Real Name: Kirk
Real Name: Kirk
GVWR/GCWR or NO your roof rack bars make no diffderence
It seems to me that there is WAY to much worry and consternation about the load capacity stickers on the door.
The real crux of the matter is the vehicles Gross Vehicle Weight Rating.
I will use my 19 Pro and my Airstream basecamp 20 as an example.
When we left to go to Big Bend NP in January of this year, the CAT scale, 1st weight showed the following:
Front Axle: 2920 lbs 80lbs under max axle capacity
Rear Axle: 3640 lbs 190lbs OVER Max axle capacity
Trailer: 3800 lbs 500lbs under max load capacity
TOTAL: 10360 lbs fuel, 300lbs of people, and assorted stuff for a week in
the desert etc. etc.
NOTE: we DID take the time to move some stuff into the trailer once we saw the weight. We were at 3430 on the rear after we moved some stuff around.
NOTE 2: the trailer tongue weight on the weight distributing hitch is 490 lbs.
That is part of the truck's weight once the trailer is hooked up.
Final weight:
Front axle: 2930 lbs 70lbs under max axle load
Rear Axle: 3430 lbs 20lbs under max axle load
Trailer: 4000 lbs 300lbs under max axle load
TOTAL: 10360 lbs
Toyota Owners manual says the GVWR on the 4runner is 6300 lbs...3000 front axle, 3450 rear axle.
Airstream says the GVWR on the trailer is 4300 lbs
TOTAL Gross COMBINATION Weight Rating 10600 lbs.
So was anything over gross...NO!
Close, absolutely! That said the truck has heavier springs front and rear as well as a dual core radiator, transmission cooler, larger rear LCA's, 4.88 gears, a frame mounted WD hitch, and E load rated tires.
The 4runner tows nicely at 60mph in 4th gear and gets between 10-11mpg doing it. I set it up to tow, and I am still within Toyota's GCWR numbers.
We all have WAY more load capacity available in our 4Runners that we can use most days. Don't leave your wife at home because you are worried about the extra rack bars or your axle locker....
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
