Old 03-15-2021, 12:04 PM #16
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
Originally Posted by RidgeRunnin View Post
My Oil filter housing drain plug (Red Arrow) was stuck on at my last oil change and out of fear of cracking the plastic housing in a vice, i just left it on without changing the gasket under it(this time).
It's like you could hear my frustration on Saturday, when I was changing the oil on my SIL's '15. That o-ring does it's job very well, but makes undoing the plug difficult without getting the housing to move.
Yes, you can just undo the housing, but I like to keep my garage floor clean and I bought the little tool from MotivX that screws into the drain and relieves the oil nicely.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 01:15 PM #17
Jlongoriaz5 Jlongoriaz5 is offline
Jlongoriaz5 is on a distinguished road
I tried printing the tool. When I opened the file, no dimensions were included. In other words, if I print it as is, the tool will be tiny. Any advice? Can you post or send the file with the proper dimensions?
Jlongoriaz5 is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 01:17 PM #18
Hello All, I was hoping someone wouldn't mind being a guinea pig for a little tool i mocked up last night.
With that said, i made a model of a filter wrench with a through hole so in theory you should be able to hold the filter housing steady and crack loose the metal plug.
If someone is bored and has an oil change coming up i would appreciate and feedback on the design so that i works at my next change
When i do find the time to drop the skid plate and fit check the tool i'll update.
Link to both the .stl and .stp are below.
Free CAD Designs, Files & 3D Models | The GrabCAD Community Library
I tried printing the tool. When I open the file, there are no proper dimensions. In other words, if I hit print as is. The tool would come out very tiny. Can you include the proper dimensions?
Old 11-27-2023, 02:37 PM #19
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
Originally Posted by 3kushn View Post
Easylife45 I second the impact comment but suggest a butterfly impact.
Why Butterfly?
I know this is an old thread but my butterfly impact is 75 ft lbs max where my 1/2" impact is over 700, less chance to really tear something up.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 11-28-2023, 08:52 PM #20
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of CutthroatSlam has much to be proud of
Originally Posted by MeefZah View Post
I respect your ingenuity.
That said, you don't have to drop the filter drain bolt. It's an extra step that maybe makes the job like 10% less messy.
I just unscrew the filter housing, leaving the drain bolt in place. Turn the filter housing upside down to let it drain.
342K miles and I’ve never removed the metal center plug. Why would you? The filter housing has to come out anyway.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 11-29-2023, 10:18 PM #21
skag1T skag1T is offline
skag1T is on a distinguished road
I second CutthroatSlam. I always do my own oil changes, and on my 2018 SR5, in the first year or so i would religiously try to remove that center plug and replace the gasket. Lots of frustration and sweat.
Then I decided I will not remove that thing again, ever. 80k miles later, haven't removed it and don't see any problems. I have about 100k miles on the truck. The only thing is, when you remove the filter housing get ready for a big mess. I wrap the filter housing in 1-2 microfiber cloth before unscrewing it. Still messy, but manageable.
Toyota did a really stupid thing with this oil filter.
skag1T is offline   Reply With QuoteReply With Quote
Old 11-30-2023, 01:04 PM #22
Whippersnapper02's Avatar
Awesome work. I just used an impact on mine to remove the first time and then made sure I didn't over tighten it.
Old 11-30-2023, 11:59 PM #23
I just position a big drain pan/container under it. Then just wipe down where it drips on the frame. Not a big deal.
Old 03-24-2024, 05:11 PM #24
gwsears gwsears is offline
gwsears is on a distinguished road
Hi,
Having issues viewing this thread but I am in need of the tool that you have designed. Would love to purchase one but am having difficulties PMing you.
If you can message me I would appreciate it.
George
Savannah, GA
gwsears is offline   Reply With QuoteReply With Quote
Old 03-25-2024, 06:56 PM #25
Originally Posted by ElectroBoy View Post
What @00Sebby said.
And if you have the metal replacement housing it will be even more apparent that you will tighten until it bottoms out and it will not turn any more. The plastic ones will accept a little torque after being fully seated but not the metal ones.
I can almost remove my metal one by hand.
To make sure it stays in place when undoing the oil filter drain I hold the housing in place with big channel lock pliers.
Sometimes I do the @MeefZah method, it’s just a little more messy. But I bet that’s how the dealer oil changers do it, it’s faster.
2014 SR5 with 350K miles and all I've ever done is spin off the entire plastic housing. It's easy and not messy at all.
change , filter , housing , oil , plug
ATF drain plug stuck? freeflight 4th Gen T4Rs 2 07-16-2016 05:53 PM
Stuck Diff Drain Plug planeboy95 4th Gen T4Rs 12 10-11-2015 10:11 PM
Quick oil change question - locate drain plug nysimonsez Maintenance/Detailing 15 03-31-2008 12:41 PM
1st oil change... filter and plug torque settings? FlipIam Maintenance/Detailing 5 12-04-2006 08:44 PM
Plug at '06 Oil Filter Drain Bob Kazian Maintenance/Detailing 1 02-15-2006 09:28 AM
