Old 03-18-2021, 11:35 AM #1
DEF4Runner's Avatar
DEF4Runner DEF4Runner is offline
DEF4Runner will become famous soon enough
DEF4Runner's Avatar
Roof rack leaking?
Rained like hell last night...jumped in the ole T4R this morning, pulled the seat belt over and noticed it was wet...real wet. Looked over at the side, under what would be the forward roof rack mount, and noticed..well...water coming out of the belt housing and also soaking through the roof liner.
Common sense might suggest it is, in fact, the roof rack mount but wanted to ask those who know the anatomy of these rigs better than me, is there any other place to check? The rig was parked nose down on a 30 degee slope over night so I guess the water could have leaked in somewhere else and rolled down????
Roof rack leaking?-leak-jpg
SOLD 2008 V6 SR5 4X4 @ 165K: 265/70/17 Falken Wildpeak | SPC Racing UCAs | Method NV wheels | Wheeler's T1/T12 springs| Bilstein 5100
2020 Off Road 4X4: 265/70/17 Falken Wildpeak | OME 883/ Wheeler's T13 | Bilstein 5100 | Sprint Booster
DEF4Runner is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 11:49 AM #2
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
OEM roof rack or aftermarket?
Also, if you have a sunroof, occasionally those drains can get clogged and back up, (at least that was the case in my sons Land Cruiser) not sure if the 4runner has same drain system.
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 11:52 AM #3
DEF4Runner's Avatar
DEF4Runner's Avatar
It's a port installed pro rack. No sunroof...
Old 03-18-2021, 12:14 PM #4
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Likely a poor install job at the port, in that case. If that were me, I'm not sure whether I'd take to the dealer or not for fear that they'd make it worse. But, I'd also be pretty upset because water could discolor the headliner.
I'd probably let the dealer fix the leak as well as the headliner if it stains.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 12:35 PM #5
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
Yep, looks like a poor install on the OEM rack. Take it to the dealer and have them deal with it.
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 01:55 PM #6
AgentKooper AgentKooper is offline
AgentKooper will become famous soon enough
Roof rack leaking?
Sorry to hear that, man. I’d be curious to hear your updates regarding getting this fixed. I have the same rack on a 2021.
2021 4Runner TRD Pro (Lunar Rock)
AgentKooper is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 02:54 PM #7
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
As I have experienced myself and also said on other posts regarding this topic - many times the leak is not so pronounced, but rather very subtle. They way you'll you know is by pulling your seat belts all the way out to the stops and see if they are wet or damp. Mine had just a hint of dampness, signifying a small leak that may have never been noticed. As water never leaked/ran down the pillar or into the ceiling panel.
Hope yours is under warranty and they fix it for you. If not pull it and inspect to see if the factory parts/gaskets are there. DIf you use any sealant, don't use silicone or RVT, use the a proper product like SikaFlex 221. RVT has acetic acid in it to help it cure, that etches paint and can cause rust.
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 11:21 PM #8
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Since you are still under warranty, just have the dealer fix it.
Otherwise it is an easy repair. There are sealing washers between the rack and the holes in the roof where the screws go in. You may have to remove the whole rack, but just put some high quality sealant (silicone) around each mounting bolt and reinstall.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 11:57 PM #9
Thirty4 Thirty4 is offline
Thirty4 is on a distinguished road
Wow....so sorry to hear that. I remember on the FJ’s that there were issues with the seals sometimes on the factory racks. Maybe it’s something similar, not sure. But I was shocked to see it occur to a newer model year. I am curious to see what the resolution is. On my FJ, it was a deformed seal. It was installed improperly and clearly was not suitable to seal out water. Good luck man!
2021 4Runner TRD Pro (Magnetic Gray Metallic)
2021 4Runner TRD Pro (Lunar Rock) - Sold
2020 Land Rover Defender 110 HSE - Sold
2016 4Runner SR5 - Sold
2010 FJ Cruiser - Sold
Thirty4 is offline   Reply With QuoteReply With Quote
belt , mount , rack , roof , water
2019/2020 Pro Roof Rack To SR5/Off-road Roof Rack LRT 5th gen T4Rs 19 02-05-2022 03:45 PM
Known issue with roof rack (stock) leaking? GrantK 5th gen T4Rs 12 03-04-2020 11:33 AM
Fixing Leak - roof rack rail leaking, also with pics of rear sunroof drains. [pics] bener 3rd gen T4Rs 2 10-17-2014 02:53 PM
Roof Leaking After New Roof Rack BlackWorksInc 4th Gen T4Rs 1 05-23-2013 10:59 PM
Wanna trade my roof rack for your roof rack covers? Qyota 3rd gen T4Rs 10 05-07-2013 10:23 PM
