Old 03-20-2021, 04:13 PM #16
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by ahtoxa11 View Post
Anyone has any insight on why the locker reduces the payload so much? I’d guess it’s something to do with axle weight limits but it can’t be that the locker makes the axle weaker.
It’s just the weight of the locker hardware itself.
Old 03-20-2021, 04:31 PM #17
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
The weight of the locker hardware is negligible. However, the torque that can be applied to one axle shaft with a locker, is significant.
I've never seen a definitive comment from Toyota regarding why the payload is reduced so much with the locker, but limiting the potential load on a single axle shaft by reducing payload, makes sense.
02SE is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 07:36 PM #18
Banned
Real Name: Mark
Banned
Real Name: Mark
What you said sounds right. It must be so you don’t destroy the rear axle shaft when locked under worst case conditions. I’d imagine if you don’t engage the locker you could increase your payload to the 1165 lbs spec.
Looking around the forum it seems no one has found the official answer but this thread and the @Jetboy posts cover your assessment, and it makes sense.
Vehicle weight capacity with Diff Lock
Old 12-19-2021, 02:45 PM #19
syedlink27 syedlink27 is offline
syedlink27 is on a distinguished road
Does the lower payload of the TRD ORP have anything to do with KDSS?
I have KDSS and the rear locker and my stick says 880 lbs.
Will KDSS be damaged/affected if you overload the vehicle or tow?
syedlink27 is offline   Reply With QuoteReply With Quote
Old 04-19-2024, 02:10 PM #20
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Old thread but my 2015 SR5 4x4 with third row has the 12 lbs yellow reduction sticker and the 1165 payload rating.
I would have thought an additional row would have reduced the rating significantly. My 3rd row has since been removed and converted into fridge / proper storage space.
This really got me wondering if I was approaching my payload / gvwr with mods and newly added RTT so I took it to the Cat Scales. With me not in the vehicle, half a tank of gas and all my permanent items in or on the rig:
Front Axel weighed 1340, rated for 3000
Rear Axel weighed 2660, rated for 3450
Gross weight 4000, GVWR of 6300, 2300lbs remaining
My guess it to toss out what the scales are reading as I am 400 lbs lighter than the lightest factory curbweight. I have 200lbs on my roof, 150lbs of armor, at least 20lbs heavier per tire x5 and 150lbs of items in the trunk. With my 3rd row removed Im guessing I am at 500 lbs over the curb weight...
Anyway according to the payload I'm probably right at capacity when I get in the car with the gf and camping gear. Will try to get another weight elsewhere.
Edit 4/22/24: I was able to measure the front two tires and then the rear axle on a calibrated freight scale.
Drivers Tire 1513, Passenger 1369 for a total of 2882
Rear Axel 2633
Gross 5515, GVWR 6300, 785 Remaining
Im guessing the "weighmaster" at the cat scales fudged up my front axel numbers or they are in serious need of calibration.
4runner cargo payoad-img_1728-jpg  4runner cargo payoad-img_1723-jpg
El Dusty is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 09:57 PM #21
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
GVWR/GCWR or NO your roof rack bars make no diffderence
It seems to me that there is WAY to much worry and consternation about the load capacity stickers on the door.
The real crux of the matter is the vehicles Gross Vehicle Weight Rating.
I will use my 19 Pro and my Airstream basecamp 20 as an example.
When we left to go to Big Bend NP in January of this year, the CAT scale, 1st weight showed the following:
Front Axle: 2920 lbs 80lbs under max axle capacity
Rear Axle: 3640 lbs 190lbs OVER Max axle capacity
Trailer: 3800 lbs 500lbs under max load capacity
TOTAL: 10360 lbs fuel, 300lbs of people, and assorted stuff for a week in
the desert etc. etc.
NOTE: we DID take the time to move some stuff into the trailer once we saw the weight. We were at 3430 on the rear after we moved some stuff around.
NOTE 2: the trailer tongue weight on the weight distributing hitch is 490 lbs.
That is part of the truck's weight once the trailer is hooked up.
Final weight:
Front axle: 2930 lbs 70lbs under max axle load
Rear Axle: 3430 lbs 20lbs under max axle load
Trailer: 4000 lbs 300lbs under max axle load
TOTAL: 10360 lbs
Toyota Owners manual says the GVWR on the 4runner is 6300 lbs...3000 front axle, 3450 rear axle.
Airstream says the GVWR on the trailer is 4300 lbs
TOTAL Gross COMBINATION Weight Rating 10600 lbs.
So was anything over gross...NO!
Close, absolutely! That said the truck has heavier springs front and rear as well as a dual core radiator, transmission cooler, larger rear LCA's, 4.88 gears, a frame mounted WD hitch, and E load rated tires.
The 4runner tows nicely at 60mph in 4th gear and gets between 10-11mpg doing it. I set it up to tow, and I am still within Toyota's GCWR numbers.
We all have WAY more load capacity available in our 4Runners that we can use most days. Don't leave your wife at home because you are worried about the extra rack bars or your axle locker....
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 02:02 PM #22
El Dusty's Avatar
El Dusty's Avatar
Originally Posted by AMLOR View Post
Final weight:
TOTAL: 10360 lbs
That's nothing short of a miracle that you are right at or under your ratings with your mods and towing. Does it include passengers?
I think the takeaway is GVWR is your engineered limit but you will need scales to verify. Payload works for quick and easy numbers but if you exceed it you may still have leftover capacity according to GVWR / axle ratings. I would assume you would be legally held to the GVWR / axles.
Toyota de-rating payload and blanketing all models into the 1165 vs 835 group is lazy and I wont try to guess reasons. My third row, kdss and other options seem to have little to no affect on payload but for some reason the port installed options and a locker get reduced payload? Very inconsistent and no wonder there are multiple threads on the topic.
Old 04-28-2024, 02:53 PM #23
Real Name: Kirk
Real Name: Kirk
Yes...me at 185lb and my wife at 107lb. both in the front seats
full tank of fuel as well
I would agree without the trailer...GVWR would be the legal standard...
with the trailer hooked up GCWR and the individual ratings of all 3 axles would apply.
Toyota de-rating payload and blanketing all models into the 1165 vs 835 group is lazy and I wont try to guess reasons. My third row, kdss and other options seem to have little to no affect on payload but for some reason the port installed options and a locker get reduced payload? Very inconsistent and no wonder there are multiple threads on the topic.[/QUOTE]
1500lb , 4runner , cargo , means , theory
DIY 4Runner Cargo Attic 007Tacoma 5th gen T4Rs 0 12-30-2020 10:52 PM
2011 4runner cargo cover and cargo mats bandit1942 New Members 0 06-14-2012 05:59 AM
4Runner cargo cover jsun_2k For Sale: T4R Items 16 07-05-2011 09:19 PM
WTB 96 4runner cargo cover tan Rod Classifieds - buy & sell (no commercial ads please) 2 03-24-2010 02:01 AM
99 4runner cargo mat wtb tailduster Classifieds - buy & sell (no commercial ads please) 0 10-31-2006 12:08 PM
