03-20-2021, 08:38 PM
#16
Cheaper then carista, I'll give you that.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
03-20-2021, 10:15 PM
#17
Carista can't turn this off. I tried.
03-20-2021, 10:16 PM
#18
Originally Posted by dcguy
Any thoughts on disabling it on keyless ignition models (2020+)?
I'll look into the wiring diagrams tonight.
03-20-2021, 10:59 PM
#19
For smart key users:
It appears without a techstream (more on that below) you won't be able to stop your buzzer from going off when your key is inside the vehicle.
Your key sends a signal to the Certification ECU (Smart Key ECU) that it is inside the car, which in turn signals the "Combination Meter Assembly"(Gauge Cluster) CPU to sound the buzzer. All communication is done via can bus signal, there is no physical wire or physical switch that can be disabled to circumvent this system, but.................
There are cables that are available online that will allow you to hook up a laptop with certain software to your vehicle to disable it. I'm not going to link you to how to do it, google is your friend, searching toyota techstream could be useful.
I still can't tell you 100% you will be able to disable this, but it's a pretty powerful solution.
-Drew
03-21-2021, 01:25 PM
#20
-Drew
Thank you
03-21-2021, 03:02 PM
#21
Interesting, i get a few seatbelt chimes and that's it. Maybe a year specific thing?
03-21-2021, 08:22 PM
#22
This isn't for the seat belt ding. It's for when your key is in the ignition and the drivers door is open, it will constantly ding unless you remove the key from the ignition or shut the door.
03-21-2021, 10:10 PM
#23
Again, i get 3 or 4 seat belt chime. Key on, engine running, door open. No extra bells or whistles. Only thing i ever did was turn everything off with the carista (flashing lights, door unlock/ lock and the rest of the factory carnival nonsense). Guess i got lucky.
03-23-2021, 07:57 PM
#24
Correct, and what happens when the engine is not running?
03-23-2021, 08:08 PM
#25
Thank you very much! Ima doing this tomorrow!
04-10-2021, 01:35 AM
#26
Finally did this today and OMG it has to be my FAVORITE "mod" so far!
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
04-15-2021, 06:18 PM
#27
Real Name: 2014 TEP, Bilstein 5100's all around set at 2.5 up front, 275/70/17 Falken WP
Nice little mod worked like a charm. Thanks OP
02-09-2023, 10:36 PM
#28
Can the darn buzzer be turned off or removed? 2021 keyless venture?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
