Old 03-30-2021, 12:14 PM #31
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
I have had a Sherpa Crestone for just over a year. After I finished mounting it, one side panel ran a little too close to the roofline, but when I contacted Sherpa, Will was quick to respond and sent some replacement mounting brackets - the new design - and it fits perfectly now. It's as modular as an erector set and quite easy to add accessory brackets and such exactly where you want them. Very solid and no leaks. Little to no wind noise (I'm a little deaf, but my wife isn't and she has no complaints).
I was a little skeptical from the engineering perspective: The brackets are bolted to the roof through the rubber mounts. The horizontal crossbar rides on a pair of those brackets, held by a few 1/4" bolts. The long side panel is bolted to the crossbar by two 1/4" bolts on each side. The next crossbar is bolted to the side panel by two 1/4" bolts. So any weight on the second crossbar is distributed through quite a few bolts along the way back to the first crossbar and the mounting feet. A cheap copy would flex, separate, and fall apart under stress. This is not a cheap copy. It feels solid, and rides quiet, with no creaks. I run a Gazelle tent, a tailgater awning, and four traction boards on the roof. Maybe a Gobi would offer a more integrated construction, but with less modularity, more weight, and rust.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 04:23 PM #32
justanothereric justanothereric is offline
justanothereric is on a distinguished road
Originally Posted by Sconnie View Post
I do not currently own a roof rack. However, I've been doing my own research on them and I'm 99.9% sold on a Sherpa Crestone rack. No drill. No silicone/butyl. Aluminum. Rustproof. Looks sharp. This thread sold me on them. I don't see any negatives.
Sherpa Crestone Rack Install/Review
Sherpa racked ordered a few weeks ago! Hopefully get it mid-June. Thank you all for your inputs! Finally won't look so naked without a roof rack soon.
Roof Rack Recommendations!-truck-jpg
justanothereric is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 02:18 PM #33
1Louder 1Louder is offline
1Louder will become famous soon enough
I have a Victory 4x4 rack. Only thing I don't like about it is the slots that allow you to move the crossbars forward and aft are very small. I ended up removing 2 of the bars for that reason because they would not work with my setup (I have a solar panel recessed in the roof rack.
RCI and other makes similar racks with larger slots to allow for more forward and aft movement. I think those are better for that reason and provide greater flexibility. In the end most use the same parts. Buy an RCI and get accessories from Victory 4x4, for example... The rails are the same. Mounting hardware for accessories can be bought from V4x4 in small packets or bulk at Amazon.
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
1Louder is offline   Reply With QuoteReply With Quote
Old 05-11-2021, 03:06 PM #34
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
Nothing but good things to say about Sherpa. Way better then my LFD I had before. Less weight, excellent craftsmanship, etc...
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
4x4 , overland , rack , roof , style
Roof Rack Waterproof Storage Bag Recommendations mtbtim 3rd gen T4Rs 21 09-08-2018 11:34 AM
Roof Rack Recommendations Throwback 5th gen T4Rs 22 12-09-2016 11:36 AM
Roof surfboard rack, recommendations? ouki 3rd gen T4Rs 11 12-26-2012 11:17 PM
Recommendations on tie-down hooks for the roof rack? SilverGs 4th Gen T4Rs 0 01-17-2012 05:27 PM
07 4Runner Roof Rack Systems - measures and recommendations? gcraig Engines / Suspension / Wheels / Tires / Audio / Accessories 9 02-26-2011 09:10 PM
