyDevil is offline
JerseyDevil is on a distinguished road
Not something you want to try to hold in place with tape. I installed mine last weekend (had ordered a few months ago but waited for warmer weather). Definitely agree with the other posters ... follow Ragoís video EXACTLY and you wonít have a problem. Donít do shortcuts. Itís a solid piece and looks great with my CB mike mounted to it. Iím 5í8Ē and it doesnít block my view of the clock (seat adjustment all the way down). Even if it did, thereís a second clock in the radio display, so thereís that ...
JerseyDevil is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 04:01 PM #27
Thanks for all the replies.
Makes sense, I was just curious (more for others that didnít want to drill).
Now I just need UPS man to show up so I can get this thing mounted!
And yes Iíve watched the install a few times, but appreciate all the tips 5th Gen 4Runner Dash Plate
5th , attach , dash , gen , mount
SoCal - Aftermarket 4th Gen 4Runner Skid Plate + Filler Plate - $250 boxtree619 For Sale: T4R Items 2 02-04-2017 10:00 PM
3rd Gen T4R: WeatherTech, Dash Cover, and License Plate Frames. MCObray For Sale: T4R Items 2 06-20-2013 12:14 AM
Tail Lights, Markers, License Plate, Dash Lights all out! aeroneer1 3rd gen T4Rs 3 09-01-2012 06:53 PM
4runner Dash....!!! Gabo The Flash 4th Gen T4Rs 16 04-06-2010 02:55 AM
WTB: Dash for 88 4runner sleepy88 Want to Buy/Trade 0 05-16-2008 07:28 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
