Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 03-13-2021, 03:24 PM #1
RidgeRunnin's Avatar
RidgeRunnin RidgeRunnin is offline
Junior Member
RidgeRunnin is on a distinguished road
Junior Member
Oil Change, Stuck Filter Drain Plug, Solution?
Hello All, I was hoping someone wouldn't mind being a guinea pig for a little tool i mocked up last night.
My Oil filter housing drain plug (Red Arrow) was stuck on at my last oil change and out of fear of cracking the plastic housing in a vice, i just left it on without changing the gasket under it(this time).
With that said, i made a model of a filter wrench with a through hole so in theory you should be able to hold the filter housing steady and crack loose the metal plug.
If someone is bored and has an oil change coming up i would appreciate and feedback on the design so that i works at my next change
When i do find the time to drop the skid plate and fit check the tool i'll update.
Link to both the .stl and .stp are below.
Free CAD Designs, Files & 3D Models | The GrabCAD Community Library
Oil Change, Stuck Filter Drain Plug, Solution?-oil_filter_drain-jpg  Oil Change, Stuck Filter Drain Plug, Solution?-file_002-jpg  Oil Change, Stuck Filter Drain Plug, Solution?-file_000-jpg
__________________
2018 TRD Off-Road
RidgeRunnin is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:08 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Senior Member
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
Senior Member
ads2539's Avatar
Looks like a great solution!
I have a 4th gen, with the “old fashioned” oil filter, so I can’t be your guinea pig.
__________________
2004 Limited V8 4WD 184k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:25 PM #3
jrandom's Avatar
jrandom jrandom is offline
Senior Member
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
Senior Member
jrandom's Avatar
This exactly why I love being able to do cost effective rapid prototyping! Twenty years ago it would have cost you over a thousand bucks and three weeks of waiting to make that.
Great idea. thankfully, I haven’t run into the issue. regardless, this is a perfect solution for it.
__________________
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:31 PM #4
Charlievee's Avatar
Charlievee Charlievee is offline
Senior Member
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Senior Member
Charlievee's Avatar
Or you can use the vise grip style oil filter pliers. Just saying.
__________________
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 04:35 PM #5
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
I change my 4runner's oil every 5000 miles right in my driveway. Definitely don't want that drain bolt locked on so you can't get it off - or you strip something.
The filter should be hand tight and 1/4 turn further.
FordF150 is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 05:03 PM #6
00Sebby's Avatar
00Sebby 00Sebby is offline
Senior Member
Real Name: Mark
00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice
Senior Member
00Sebby's Avatar
Real Name: Mark
What you said is true for standard one-piece spin-on filters since the gasket has to be compressed enough to seal the oil in and not overly compressed that the gasket squishes out and leaks.
However, these cartridge filters have to be turned until they bottom out against the mating part... like a dead stop. Hand or wrench doesn't matter, but you turn to fully-bottomed condition vs. turning to the subjective tightness of a spin-on filters. The only reason I am pointing this out is with "hand tight + 1/4 turn" someone could think it's tight enough without it being fully rotated in and it could leak later.
And even though it's a simple concept, every dealer and quick change place will still over-torque these housings and make it almost impossible to take off without damaging or breaking them.
__________________
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
00Sebby is offline   Reply With QuoteReply With Quote
Old 03-13-2021, 05:03 PM #7
jrandom's Avatar
Senior Member
Senior Member
jrandom's Avatar
Quote:
Or you could use an impact wrench, or you could use a strap wrench, or you could use 64.5(?) mm socket, or...
__________________
2013 TE w/ KDSS Nav
Old 03-15-2021, 11:25 AM #8
firebirdguy firebirdguy is offline
Member
firebirdguy is a glorious beacon of light firebirdguy is a glorious beacon of light firebirdguy is a glorious beacon of light firebirdguy is a glorious beacon of light firebirdguy is a glorious beacon of light
Member
this is the 5th gen section captnsolo, they dont use canister type spin on filters like a 4th gen.... & the spin on filters are usually 3/4-1 full turn, not 1/4 turn.
firebirdguy is offline   Reply With QuoteReply With Quote
Old 03-15-2021, 12:04 PM #9
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Member
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Member
Real Name: Ben
Quote:
It's like you could hear my frustration on Saturday, when I was changing the oil on my SIL's '15. That o-ring does it's job very well, but makes undoing the plug difficult without getting the housing to move.
Yes, you can just undo the housing, but I like to keep my garage floor clean and I bought the little tool from MotivX that screws into the drain and relieves the oil nicely.
__________________
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 01:17 PM #10
Jlongoriaz5 Jlongoriaz5 is offline
Junior Member
Jlongoriaz5 is on a distinguished road
Junior Member
I tried printing the tool. When I open the file, there are no proper dimensions. In other words, if I hit print as is. The tool would come out very tiny. Can you include the proper dimensions?
Jlongoriaz5 is offline   Reply With QuoteReply With Quote
Reply
Tags
change , filter , housing , oil , plug
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ATF drain plug stuck? freeflight 4th Gen T4Rs 2 07-16-2016 05:53 PM
Stuck Diff Drain Plug planeboy95 4th Gen T4Rs 12 10-11-2015 10:11 PM
Quick oil change question - locate drain plug nysimonsez Maintenance/Detailing 15 03-31-2008 12:41 PM
1st oil change... filter and plug torque settings? FlipIam Maintenance/Detailing 5 12-04-2006 08:44 PM
Plug at '06 Oil Filter Drain Bob Kazian Maintenance/Detailing 1 02-15-2006 09:28 AM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
