03-17-2021, 08:24 PM
#16
Real Name: Kirk
Real Name: Kirk
Originally Posted by Saker
@ AMLOR
@ fkheath
@ Charlievee
This thread requires EDITING of the first post.
So here is what I found out.
The short Studs for the rear of this mod are insufficiently brittle/weak.
You ask, how do you know this.... because I went out to check the nuts to make sure they were still tight using Belleville washers and upon tightening them each of the rears broke without much ft pds.
So the first post will be edited with the latest Rev 1.1
SS parts ordered! Thanks for the heads up on the substandard parts!
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
03-18-2021, 07:29 PM
#17
I found the Dremel tool worked the best for me.
Why, yes. Yes it does.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
03-20-2021, 03:35 PM
#18
Got it done with today's oil change. Only concern is the front studs backing out, when i take it down (couldn't find red loctite local). Info and measurements provided by Saker are spot on. sure make getting the plate back up a snap.
03-20-2021, 05:52 PM
#19
I used blue loctite.
Red Loctite, if you have to remove the stud, you have to heat to 500 degrees F !
Best Regards,
Saker
03-20-2021, 06:26 PM
#20
Exactly.
03-26-2021, 09:45 AM
#22
Thanks for the idea and write-up! I used cut stainless bolts for the front and yellow zinc for the rear.
2019 TRD OR: TRD CAI | Gibson Elite Cat-back | Wildpeak AT3W 265/70/R17 | Anytime Backup Camera/Front Camera | TRD Pro Skidplate | Victory 4x4 Crossbars | ARB Diff & Locker Breather Relocate | Apex Overland Front Recovery Points | LFD Sliders | GS59-700/C59-300 | GS59-705/C59-599 | Dobinsons UCAs | Greenlane Offroad Ladder
04-03-2021, 01:33 PM
#23
10mm ID
TOYOTA kit= +-$16.00
Try McMaster-Carr
Write up only speaks to front bolts. What length for the rear bolts?
04-03-2021, 01:51 PM
#24
@ CutthroatSlam
Hmmm, on my response I was addressing your retainer question.
If you are referring to the mod, first paragraph under
EDITED VERSION Rev 1.1 is for the rear bolts as only those can come in from the top.
Shout out if you request more info!
Best Regards,
Saker
04-03-2021, 02:09 PM
#25
@ CutthroatSlam
On the fronts, use the same M10 x1.25 hex bolts in 70MM length. Cut the head off with dremel and run into proper depth? Using blue loctite to hold them in?
04-03-2021, 05:31 PM
#26
You got it!
I cut mine to total length of 2 5/8” to bottom out in the forward radiator location.
Depending on what nut and washer hardware you use, the total length may be different.
If you use what I used, 2 5/8” is correct, blue loctite screw them in till they bottom out. If you put 2 nuts on each stud, lock them together and tighten the studs up tight, release the nuts, unscrew the nuts. Put your skid on & .... done!
Shout back if you need anything!
Best Regards,
Saker
04-12-2021, 10:01 AM
#27
Pulled the skid plates yesterday, amazing how this mod simplifies the project. The neurotic part of me was thinking of doing this mod for the rest of the plates... maybe one stud in each for indexing. Probably not. Lol.
04-12-2021, 08:11 PM
#28
Someone should buy 100 of each and make and sell kits for cost +$20 to the 500 of us that are too disorganized to ever get to this.
04-12-2021, 08:57 PM
#29
I would love to do that, but it is so easy to order these and DIY.
I’ve listed parts and instructions for everyone!
I will take donations for the guidelines if you want to drop some coin in my PayPal acct!!!!!!
Best Regards,
Saker
07-03-2021, 05:35 PM
#30
Did this mod today and it was not hard at all. I did have to chase the threads on the rear holes, but otherwise, pretty straightforward. So much easier putting the skid plate back on. No longer hunting for threads with the bolts while also holding up the skid plate.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
