Old 03-18-2021, 08:02 PM #1
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
TPMS life span and interchangability question
I have a 2014 4runner. I bought 4 2018 trail wheels and they had the tpms sensors from the 2018 included. I am going to get new tires for the trail wheels and I was hoping I could use the sensors that came from the 2018. Does anyone know if they will work? I think the Toyota part number is different.
Also how long do the stock tpms sensors work. I figured my 2014 sensors are at the end of their life and I would be wasting my time taking them off the stock rims to use them.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 08:47 PM #2
nm_t4r nm_t4r is offline
nm_t4r is on a distinguished road
This is the correct TPMS for the 2018 4Runner and it doesn't look like it is backward compatible.
42607-35040, PMV-C11A - Toyota; 4 Runner; 2018 - 2019 per tpms.com
nm_t4r is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 09:10 PM #3
When I looked at the Tire Rack sight they list part number T3 for both a 2014 and a 2018. Can it be determined by a tire shop if the sensors will work before the tires are mounted? I hate to get the tires mounted with the 2018 sensors then have to remove the sensors. Would any of you reuse 7 year old sensors from my 2014? I really want to leave them on the stock 20" wheels and tires.
If I buy new sensors would you only use OEM? I plan to run this 4runner for several more years and then maybe get a 6th gen if they ever come out.
Old 03-18-2021, 10:22 PM #4
A tire shop may be able to help more than I can. I would probably not reuse the 7 year old sensors, expecting they are probably near end of life. I found a good deal on ebay for OEM sensors when I put TRD Offroad wheels on my 2018 Limited. Note: the OEM sensors as Pacific branded, like the one's tpms.com advertises. I think I paid about $30 each for 5.
Old 03-19-2021, 04:09 PM #5
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
you will not believe my 2005 4runner still have the original tpms sensor. 2 of them are showing low battery when i scanned it. it's been there for 15 years. it should last probably more than 5 years.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 04:12 PM #6
try to use the one for 2018 wheels. it should work. on your 2014 4runner, do you see each wheels tire pressure in the dash?
Old 03-19-2021, 05:45 PM #7
ESS4RNR ESS4RNR is offline
ESS4RNR is on a distinguished road
For what it's worth I replaced the original 4 out 5 TPMS on my 2005 Limited last year (2020). At 150K miles and 3 sets of new tires over the years I was amazed out how long the original OEM's lasted. I purchased my new sets of tires from Discount tire and each time asked them to check and advise if I needed new TPMS'. It wasn't until last year when I was getting the TPMS warning dash light and I knew air pressure was fine that I replaced the sensors before selling the 05.
ESS4RNR is offline   Reply With QuoteReply With Quote
life , sensors , tpms , trail , work
Ignition Coil life span? Mudeprived 3rd gen T4Rs 10 01-17-2022 01:24 PM
Total Chaos Upper Control ARMS - Life Span bzettler83 4th Gen T4Rs 3 07-23-2018 06:28 PM
4runner life span ? Thoughts anyone ? Mellemel 3rd gen T4Rs 8 03-25-2015 10:09 PM
Life span of new suspension? Cow_doc.308 3rd gen T4Rs 5 10-11-2013 03:59 PM
Bilstein life span 004Gunner 3rd gen T4Rs 0 12-24-2010 03:02 AM
