Old 07-03-2021, 06:31 PM #31
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Originally Posted by CutthroatSlam View Post
Did this mod today and it was not hard at all. I did have to chase the threads on the rear holes, but otherwise, pretty straightforward. So much easier putting the skid plate back on. No longer hunting for threads with the bolts while also holding up the skid plate.
@CutthroatSlam
Took mine into the dealership several days ago and the sr tech that works on my truck was blown away at this mod.
He told me it made his job really easy removing and replacing the skid plate.
Best Regards,
Saker
Old 07-04-2021, 12:24 AM #32
57HotrodVW's Avatar
57HotrodVW 57HotrodVW is offline
Real Name: Eric
57HotrodVW will become famous soon enough 57HotrodVW will become famous soon enough
57HotrodVW's Avatar
Real Name: Eric
Originally Posted by Saker View Post
I used blue loctite.
Red Loctite, if you have to remove the stud, you have to heat to 500 degrees F !
Hand tools can be easily used to remove fasteners secured with red Loctite. I've done it many times over the years.
57HotrodVW is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 02:44 AM #33
Saker's Avatar
Saker's Avatar
FEATURES AND BENEFITS
Loctite Threadlocker Red 271 is designed for the permanent locking and sealing of threaded fasteners.
The product cures when confined in the absence of air between close fitting metal surfaces. It protects threads from rust and corrosion and prevents loosening from shock and vibration. It is only removable once cured by heating up parts to 500°F (260°C).
Loctite(R) Threadlocker Red 271™
YMMV
Best Regards,
Saker
Old 07-04-2021, 03:45 PM #34
57HotrodVW's Avatar
Real Name: Eric
57HotrodVW's Avatar
Real Name: Eric
YMMV
At most, you'll only need to use a longer ratchet/breaker bar/cheater pipe to remove fasteners secured with Loctite 271 (aka "red"). It holds better than blue, but can be easily removed with hand tools. Trust me, or try it yourself... 😊
Old 11-29-2022, 02:09 PM #35
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
YMMV
you can try 272 or other types. Most of the reds have lower melt points of just under 300F. Theres only a couple Red types that go much past that. Loctite has a chart listing all their min max temps and operating ranges. Ideally get one that has anti corrosive properties, can be used on bolts that are dirty and oily and resist vibration.
Grug556 is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 09:45 PM #36
papadop88 papadop88 is offline
papadop88 is a jewel in the rough papadop88 is a jewel in the rough papadop88 is a jewel in the rough
My dealer didn't strip one of my bolts, but the genius who used an impact driver to remove the skid broke off the welded nut in the support frame that the front bolt goes screws into. So now I only have one bolt in the front holding the plate and the two in the rear. It's extremely annoying. Anyone have a solution for that because I don't think this great solution Sake provided will work?
2020 TRD Pro | Super White | C4 Fab Lo-Pro Bumper | Warn Evo VR10-S Winch | Factor55 ProLink | Morimoto XB Headlights | Baja Designs Squadron Amber SAE Fog Lights | USR Rear Black Tailights | Shrockworks Angled Sliders | Sprint Booster V3 | TRD OEM CAI | Llumar CTX 25% | King 2.5 Front Coilovers w/ Res Adjusters and rear 3-Tube Bypass Shocks | Camburg UCAs | Eibach 1" Rear Coils | RRW-7H Graphite Blue 17x8.5 -12 | KO2s 285/70/17 | Raptor Lights | Prinsu Roof Rack w/ Cali Raised 40" Amber LED Bar | GOBI Ladder | Agency6 Recovery Shackle | Baja Designs Squadron Ditch Lights | Cali Raised Molle Panels
papadop88 is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 10:36 PM #37
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Have a new nut welded in place.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 11-29-2022, 11:10 PM #38
That was my first thought as well, but after taking a look at where the nut is, it's inside the support frame and there's no way of getting in there. The original welded nut is just dancing around in there. You would have to drill a large enough hole in the frame to get a welder in there to weld a new one. That was my only thought.
Old 11-29-2022, 11:38 PM #39
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
Sounds like the dealer owes you a new piece. What was their proposed solution?
NB17Limited is offline   Reply With QuoteReply With Quote
Old 11-30-2022, 05:42 AM #40
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Pretty simple for a competent welder.
With a new nut, chamfer the outer edge a bit.
Drill a hole so the nut will pass thru.
Countersink the hole slightly.
Hold new nut in hole using a minimum 2"+ bolt threaded into nut.
With the new nut flush with the frame member, using a TIG welder, tack the nut to the frame member on the outside.
Remove bolt carefully, continue to tack in more spots and/or finish weld
When cooled off, chase thread with a tap if needed.
With a good weld, there should be no grinding flush needed.
20 minute task, max.
seatia is offline   Reply With QuoteReply With Quote
Old 11-30-2022, 03:23 PM #41
They never gave me one. Their only solution was to cut off the loose bolt that was screwed into the nut. So I brought it back to them and they just cut the bolt off and said tey took care of it. When I saw it, I realized they just did that and there's no bolt in that right front hole. So now the plate is just mounted using three bolts. It ain't going anywhere, but still. Really annoyed by it.
Old 11-30-2022, 03:25 PM #42
Appreciate this Seatia! I'll look into it.
Old 11-30-2022, 07:34 PM #43
Grug556's Avatar
Grug556's Avatar
There are many grades of Loctite red, some require heat to remove, others dont. Blue is ok ive used it for years on various parts. I use to use alot of Green in specialty transmissions as well. This chart only has a few of their range but you get the idea. I think blue for most parts with red for specialty stuff
TRD Skid Plate Mounted w/ Studs 2010-2021, 2022, 2023-loctite-chart-jpg
Old 12-01-2022, 04:25 AM #44
The cost will be minimal if you do all the prep yourself and just employ the welding.
Old 05-05-2023, 08:53 PM #45
icestud's Avatar
icestud icestud is offline
Real Name: Matt
icestud is on a distinguished road
icestud's Avatar
Real Name: Matt
Thanks for taking the time to write this up and post it👍🏻
I do have one question why did you use Stainless Belleville Washers (WB16SS - Stainless Belleville Washer) and not the washers for a 10 mm bolt?
Matt
2023 TRD Pro Solar Octane Westcott Lift, Dobinsons UCA, Westcott 0 degree no Kick Out, No top plate Sliders, Ugly Rack Removed
icestud is offline   Reply With QuoteReply With Quote
bolts , nut , plate , skid , studs
WTB: Factory skid plate and tranny pan 2010 Houston QwikKotaTx Want to Buy/Trade 2 11-08-2021 10:26 AM
Front TRD Pro Skid Plate Install on 2010-2013 SR5's (no KDSS) T4RDriver 5th gen T4Rs 5 08-21-2019 05:39 PM
2010 - current shock works 5 skid plate set. IRON433 For Sale: T4R Items 5 12-20-2016 11:15 PM
FS : BudBuilt 2010+ 4runner KDSS stainless Steel Front Skid Plate 300.00 reconmarine For Sale: T4R Items 6 11-19-2012 03:19 PM
