Old 03-14-2021, 01:56 AM #16
TheWraith's Avatar
TheWraith TheWraith is offline
Real Name: Justin
TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light
TheWraith's Avatar
Real Name: Justin
Originally Posted by lewdog998 View Post
What is the new spin on filter that you use?
I use a Wix 51068 / Napa Gold 1068 oil filter (at $4.58 each ... bought in bulk )
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
TheWraith is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 08:30 AM #17
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Originally Posted by Bwwepplo View Post
Broke the plastic tab off my stock plastic oil filter housing during the last oil change. Figured the metal one would be a more durable option but now it’s leaking. Before mounting the new one I took a file to the small mould-lines that go right down the middle of the part but maybe I didn’t file enough... thought about using a small application of black RTV along the mating surface to make up for the less than perfect finish. Have y’all had this issue / do you recommend going back to the plastic housing or is there a fix that you recommend?
I would recommend this tool by Assenmacher and to use the plastic housing. It does not require a lot of torque seal up the housing.
Assenmacher Tool of Boulder, Colorado Toyota Filter Wrench
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 04:02 PM #18
Bwwepplo Bwwepplo is offline
Bwwepplo is on a distinguished road
Thank you all for the tips!
Bwwepplo is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 04:33 PM #19
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
I don't if I would be comfortable owning an assmuncher tool.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 04:35 PM #20
wut?
Sunroof
Old 03-18-2021, 07:10 PM #21
skag1T skag1T is offline
skag1T is on a distinguished road
I recently found out that there are a lot of counterfeit Toyota parts on amazon and all over the place, make sure you buy the aluminum oil filter housing from a Toyota dealer !
The aluminum oil filter housing that fits the 4Runner is the one for the Camry, and you need to swap the inner tube.
Part number: 15620-31060 (OEM Toyota Camry). The bottom cap part number is 15643-31050.
There is a youtube out there that explains all this counterfeit issue, The Car Care Nut. Check him out.
skag1T is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 10:53 AM #22
ltsatch ltsatch is offline
ltsatch is on a distinguished road
Surprised to see the cost of that adapter at $200. I guess it makes sense if you do your own oil changes. I do not do my own changes. I could see a service tech spinning that sucker loose and not retightening. The fact that it also adds another potential gasket to leak is an issue for me as well.
ltsatch is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 11:19 AM #23
blackie2's Avatar
blackie2 blackie2 is offline
blackie2 is on a distinguished road
blackie2's Avatar
These are the parts for a metal filter housing. I got a second one from a dealer that sent me two when I only ordered one. I'll put it on my new 2021 if I need to in the future. All you have to do is replace the tube with the one off your old filter. Just press on the down on the tabs between the holders on the inside of the filter and you can twist the tube off.
Metal oil filter housing-img_20210319_101448829-jpg  Metal oil filter housing-img_20210319_102115868-jpg
2021 SR5 Premium 4x4 stock, Nitto Terra Grapplers
blackie2 is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 11:24 AM #24
rsclancy rsclancy is offline
rsclancy is on a distinguished road
Counterfeit everything
Buying anything from Amazon now has become a crap shoot- tools, parts, clothes, whatever.
rsclancy is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 11:25 AM #25
Its spring loaded too, IRRC.
Old 03-19-2021, 12:16 PM #26
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I went with a Baxter Performance spin on filter kit because of all the issues with the oem filter.
Toyota TS-201-BK Cartridge To Spin-On Adapter
SKU: TS-201-BK
Replaces medium size Toyota, Lexus or Scion cartridge filters that require Toyota filter #04152-YZZA5.
Note: 4Runner and FJ Cruiser require TRD or aftermarket Skid plate for filter clearance.
Price:
$199.95
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 12:56 PM #27
Saker's Avatar
Saker Saker is offline
Saker's Avatar
SKU: TS-201-BK
Price:
$199.95
So, does anyone have information on what OEM Toyota filter this would take?
Best Regards,
Saker
Old 03-20-2021, 08:48 AM #28
blackie2's Avatar
blackie2's Avatar
Yes it is. You push down the tabs then push the whole tube down and twist it off. Replace the tube with the stock tube and put the tabs back to their original position then just push it down and twist it into place.
Old 03-20-2021, 10:56 AM #29
Saker's Avatar
Saker's Avatar
Don’t forget to bend the tabs back up so the tube stays in place!
Best Regards,
Saker
Old 04-17-2021, 07:57 PM #30
The Toyota brand metal filter housing is in and no leaks. If it wasn’t so difficult to figure out how to post pictures on here I could show y’all the huge difference in casting and finishing quality. Didn’t get any calipers out but it comparing the Toyota to the Doorman unit, it seems like the recess for the o-ring was too deep on the doorman and doesn’t allow the o-ring to protrude far enough.
housing , metal , oil , plastic , small
Replaced plastic filter housing with metal - question fir those that already did Nuke 5th gen T4Rs 36 02-02-2021 12:42 AM
Metal Flakes (gold color) in Oil Filter Housing Cap? Woz1976-MT 5th gen T4Rs 10 06-17-2017 03:53 PM
WTB: 3rd Gen Air Filter Housing Run 4 Fun Want to Buy/Trade 6 02-26-2016 02:51 PM
Metal oil filter housing flying fuzz 5th gen T4Rs 7 01-02-2015 08:10 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
