Old 03-14-2021, 09:35 AM #1
SilverFox2020 SilverFox2020 is offline
SilverFox2020 will become famous soon enough
Towing a 4Runner help.
I am stuck between a rock and hard place with my 4Runner. My wife and I have worked very hard and saved to be able to retire early. Now we want to travel the country by RV. I would like to be able to explore the backcountry of the places we visit, thus I need a capable off road vehicle. I absolutely love my 4Runner over the Jeep’s I have had in the past, however I will not be able to dingy tow the 4Runner nor will my RV pull be able to pull it on a trailer as the combined weight will be about 7000#.
I have done my homework and there doesn’t seem to be a way to dingy tow these without disconnecting the driveshaft. The company that made the driveshaft disconnect no longer makes them as they have had too many vibration issues.
So here is my dilemma. I don’t want to go back to a Jeep. Now I am eyeing the Colorado with the Bison ZR2 package. I hate to get rid of my beloved 4Runner but alas I must make a choice.
I’m reaching out to see if there is an way to tow a 4Runner without damaging the transmission or transfer case. I’m all ears as they say.
SilverFox2020 is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 09:51 AM #2
Jeremy556's Avatar
Jeremy556's Avatar
Put transfer case in neutral and tow it. No, don't do that. Here's why:
Old 03-14-2021, 10:48 AM #3
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
Horrible advice!! 4runner transfer case oil pumps are driven by the input shaft and with it in neutral you might bounce enough fluid around to lubricate everything but you might also destroy the transfer case.
Arnezie is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 12:01 PM #4
I have done the research and this is what seems to be the consensus. Im just hoping there is an easy way that I am missing.
Old 03-14-2021, 01:22 PM #5
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Another possible option is to get a side by side ATV, and haul it behind your motor home on a utility trailer. The ATVs can go almost anywhere the 4Runner can go -- almost.
You see them all over in Utah and western Colorado. Letter: ATV tourism has damaged Moab’s reputation -- but there’s a middle ground
The biggest down side is they are not nearly as comfortable as the 4Runner, especially when it is cold or dusty.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 02:03 PM #6
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
bad advice...
It is an expensive fix
you are on the right track, unless the owner's manual says you are good to go (pretty sure it doesn't)
Sounds like you need a bigger tow Motor home
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 03-14-2021, 11:20 PM #7
I checked my owners manual and it specifically says NOT to tow with ANY wheel on the ground.
Old 03-17-2021, 10:28 AM #8
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
@SilverFox2020 Get an old FJ40 and put it on a dolly or trailer. FJ40 only weighs about 3200lbs and would definitely be one of the most fun vehicles to explore the Backcountry in retirement...(at least that's what I would do). I hope to have the same plan when I retire...Congrats on the early release!
Here is a discussion on Mud about it.
Best way to tow my 1980 fj40 behind my motorhome? | IH8MUD Forum
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 11:04 AM #9
spartacus's Avatar
spartacus's Avatar
Disconnecting the front and rear drive shafts completely from the the TC and the rear and front diff's is your only option.
Old 03-18-2021, 06:05 PM #10
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
  • more capable totter
  • Aluminum trailer
  • Side by Side
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 07:00 AM #11
Well problem solved. I stumbled on a pretty nice 98 TJ that was set up to tow for pretty cheap. It’s a win/win as I get a beater Jeep and I get to keep the 4Runner.m
Old 03-20-2021, 11:53 AM #12
Whippersnapper02's Avatar
The front can stay in. It doesn't spin in 2wd due to the ADD.
Old 03-21-2021, 01:03 AM #13
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
TJ's have been rising in price lately. Congrats.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 03-21-2021, 06:25 PM #14
Dropzone's Avatar
Dropzone's Avatar
sorta what I figured but without access to a 5th gen owner's manual
nice score, keeping the 4runner means you only sorta went to the darkside
Hope the jeep being 23 years old won't take a ton of maintenance to make a reliable vehicle.. My 94 4Runner being 27 brings somes challenges
@503dropzone on IG
Old 03-21-2021, 11:11 PM #15
Yeah riding around int the TJ reminds me of how much I love the 4Runner. Good thing about that old Jeep, it’s not to hard to work on. Besides, I gotta have something to do as my 4Runner is built like a brick chit house.
4runner , dingy , driveshaft , i’m , tow
Towing another 4runner 89T4runner 3rd gen T4Rs 3 12-18-2019 10:47 AM
Towing with your 4Runner? dano General Discussions 23 09-16-2017 07:26 PM
New to me 96 4runner, towing? ashbata 3rd gen T4Rs 2 06-29-2015 06:50 PM
Towing with 4Runner jinnohilario 4th Gen T4Rs 4 06-26-2014 07:07 PM
Towing with 4Runner? biskit 4th Gen T4Rs 8 12-29-2007 01:55 PM
