Old 03-11-2021, 07:55 PM #1
IjmRunner IjmRunner is offline
IjmRunner is on a distinguished road
PSA: How To disable key ignition warning buzzer
This mod will disable the warning buzzer that occurs when your key is in the ignition and your drivers door is open.
This mod is completely non destructive and fully reversible, no cutting.
What you need:
1. Phillips screwdriver
2. 5 minutes
How to:
1. Remove Key, turn steering wheel 90 degrees left to expose Phillip head screw (Pictured)
2. Remove left screw
3. Turn wheel 90 degrees from center to the right and expose the other screw.
4. Remove right screw
5. Separate upper and lower plastic pieces by gently pulling them apart. To fully remove the lower piece you will need to lower the steering wheel adjustment lever.
6. Under the ignition switch on the right side of the column you will see a white 4 pin plug (pictured). Unplug and tuck away.
7. Reassemble plastic column covers and reinstall the 2 Philips head screws.
NOTES:
1.This switch is called the "UNLOCK WARNING SWITCH ASSEMBLY" digging through the toyota wiring diagrams I have found no other use for this switch other than running the buzzer. I may be wrong, only time will tell. I will run this mod for the foreseeable future and try and discover if any other ECM function was tied into it, although I'm 90% confident, you have been warned. If I find any issues or symptoms, if you decide to do this mod and discover anything, or if you know of anything else this switch is tied in to, please let everyone know by posting below.
2.This mod is only for KEYED vehicles, I haven't been through the wiring diagrams for the keyless ignition 4runners, I don't even know if they beep when the receiver is in the car and the door is open or not.
IjmRunner is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 01:35 AM #2
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Honestly the most annoying thing ever.....I might do this. @Old Red do you have any knowledge on this plug from your extensive experience with the wiring diagrams and experimentation?
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 01:37 AM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Nice mod .. wish it worked with keyless trucks too
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 02:41 AM #4
I drove around with it for 2 days and noticed nothing out of the ordinary, although I have also disabled my seat belt chimes.
I'll see what I can find looking into the keyless 4runners, the keyless version will most likely require a wire being cut as there is probably no physical switch.
Old 03-12-2021, 07:47 AM #5
PJSnow's Avatar
PJSnow PJSnow is offline
PJSnow will become famous soon enough
PJSnow's Avatar
It may impact those of us with a remote start module.
PJSnow is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 08:22 AM #6
BigGy's Avatar
BigGy BigGy is offline
BigGy will become famous soon enough
BigGy's Avatar
Well written Ijm.
2021 TRD Pro
BigGy is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 01:20 PM #7
Should have zero effect on remote start modules. All this "switch" does is go to ground when your key is inserted sending a ground signal to the ECM that sounds the buzzer. It's not connected to the door switch, nor does it deactivate the 3 beeps when starting the car.
Old 03-12-2021, 01:38 PM #8
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Really? Just unplug that harness?
Old 03-12-2021, 06:10 PM #9
krhayes79's Avatar
krhayes79 krhayes79 is offline
Real Name: Kelly
krhayes79 has a spectacular aura about krhayes79 has a spectacular aura about
krhayes79's Avatar
Real Name: Kelly
Doing this ASAP!!!!!!!!!!!!! Hate that f'ing chime!!!!
THANK YOU for figuring this out!
2018 ORP | KDSS | 3/2" Dobinsons MRA Suspension | Dobinsons UCAs | 17" Procomp 29 La Paz Wheels | Falken Wild Peak 285/70/R17 | Cali Raised 20° Sliders | LFD Full Skids | ARB breather kit | 30" KC Hidden light bar | LFD 7/8 Rack | LED interiors/low beams/fogs | MESO Puddle Lights | #newb
krhayes79 is offline   Reply With QuoteReply With Quote
Old 03-12-2021, 07:24 PM #10
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Lightbulb
Tanner was one who showed me this simple mod after I asked him if he had found which plug it was !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 02:26 AM #11
Good to know. Have you done this and has everything been normal since?
Old 03-13-2021, 12:07 PM #12
Talking
Yes sir zero & have the Accessorides start ! Been nice & quiet . Only the initial dong when when key in
Old 03-14-2021, 11:24 AM #13
Been over a week now, doesn't appear this is tied into anything else in the truck.
Old 03-15-2021, 03:47 PM #14
Awesome thanks!
Old 03-20-2021, 08:11 PM #15
dcguy dcguy is offline
dcguy is on a distinguished road
Any thoughts on disabling it on keyless ignition models (2020+)?
dcguy is offline   Reply With QuoteReply With Quote
lower , mod , remove , screw , switch
headlight on warning buzzer when exiting vehicle? ericantonio 5th gen T4Rs 3 02-20-2019 02:23 PM
No headlight warning buzzer? Richmond Dan 5th gen T4Rs 11 12-03-2018 09:13 PM
Ignition buzzer mikesmith140 Classic T4Rs 7 09-04-2014 07:09 PM
E Brake Warning Buzzer AE1M 4th Gen T4Rs 11 11-09-2009 06:58 PM
Headlight (on) warning buzzer/bell mikolw Problems & Warranty Issues 5 07-08-2006 08:12 AM
