03-08-2021, 09:28 PM
#16
TRD front skid and then RCI all the way back to the rear diff and shocks. Went 1/4 raw aluminum where available. Glad I waited for the new redesigned skids as they are improved, especially the gas tank. Great quality, perfect fitment, no rattles and received my orders within two weeks each time during big sales.
2017 MGM TRD Off Road Premium
03-08-2021, 09:59 PM
#17
Skids are next on my list.
Still bouncing back and forth between BudBuilt & RCI.
If BudBuilt releases the "tummy tuck" that will clinch it for me.
03-08-2021, 11:34 PM
#18
Real Name: Kirk
Real Name: Kirk
Originally Posted by gsla72
Running RCI on mine front to back including the fuel tank. Mainly chose them due to the availability/design of their TRD pro integration plate. I already had the TRD pro skid and didn't want to deal with having to change that to something else.
Overall experience was great. Ordering process was easy, they arrived well packaged within the approximate delivery/production times, and the installation instructions were good. Fit and finish with all pieces is excellent.
I opted for the non-powdercoat version to keep costs down.
THIS^^^
mine are powder coated steel, and I have the rear pumpkin skid as well.
Same reasons as above, they work seamlessly with the stock PRO skid plate.
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
03-08-2021, 11:35 PM
#19
This is what I would go with for the TRD skid goes much higher on the front than the others, almost to the bottom of the front bumper. Then the RCI from there back.
RCI is the only skid that integrates with the TRD skid on the front.
03-09-2021, 12:16 AM
#20
I have victory and so far so good
Its heavy--over 100Lbs all together. Got it here and installed myself
03-09-2021, 12:31 AM
#21
Tummy tuck plates? Please elaborate... got my attention
03-09-2021, 02:16 AM
#22
Real Name: BLACK TRD PRO
C4 has a TRD Pro integration skid also. Steel only. For ~50lbs more total for all the skids from front to rear as compared to aluminum I will take steel. Stronger, tougher and easier to fix. 50lbs extra is not going to save your gas mileage or performance. If you really need to use them the steel is better. Aluminum has better corrosion resistance.
03-09-2021, 02:45 AM
#23
RCI aluminum all day err day
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
03-09-2021, 09:52 AM
#24
Originally Posted by rageandlove
I have RCI except for the fuel tank skid. Their fuel tank skid design is not ideal, since the front end is fairly exposed to stuff being kicked (rocks, branches, etc.) There is a thread somewhere of some guy that added a bunch of extra aluminum to the front of his after he ran into problems.
I went with the Rago fuel tank skid instead - it does a much better job of covering the front end is no more expensive, and they will make it in aluminum or steel to match whatever else you decide. Highly reccomended.
RCI redesigned their gas tank skid, by the way. I have full RCI set including the redesigned gas tank skid. The front of the gas tank skid is reinforced.
I like them a lot.
Kings, Icon UCAs, 285s, full armor, rear diff breather relocation, ECGS diff bushing, Rokmen trailing arms
03-09-2021, 11:24 AM
#25
This was my thinking exactly. The weight penalty going from aluminum to steel isn't that much unless you are counting every pound and loading up near the maximum gvwr.
I went with C4 front to back, still waiting on half the order but the pieces I've received look outstanding. Love their fuel tank skid.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
03-09-2021, 11:27 AM
#26
I like them a lot.
That new gas tank design is beefy, even with being 1/4 aluminum it’s one heavy MF’r
03-09-2021, 12:01 PM
#27
Check this thread out:
5th Gen Tummy Tuck = ground clearance
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
03-09-2021, 12:39 PM
#28
Originally Posted by ryguytheman
This leaves just the fuel tank as the low point
03-09-2021, 05:48 PM
#29
I have LFD front and transmission skids with RCI transfer case skid plate. I want to say that RCI redesigned their transfer case skid plates to eliminate the exhaust rattle from getting rocks/dirt/mud stuck between the plate and exhaust.
My advice to the OP, if you think you might need steel plates, get steel. Aluminum is nice in that it doesn’t rust, but it’s more expensive, can fatigue with multiple hits and the weight savings you will get may end up being negligible after all the other weight you add, if that is what you intend to do.
2017 SW SR5
03-09-2021, 07:00 PM
#30
Real Name: J
Real Name: J
Another vote for RCI Aluminum Skids here... Integration all the back past the T-Case... Not doing heavy rock crawling so the Aluminum was plenty sufficient and the folks at RCI did not disappoint on the skids or the sliders... I believe there is an RCI group buy here every fall that will save you some $$.
Good luck!
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
