Old 03-08-2021, 06:51 PM #1
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Calling everyone with rotopaX
So I am looking for RotopaX ideas. I am looking to carry fuel and water. I have a LFD rear bumper. Is it possible to put a pax on the outside of the spare tire or iniside. Also do I need the plate or just the 1, 2, 2.25, and 4 Gallon Extension? I would love to use a 2 gallon water and a 4 gallon fuel since I don't think 2 gallons would do much. What do you have? Do you like it? Do you have pictures?
Would this work?
RIGd UltraSwing Rotopax Mounting Bracket - RIGd Supply
Thanks for reading and I look forward to seeing your setup.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 07:12 PM #2
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
You could probably mount one of the Gamiviti Spare receivers behind/through the spare. Spare Receivers — Gamiviti
Old Tanker is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 08:43 PM #3
Thanks I will contact them to see what they have. Since my spare is on the bumper I have no hitch so I would need a plate and then another plate. I wish I knew how to weld I could just make one.
The Build
Old 03-08-2021, 10:02 PM #4
That doesn't mount to your hitch. It mounts to the tire mount (on your bumper swing-out, not a stock tire mount) and adds a receiver, and you can attach a rotopax mount to that new receiver.
Old 03-08-2021, 11:27 PM #5
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
Would this work?
The Rigd Supply setup works great. 2200 miles recently with the 4 gallon unit between the tire and the hatch.
Easy on and off, not having to climb on the roof to get 30 pounds of fuel down, solid and simple.
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb rear springs, DrawTight Class IV frame hitch, Method Racing 703 Bead Grips, goodies from URD.
AMLOR is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 11:29 PM #6
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
I have several RotoPax for my ATV, but not for my 4Runner. They are a great product.
The RIDg swing arm for the spare looks like a great idea. The link you provided is just al bracket to add a RotoPax to the swing arm; you would still need the swing arm. Since the RotoPax sits between the tire and the hatch, you would only be able to have one RotoPax mounted, otherwise it would be too thick. Thus, you could not use the RotoPax extensions to add a second Pax.
The RIDg adapter does not come with the RotoPax mount, so you would need to buy the RotoPax mount (Rotopax Deluxe Pack Mount | eBay). That would allow you to mount any RotoPax from 1 gallon to 4 gallon (the RIDg picture shows a 4 gallon).
fkheath is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 03:30 PM #7
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I have a 4 gallon Rotopax on my roof sitting flat. I have the extension and plan on putting a 2 gallon water and a 2 gallon gas tank fit together to go on top of the 4 gallon gas. Currently with only 1 4 gallon gas tank I use the center hole, but once I get the 2 gallon water and 2 gallon gas I will have no choice but to use the outer two holes.
Negatives, because they sit flat I have had some leaks. You will have to take them off especially if you are losing altitude and release the pressure from time to time. Hassle. Second, wind resistance. I haven't noticed much noise since I have a wind fairing on my LFD setup but with a second one added who knows. Gas mileage will also go down.
I do not really want a rear bumper so I keep my spare underneath. I haven't figured out a location to mount the Rotopax except for my roof. I have seen some outside molle panels on the rear window but they are held on with a suction cup on the bottom so not sure about that. There are some ladders you can attach them too but I don't want or need a ladder.
Calling everyone with rotopaX-rotopax-jpg
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 03-09-2021, 08:55 PM #8
AMLOR
Got pics?
The Build
Old 03-09-2021, 11:38 PM #9
1Louder 1Louder is offline
1Louder will become famous soon enough
Got pics?
RIGd does, RIGd UltraSwing Rotopax Mounting Bracket - RIGd Supply
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
1Louder is offline   Reply With QuoteReply With Quote
Old 03-10-2021, 07:17 PM #10
Originally Posted by 1Louder View Post
I don't see that working with the LFD rear bumper.
The Build
Old 03-10-2021, 07:20 PM #11
Are those the LFD crossbars? I just bought 2 and a wind fairing.
The Build
Old 09-01-2024, 12:25 PM #12
RBLACAUSA's Avatar
RBLACAUSA RBLACAUSA is offline
RBLACAUSA is on a distinguished road
RBLACAUSA's Avatar
Late bump here. Have you figured out a solution to better mount your Rotopax? I'm on the same mission as you, for my 4th gen. Considering getting the LFD cross bars to put a rotopax gas tank up top for the few times I may need a few gallons out on a trail, but the occasional leaks thing bothers me. In addition to your comments I bolded above, I also don't want to attach anything to the side windows. I envision the limit of the rooftop stuff exactly as your photo...my Hi-Lift, MaxTrax, a gas tank and maybe an awning, too.
'04 4Runner 4X4 SE V8
'06 4Runner 4X2 SE V8
'06 LX470
RBLACAUSA is offline   Reply With QuoteReply With Quote
Old 09-01-2024, 03:54 PM #13
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
I would recommend a Rigd ultraswing. I have one but instead of a spare I have a dual jerry can holder on it, and I have the hi lift attachment but havent used it. I like that it does everything I need and is removable when not needed.
2018 TRD ORP w/ Magnuson
jdm-v35 is offline   Reply With QuoteReply With Quote
fuel , gallon , gallons , rotopax , water
Rotopax swim.bike.run 5th gen T4Rs 3 12-01-2019 04:23 AM
Rotopax 4.5 gal. Off-Camber 5th gen T4Rs 1 11-30-2019 12:52 AM
Rotopax swim.bike.run 5th gen T4Rs 26 03-21-2018 01:52 AM
rotopax gas can kolelt Off Topic 26 01-08-2015 10:40 PM
Rotopax Buckles 4th Gen T4Rs 7 09-17-2013 09:10 PM
