Old 02-14-2024, 02:52 PM #1
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Brake pad replacement PSA
Over the years I've changed brakes on more vehicles then I can recall, but as we all know every brake job is a little different. The 4Runner was getting on about 45K so I figured it was probably time.
Everything went relatively smoothly until I went for a test drive. Was hearing a terrible grinding sound from the front passenger side when applying the brakes. Fearing the worst, I pulled back to the garage and removed the tire. Turns out when installing the new pads I inadvertently missed the hole on one of pads with the caliper pin and that was causing the grinding. Luckily there wasn't any damage and upon installing the pin correctly all was good.
Double check your work.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 05:38 PM #2
djeepin djeepin is offline
djeepin is on a distinguished road
"inadvertently" is the wrong word for this
djeepin is offline   Reply With QuoteReply With Quote
Old 02-14-2024, 08:37 PM #3
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Wouldn’t be the first time the hole was missed.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 02-15-2024, 01:01 PM #4
premise premise is offline
premise is on a distinguished road
...the horror...
premise is offline   Reply With QuoteReply With Quote
brake , grinding , installing , pads , pin
V8 Brake Pad Replacement bagelsjustbagels 4th Gen T4Rs 5 06-06-2019 12:08 PM
brake pad replacement for 2wd v8 keakar 4th Gen T4Rs 6 10-13-2017 09:13 AM
Brake Replacement MattB1 5th gen T4Rs 27 07-31-2017 07:29 PM
Brake pad replacement kai920 4th Gen T4Rs 14 12-22-2011 12:13 AM
Brake Pad Replacement wtn11 4th Gen T4Rs 4 12-19-2011 11:56 AM
