Old 03-11-2021, 07:33 PM #1
Rpede Rpede is offline
Rpede is on a distinguished road
Use two Anti-Squeal Clips instead of one for brakes?
I noticed the front brakes have the holes to accommodate two anti-squeal clips...some call these pad return clips. (Shaped like letter M). Seems that replacement shows only one being installed. Did some research online and other forums and some people are actually placing a second anti-squeal clip on each side. Has anyone else done this to help ensure their brake pads fully spring back after you are done applying the brakes? In theory wouldn’t this help with uneven pad wear? It does seem odd that Toyota only calls for one of these clips on each side vs two which I have seen on many cars. Would love feedback from those who have used two on each side or any brake experts advice on this. Thanks.
Rpede is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 08:14 PM #2
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
the brake pads will make a noise. bleed the brake system .. then when air is in it ,,, the pads will not move back when your foot is off the brake pedal..
if the brakes still make a noise then you remove the brake pads use 220 grit sand paper and sand the rotor in a rotation sanding .. then put high temp anti seize on the brake pad steel backing plate just a paint amount ..
pads will work best will not stick and the NO air in the brake fluid system will create a great braking .
I have done many braking work on my vehicles ,, brake pads last 40-80K miles..wear when changed 60% wear..
catrains is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 08:39 PM #3
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Lightbulb
1st heard clicking sound on my son's 11' & could never figure out what it was till I saw an old thread about this 2nd clip & bam no more clicking , guess if pads are little loose it keeps em tight , worked for me , don't know about wear issues
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 09:22 PM #4
yes old vehicles do have the brake pads move too much .. calipers do rust up a bit or wear on the setup position and they can move a bit and make a click sound when the brakes are turned on...
up in the rust belt pads rust up and get sticky and make squealing noises.
many new Toyotas have this squeal noise..dealerships put anti brake noise product on the pad backing plate ..some of the brake pads had to be changed from another pad manufacturer..Toyota ..
anti-squeal , brakes , clips , pad , side
OEM Tundra 199mm brake pad anti-Squeal shims WeakSauz Free 1 06-18-2020 09:44 AM
my front brakes squeal like a school bus 4bangr 3rd gen T4Rs 6 03-13-2018 02:39 PM
Tundra Brake Pad - Anti-squeal shims sggaz 3rd gen T4Rs 5 07-03-2014 07:45 PM
Tundra brake anti-rattle clips djbrand1 3rd gen T4Rs 12 12-27-2012 04:00 AM
Why do my brakes squeal only when going faster than 30mph? Lowpro 4th Gen T4Rs 3 04-06-2010 08:42 PM
