View Poll Results: Standard Load (P) or E load?
standard load (P) 7 53.85%
standard load (P)
7 53.85%
E load 6 46.15%
E load
6 46.15%
Voters: 13. You may not vote on this poll
Old 03-23-2021, 04:06 PM #16
jhmoore jhmoore is offline
Real Name: John H. Moore
jhmoore will become famous soon enough jhmoore will become famous soon enough
Poll: LT E-load or P?
I'm struggling mightily with replacing my stock Dunlop tires with an E rated or P rated tire. Planning to get General Grabber ATX. There's no C load option.
My vehicle: 2018 TRDORP, fairly stock: stock suspension, no lift, haven't added a ton of weight
My usage:
1. Daily driver in San Diego
2. I'll do 3-6 longer trips per year (Sierra mountains in CA; desert in UT/AZ, mountains & valleys in WY/MT/ID) and then some runs out to play in the Anza-Borrego desert outside of San Diego
3. I'm not a hard-core rock crawler
4. I do spend a fair amount of time on unpaved roads
5. Recent offroad, as examples: White Rim Trail outside of Moab; Kofa National Wildlife Refuge--way back; national forest roads outside of Zion NP; national forest roads in Jackson Hole; various trails in Anza-Borrego Desert; White Pocket and other areas within Vermilion Cliffs NM in UT/AZ; various non-hard-core trails in Death Valley NP)
I pretty much always air down. Have been on the stock tires for almost 3 years / 45K miles and have not had a problem. Time to replace those and I'm trying to balance tire weight, MPG, ride, cost, and durability.
Go with the P (SL) or E????
Only difference on the Grabber ATX's been P (SL) and E is the sidewall, so far as I can tell.
jhmoore is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 04:17 PM #17
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
I have ATX P-rated mainly due to most driving in on sandy soils or the beach. They air down a hell of a lot better than E load tires.
If it was rocky, I would go with E.
It's all a tradeoff.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 03-23-2021, 04:34 PM #18
Hmmm... my reply up two comments was a new post with attached poll, but looks like some admin combined the this post and that new poll post and buried the info that I wanted to go with the poll deep into this thread....
Old 03-23-2021, 06:38 PM #19
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
I haven't lost any fuel economy since switching from oem tires to 255/80R17 Toyo OC A/T III (E load). It's both taller (33") and heavier (50 lb) than oem. They ride like I'm on pillows but the handling is much more controlled and stable than the oem tires, probably the stronger sidewalls.
If you frequently venture off road by yourself, I would go for better puncture resistance just to be safe. Toyo makes an E load in oem size at 48 lbs. Great tire.
BF Goodrich KO2 is available in C load 265/70R17. I think Cooper Discoverer has a C load in this size as well.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 10:01 AM #20
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
I went with KO2s because of the 3 ply sidewall and being a C-load. The Generals are at a great price point, but I have had great experiences with KO2s and definitely would have been dissapointed in going with the Generals for the $200 price difference. KO2s also look cooler because Smiles per Gallon is important
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 01:24 PM #21
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
OP, the 285/70/17 fits just fine in the spare area. I have my KO2s in that size mounted up with no issues. It's a wider tire than stock so it hangs down a little lower, but it's not evident nor a hinderance, IMO.
P/SL vs E? For me, the decision was load C, which is the middle ground. Es are too much for the 4runner when it comes to street driving -- they will transmit small bumps and cracks in the road more than C and especially P-rated tires.
So consider other tires that come in C load in the size you want. To me, most AT tires are pretty close in how they perform given the same load rating comparison. The differences aren't that huge, I think. So, it comes down to the looks of the tire and load rating for most people. If I HAD to choose the between P and E, I'd probably go E. I don't daily drive much, so durability offroad would take priority. If I did drive a lot more, I'd probably stick with P and ensure my spare was well-maintained in case there was an issue on the trail.
This is how I ended up with Load C KO2s in 285/70 flavor. They look good and aren't too stiff, although they are stiffer than P/SL so you will feel more NVH with them.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 02:03 PM #22
Tuco S.'s Avatar
Tuco S.'s Avatar
Originally Posted by Pedro367 View Post
I went with KO2s because of the 3 ply sidewall and being a C-load. The Generals are at a great price point, but I have had great experiences with KO2s and definitely would have been disappointed in going with the Generals for the $200 price difference. KO2s also look cooler because Smiles per Gallon is important
I'm pretty sure the C load KO2 has a 2-ply sidewall. The E load has a 3-ply sidewall for sure.
Old 03-25-2021, 03:24 PM #23
Well look at that. You're right. Thought they all had the TriGard sidewall.
Old 03-25-2021, 06:03 PM #24
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
I have 285 E rated K02, ride seems fine to me but want to get C next time for less weight.
And as previously mentioned, 285(at least K02) fit fine in spare tire spot.
OP, the extra clearance is nice in Anza Borrego with 285 but I understand not wanting to lug around the extra weight/lower MPG.
2018 SR5P+3rd row, 285 KO2, 5100+Dobinsons 300/505
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 06:16 PM #25
wow, it is a lot tighter then I expected.It is flush against the trailer hitch. Maybe the chain pulley pulls it flush to it?
These are actually used 285 KO2 and K02 supposedly run small for 285.
Tech Help Needed: General Grabber ATX on 2018 TRDORP-pxl_20210325_220739633_resized-jpg  Tech Help Needed: General Grabber ATX on 2018 TRDORP-pxl_20210325_220826672_resized-jpg  Tech Help Needed: General Grabber ATX on 2018 TRDORP-pxl_20210325_220834994_resized-jpg
Old 03-29-2021, 10:03 PM #26
nickjo nickjo is offline
nickjo is on a distinguished road
I believe General makes their AT/X 265/70 r17 in C load.
I found it here on Tire Rack: https://www.tirerack.com/tires/tires...omCompare1=yes
nickjo is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 11:21 PM #27
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
They only sell stock size in SL (which they apparently don’t like being called “P”) and E.
91foxbody is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 12:40 AM #28
Their website lists a C load range tire in stock size, I think? Not sure if I'm missing something.
Tech Help Needed: General Grabber ATX on 2018 TRDORP-grabber-png
Old 03-30-2021, 01:20 AM #29
I can’t find that, and only see SL/E rating here.
https://generaltire.com/sites/defaul...r_v2_Print.pdf
I’ll be damned, I just found the C rated tire on TR. It must be brand new. Just bought SL in stock size 2 months ago, son of a *****!
Old 03-30-2021, 02:39 AM #30
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
A day or 2 off road by yourself? Definitely go with anything but P or SL. You're just asking for trouble with a P rated tire.
I went from stock 265P up to 275 E's and they are just fine.
Although I know they are heavier, so for the next set I buy will be 285 C range.
nglayton is offline   Reply With QuoteReply With Quote
lot , national , pounds , rating , roads , roughly , san , stock , tire , trails
Where the heck are the jack points?? 2018 TRDORP w/ KDSS jhmoore 5th gen T4Rs 84 11-27-2023 01:30 PM
General grabber at2 thinblue148 3rd gen T4Rs 7 09-03-2016 03:51 PM
BFG AT vs. General Grabber AT2 speedgoat 3rd gen T4Rs 4 10-10-2012 04:46 PM
General Grabber AT2 Maritimer Engines / Suspension / Wheels / Tires / Audio / Accessories 6 09-24-2010 09:50 AM
BFG A/T KO Vs. General Grabber AT2 benk777 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 08-22-2007 06:34 PM
