Old 03-20-2021, 08:38 PM #16
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Cheaper then carista, I'll give you that.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 10:15 PM #17
IjmRunner IjmRunner is offline
IjmRunner is on a distinguished road
Carista can't turn this off. I tried.
IjmRunner is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 10:16 PM #18
Originally Posted by dcguy View Post
Any thoughts on disabling it on keyless ignition models (2020+)?
I'll look into the wiring diagrams tonight.
Old 03-20-2021, 10:59 PM #19
For smart key users:
It appears without a techstream (more on that below) you won't be able to stop your buzzer from going off when your key is inside the vehicle.
Your key sends a signal to the Certification ECU (Smart Key ECU) that it is inside the car, which in turn signals the "Combination Meter Assembly"(Gauge Cluster) CPU to sound the buzzer. All communication is done via can bus signal, there is no physical wire or physical switch that can be disabled to circumvent this system, but.................
There are cables that are available online that will allow you to hook up a laptop with certain software to your vehicle to disable it. I'm not going to link you to how to do it, google is your friend, searching toyota techstream could be useful.
I still can't tell you 100% you will be able to disable this, but it's a pretty powerful solution.
-Drew
Old 03-21-2021, 01:25 PM #20
dcguy dcguy is offline
dcguy is on a distinguished road
-Drew
Thank you
dcguy is offline   Reply With QuoteReply With Quote
Old 03-21-2021, 03:02 PM #21
Charlievee's Avatar
Charlievee's Avatar
Interesting, i get a few seatbelt chimes and that's it. Maybe a year specific thing?
Old 03-21-2021, 08:22 PM #22
This isn't for the seat belt ding. It's for when your key is in the ignition and the drivers door is open, it will constantly ding unless you remove the key from the ignition or shut the door.
Old 03-21-2021, 10:10 PM #23
Charlievee's Avatar
Charlievee's Avatar
Again, i get 3 or 4 seat belt chime. Key on, engine running, door open. No extra bells or whistles. Only thing i ever did was turn everything off with the carista (flashing lights, door unlock/ lock and the rest of the factory carnival nonsense). Guess i got lucky.
Old 03-23-2021, 07:57 PM #24
Correct, and what happens when the engine is not running?
Old 03-23-2021, 08:08 PM #25
stormydawg stormydawg is offline
stormydawg is on a distinguished road
Thank you very much! Ima doing this tomorrow!
stormydawg is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 01:35 AM #26
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Finally did this today and OMG it has to be my FAVORITE "mod" so far!
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 06:18 PM #27
mostapo mostapo is offline
Real Name: 2014 TEP, Bilstein 5100's all around set at 2.5 up front, 275/70/17 Falken WP
mostapo is on a distinguished road
Nice little mod worked like a charm. Thanks OP
mostapo is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 10:36 PM #28
H20ratt H20ratt is offline
H20ratt is on a distinguished road
Can the darn buzzer be turned off or removed? 2021 keyless venture?
H20ratt is offline   Reply With QuoteReply With Quote
lower , mod , remove , screw , switch
headlight on warning buzzer when exiting vehicle? ericantonio 5th gen T4Rs 3 02-20-2019 02:23 PM
No headlight warning buzzer? Richmond Dan 5th gen T4Rs 11 12-03-2018 09:13 PM
Ignition buzzer mikesmith140 Classic T4Rs 7 09-04-2014 07:09 PM
E Brake Warning Buzzer AE1M 4th Gen T4Rs 11 11-09-2009 06:58 PM
Headlight (on) warning buzzer/bell mikolw Problems & Warranty Issues 5 07-08-2006 08:12 AM
