Old 03-13-2021, 12:03 PM #1
Bwwepplo Bwwepplo is offline
Bwwepplo is on a distinguished road
Metal oil filter housing
Broke the plastic tab off my stock plastic oil filter housing during the last oil change. Figured the metal one would be a more durable option but now it’s leaking. Before mounting the new one I took a file to the small mould-lines that go right down the middle of the part but maybe I didn’t file enough... thought about using a small application of black RTV along the mating surface to make up for the less than perfect finish. Have y’all had this issue / do you recommend going back to the plastic housing or is there a fix that you recommend?
Bwwepplo is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 01:30 PM #2
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
You DID install the rubber sealing O-ring it (should have) come with didn't you...?
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 01:40 PM #3
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
... o-ring also has to be installed in the correct location. What brand of oil filter housing did you install? A genuine Toyota part or Dorman? Did you look for 'casting lines' in the groove for the o-ring? Did you install a genuine Toyota oil filter and o-ring? Where did you buy the oil filter housing, and oil filter?
Dorman is the lowest quality oil filter housing one can buy. A few years ago, I inspected two after market oil filters and decided to never install one in my 4Runner.
DougR is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 01:52 PM #4
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
It helps to pre oil that o-ring as well so it doesn't unseat itself on installation.
5thToy is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 05:02 PM #5
Yes, after breaking the tab off the plastic housing during the install, I took the new o-ring back off the plastic one and put it onto the metal housing in the correct location without damaging the o-ring.
Old 03-13-2021, 05:07 PM #6
It’s the doorman, didn’t realize Toyota sells one. I don’t remember looking for the casting lines there I only remember noticing and filing them down at the bottom of the threads on that mating surface.
The filter and ring are purolater, not Toyota.
Ya it definitely seemed very low quality once I saw it in person...
Old 03-13-2021, 05:10 PM #7
Ya I lightly coated the o-ring before putting it on. The leak is of a pretty considerable quantity. After about 400 miles it’s started to leak out from above the primary skid plate and sling back towards the exhaust and fuel tank skid plate
Old 03-13-2021, 05:41 PM #8
DougR's Avatar
DougR's Avatar
Amazon sells a genuine Toyota oil filter housing. I buy oil filters from the dealer because oil filters advertised as genuine on Amazon might be counterfeit. Dealer oil filter price is reasonable.
Old 03-13-2021, 05:51 PM #9
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
Believe it or not, many people in the t4r community have had this issue when swapping to the metal housing.
I know people who have done the swap will probably quote me saying 'well I've never had an issue' but this is a common occurance. I've also heard of it happening in the Audi/VW community on other vehicles.
I'm not sure if it's just an O ring issue or if the metal just doesn't seal as well as the plastic housing.
NorthPark is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 06:22 PM #10
DougR's Avatar
DougR's Avatar
Plastic threads or metal threads on the oil filter housing do NOT seal against leakage. Oil filter housing does NOT have a flat washer to provide sealing like a drain plug. O-ring does the sealing.
Old 03-13-2021, 07:34 PM #11
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I don't know the brand of metal oil filter housing, but I have seen about 3 or 4 of them now leaking on customer's cars.
They just have "Made in China" stamped on main housing and a torque spec on the filter drain plug and you can tell the quality is shit, grind marks all over the casting. The thing I noticed with all of the ones that leaked was that the O-Ring groove was too deep, the O-Ring barely stuck out of the groove and caused a leak.
I really should have mic'd the factory vs. the non-factory ring groove depths for my own curiosity. If I see another one I'll post pictures and measurements so you guys can steer clear of that type/brand.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 08:16 PM #12
That would certainly do it.
Old 03-13-2021, 10:36 PM #13
TheWraith's Avatar
TheWraith TheWraith is offline
Real Name: Justin
TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light
TheWraith's Avatar
Real Name: Justin
I went with a Baxter Performance spin on filter kit because of all the issues with the oem filter.
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
TheWraith is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 10:44 PM #14
bear1998 bear1998 is offline
Real Name: Bryan
bear1998 will become famous soon enough
Real Name: Bryan
My guess why some of the people who has had problems with the canisters leaking was because of the o'ring not being properly placed in the right groove....
bear1998 is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 01:01 AM #15
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
What is the new spin on filter that you use?
lewdog998 is offline   Reply With QuoteReply With Quote
housing , metal , oil , plastic , small
Replaced plastic filter housing with metal - question fir those that already did Nuke 5th gen T4Rs 36 02-02-2021 12:42 AM
Metal Flakes (gold color) in Oil Filter Housing Cap? Woz1976-MT 5th gen T4Rs 10 06-17-2017 03:53 PM
WTB: 3rd Gen Air Filter Housing Run 4 Fun Want to Buy/Trade 6 02-26-2016 02:51 PM
Metal oil filter housing flying fuzz 5th gen T4Rs 7 01-02-2015 08:10 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
