View Poll Results: Standard Load (P) or E load?
standard load (P) 7 53.85%
standard load (P)
7 53.85%
E load 6 46.15%
E load
6 46.15%
Voters: 13. You may not vote on this poll
Old 03-31-2021, 07:28 PM #31
jhmoore jhmoore is offline
Real Name: John H. Moore
jhmoore will become famous soon enough jhmoore will become famous soon enough
Originally Posted by 91foxbody View Post
I can’t find that, and only see SL/E rating here.
https://generaltire.com/sites/defaul...r_v2_Print.pdf
I’ll be damned, I just found the C rated tire on TR. It must be brand new. Just bought SL in stock size 2 months ago, son of a *****!
You're right, General Tire does not list a C load on their website. If this is real, it'd be great. Guess I'll send another inquiry to General Tire.
jhmoore is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 07:36 PM #32
Originally Posted by nickjo View Post
I believe General makes their AT/X 265/70 r17 in C load.
I found it here on Tire Rack: https://www.tirerack.com/tires/tires...omCompare1=yes
the tire on that link has a load rating BELOW the load rating that General Tire gives for their SL tire... doesn't make a lot of sense...
Old 03-31-2021, 09:52 PM #33
nickjo nickjo is offline
nickjo is on a distinguished road
Odd. Let me know if you hear from GT about why that's the case.
That said, I can confirm they do exist.
Tech Help Needed: General Grabber ATX on 2018 TRDORP-gatxcl-jpg
nickjo is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 10:13 AM #34
General Tire confirms that the 265/70R17 A/Tx does exist in a C load:
"We offer the Grabber A/Tx in an LT265/70R17 112/109T LRC, under part number 04509790000. We are currently experiencing a delay in site updates."
That said...
- The OEM tires are a 113S
- The A/Tx SL are 115T
- The A/Tx C are 112T
So the C are UNDER the original load rating for the vehicle (which I assume isn't good) and UNDER the load rating of the SL... which just flat out confuses me! I sent another question back to General Tire about that.
Old 04-01-2021, 10:14 AM #35
Hard to argue with a photo of the actual tire!!!! :-)
Old 04-01-2021, 10:29 AM #36
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
That said...
I believe that P-metric tires take a load reduction hit of 1/1.1, so roughly a 9% hit, when mounted on a truck or SUV. Also the LR C vs the SL would have different max pressures and would need to be run at different pressures for the same load.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 10:45 AM #37
91foxbody 91foxbody is online now
91foxbody will become famous soon enough 91foxbody will become famous soon enough
That said...
They did tell me via email:
"Thank you for contacting Customer Relations at General Tire. You are correct, the LT C version of the A/Tx will be more durable than the P-Metric version."
....so hopefully the sidewall is a bit more durable? I notice that the tread width is ~1.2'' wider and the tread depth is 1/16'' deeper.
91foxbody is online now   Reply With QuoteReply With Quote
Old 04-01-2021, 02:30 PM #38
Got this back from General Tire:
"P-Metric tires are rated with a 10% overage in load capability when used on SUV's, Light Trucks, and Vans because of the difference in load handling. However, there is no 10% overage for LT tires. An SL tire has an equivalent 4 ply sidewall, while a C has a 6 ply sidewall, offering slightly more durability than the SL.
Part#: 04509790000
Pattern_Name: GRABBER A/TX
Description: LT265/70R17 112/109T FR GRABBER A/TX
Load Range: C
Load Index: 112 - 2469 lbs
Season: AS
UPC: 51342213313
Width: 10.43"
Rim Width: 17"
Secvtion Width: 10.7"
Overall Diameter: 31.61"
I asked a couple follow up questions and got this:
"The tire is 46 lbs. As for the load range E tires, they have an equivalent 10 ply rating."
Old 04-01-2021, 02:57 PM #39
That makes me particularly pissed that after ~30 days of hemming and hawing I bought SL-rated ATX's 3 months ago LOL.
Old 04-01-2021, 03:02 PM #40
CMTAZ CMTAZ is offline
CMTAZ will become famous soon enough
I used stock size wildpeaks on my 2018. They have been great on and off road (though the off road stuff is pretty mild).
Tech Help Needed: General Grabber ATX on 2018 TRDORP-img_20200819_153144-jpg
2018 SR5 Premium - Eibach Pro Truck Lift Kit - TRD Wheels - Falken Wildpeak AT/3 - Tyger Armor Step Bars - Clear Bra - Kenwood DMX706s head unit - PowerBass 6.5" coaxial & 6x9" component speakers (tweeters replaced by JBL 3.5" coax) - Kenwood Excelon 5 Channel Amp - Pioneer 12" Shallow Mount Subwoofer - RAV4 Convex Mirrors - LED Headlights - Lexus LED Fog Lights (clones)
CMTAZ is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 03:10 PM #41
You're past their 45 satisfaction period, but find out when the C's came out... and if it was before you bought your SL's and they STILL don't have the C's on their website, contact them and make the case that they should let you swap (and pay the difference, as the C's are likely more expensive). You never know, they might say yes...
Old 07-04-2022, 04:16 PM #42
T4Ronner T4Ronner is offline
T4Ronner is on a distinguished road
Is everyone still happy with their SL load 265 Grabbers? Thinking of reading out these new Ko2’s I just bought. They feel heavy and they can’t seem to get them balanced. Going to try one more time. If no luck I’m moving to the Cooper AT3 4s or General Grabbers. I think the C load is overkill for me these days.
T4Ronner is offline   Reply With QuoteReply With Quote
Old 07-04-2022, 09:38 PM #43
I’m about a year now on LT E Grabber A/Tx. Have been great. Only complaint is the 2 MPG they cost me.
lot , national , pounds , rating , roads , roughly , san , stock , tire , trails
Where the heck are the jack points?? 2018 TRDORP w/ KDSS jhmoore 5th gen T4Rs 84 11-27-2023 01:30 PM
General grabber at2 thinblue148 3rd gen T4Rs 7 09-03-2016 03:51 PM
BFG AT vs. General Grabber AT2 speedgoat 3rd gen T4Rs 4 10-10-2012 04:46 PM
General Grabber AT2 Maritimer Engines / Suspension / Wheels / Tires / Audio / Accessories 6 09-24-2010 09:50 AM
BFG A/T KO Vs. General Grabber AT2 benk777 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 08-22-2007 06:34 PM
