Old 03-22-2021, 05:13 PM #16
Bonniem's Avatar
Bonniem Bonniem is offline
Bonniem is on a distinguished road
Bonniem's Avatar
If the bolt worn out, I can replace it. but what if the bracket
Bonniem is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 05:25 PM #17
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
If the bracket is slightly worn and the bearing surface still smooth, consider taking up the slack using a thin washer on the bolt head side. First step, identify what part(s) are either worn and/or out of spec. Then decide the best means to repair. What is the gap? 0.010 ins? 0.020 ins? More? One side? Both sides? Must also verify bolt and bracket threads are still OK.
DougR is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 05:58 PM #18
Bonniem's Avatar
Bonniem's Avatar
Got it, Thanks again.
Old 03-24-2021, 02:44 PM #19
Bonniem's Avatar
Bonniem's Avatar
Originally Posted by DougR View Post
The length of the lower bushing sleeve has to be the same as a stock shock because your shock uses the same mounting hardware.
If your shock has been loose for a long time, there's a chance the mounting hardware (bolt or bracket) is now worn and you may have the same issue with any set of new shocks.
If the noise is coming from one side only, then compare measurements of one side to the other. A short bushing sleeve on the noisy side coupled with minimal wear everywhere else identifies the root cause and offers you two options, (1) add a thin washer or (2) replace the shocks. I would add a thin washer to the noisy side.
If all dimensions are good, then it's likely the mounting bolt doesn't bear tightly against the bushing sleeve. You'll have the same issue with any brand of new shocks.
DougR what do you think, the numbers are pretty much the same. While removing the shocks i noticed they were over tighten. I didn’t use a washer as you suggest could not find the right size. Will do it on the weekend. But still should I go with washer or go with full shocks replacement.
clunking noise in the rear end-eae89292-8d37-4f22-8921-b61c2cd42f18-jpg  clunking noise in the rear end-1a51ed12-ae09-443b-b415-47915dd8516e-jpg  clunking noise in the rear end-582f569a-48a9-4fc6-8473-96a3b3f92cb5-jpg  clunking noise in the rear end-76748384-609e-48dd-a5e0-183f2be40c93-jpeg
Old 03-24-2021, 02:57 PM #20
Bonniem's Avatar
Bonniem's Avatar
Nice what? Bad shocks or numbers)
Old 03-24-2021, 04:38 PM #21
DougR's Avatar
DougR's Avatar
Your ID and OD measurements on the bushing sleeve look good. Clearance is needed so that the shock can be removed when rust is present.
If the shock bushing sleeve was tightly clamped, I would have expected less rust on the clamped ends of the sleeve. Looking at the photos, it appears there is no clamping force on the passenger side and light clamping force on the drivers side. I suspect the passenger side was clunking and drivers side either less clunking or not clunking at all.
Measure overall length of the shock bushing metal sleeves. The sleeves on my shocks measure 1.785 inches.
Use the depth rod to measure the length of the shank on which shock is mounted. This measurement should be a little bit less than the bushing sleeve overall length in order to produce a clamping force on the bushing sleeve.
Post images of both shock mount bolts showing the portions that clamp against the shock bushing sleeve. I want to see how the load bearing surfaces are machined. When the bolt is tightened, the clamping surface must bear down on the shock bushing sleeve, and not touch the shock mount shank.
Post photos of the shock mount shanks, focusing on the area of the differential bracket, to see if there is excessive wear on the clamping surfaces in that location.
Old 03-24-2021, 06:25 PM #22
Bonniem's Avatar
Bonniem's Avatar
DougR, I just updated my photos as they were taken not to confuse you. The first 4 pics I took while working on driver side. Than mounted everything back and start passenger side another 4 pics, Just don’t want to confuse you with readings. But the loose shock was at the driver side.
Will take more measurements tomorrow.
Thanks
clunking noise in the rear end-79c63f6b-55c1-4302-9f8f-046cd97923e2-jpeg  clunking noise in the rear end-0f9dc9be-7909-4028-a1ee-70f5bf9916f1-jpg  clunking noise in the rear end-737e1835-97f8-41a2-8dc3-feb5e8550e6d-jpg  clunking noise in the rear end-ff0266c5-58da-4da8-b86f-91841ff1f8e1-jpg  clunking noise in the rear end-75c9d635-5489-4896-afe7-f0412f9bdebc-jpg  clunking noise in the rear end-74946165-a2b1-4e5b-a575-9396b09b3dca-jpg  clunking noise in the rear end-03b3b52d-2947-4f5a-9d74-bdb1e47ddac2-jpg  clunking noise in the rear end-d0dc4a3e-a948-4868-8a63-5ecb0c4c76ec-jpg
Old 03-24-2021, 06:27 PM #23
Bonniem's Avatar
Bonniem's Avatar
Thanks
I did measurements on both sides of the shock as pictured
Old 03-25-2021, 05:12 PM #24
Bonniem's Avatar
Bonniem's Avatar
I’ve got some new pics today. I also rotate the driver shock and test drove again and notice less clunking nose but it was still there. I tried washer it helps a little bit but did not fixed the problem. I’m feeling new shock will be next
clunking noise in the rear end-5388e9bf-24cf-422e-9147-8d81b155a8ce-jpg  clunking noise in the rear end-47ef5b5f-4efd-4190-844a-f4269ec26d53-jpg  clunking noise in the rear end-bb627272-6f82-41cb-9c94-76af52c3d733-jpg  clunking noise in the rear end-f1796333-b537-4659-aa9a-ec4b592c0da1-jpg  clunking noise in the rear end-eb188300-aafb-46d7-9d76-64db1de65218-jpg  clunking noise in the rear end-ff791b64-8a51-4f40-a899-8cdf364ed350-jpg  clunking noise in the rear end-989a2dbc-c72a-4746-97ed-dc8b1b341062-jpg  clunking noise in the rear end-1b742505-9181-48c3-b128-7087abd0fe05-jpg
Old 03-25-2021, 05:15 PM #25
Bonniem's Avatar
Bonniem's Avatar
Some more
clunking noise in the rear end-088c90b9-abbe-47be-85eb-5b330f49698c-jpeg  clunking noise in the rear end-43238d26-98fc-43de-a84d-f13cdac81ae6-jpg  clunking noise in the rear end-63be941e-a5f0-412f-8412-853d96293501-jpg  clunking noise in the rear end-fc621245-747c-47d6-a1ed-69ff491c50a5-jpg  clunking noise in the rear end-e3a3a2c6-e954-4db0-96ec-deaabc1cf2da-jpg  clunking noise in the rear end-4553c25c-0273-4d49-9323-ad333f0cad0c-jpg  clunking noise in the rear end-6582aa2e-b059-4720-85ab-2515b6e4f579-jpg  clunking noise in the rear end-a938aa2d-8416-4f74-af72-0cc5e2978071-jpg
Old 03-25-2021, 07:19 PM #26
DougR's Avatar
DougR's Avatar
The noise occurs because the shock bushing sleeve is not long enough. Clearance is about 0.022 inches, which is enough to cause a rattle. I'm wondering if the clunking sound began shortly after the shocks were installed. How long have you had the shocks?
This is how I would fix it. Make two washers out of stainless steel shim stock, 0.025 ins thick. Inner diameter 0.75 inches. Outer diameter 1.250 ins. Shim stock could be up to 0.030 thick. It has to be thick enough so that the retaining bolt contacts the shock bushing sleeve and exerts an axial load.
Install as follows: First, shim washers on the shank, followed by the shock and then the retaining bolt.
Old 03-25-2021, 07:53 PM #27
Bonniem's Avatar
Bonniem's Avatar
I have these shocks for a little over 2 years and drove like 15000 mile with a few not crazy off road trips that all. I noticed clunking about 1 or 2 month’s ago and didn’t pay much attention to it.
Old 03-25-2021, 08:02 PM #28
Bonniem's Avatar
Bonniem's Avatar
I will still disassemble one shock at the time and drive the truck to make sure it’s really related to bottom shock mountings and than do as you recommend.
Thanks
Old 03-25-2021, 08:27 PM #29
DougR's Avatar
DougR's Avatar
Thanks
Yes, that would be a reasonable action.
After you identify short sleeves as the root cause of the clunking, you could attempt to make a warranty claim on the basis of a manufacturing defect. The 1.766 and 1.769 measurements along with a link to the YouTube video may be acceptable to Bilstein to authorize replacement. Tell them a stock shock measures 1.785 ins. Did you buy the shocks and install them yourself? If a shop installed them, then the shop would have to evaluate the shocks and make a warranty claim.
Bilstein will have to look up the minimum to maximum dimension and verify that your sleeves are out of spec and the part number is correct for your application. Here's a link to Bilstein warranty claims Warranty - BILSTEIN
The warranty is 5 years. I think Bilstein or the shop will want a copy of your receipt to verify the correct shock part number was installed. It would be interesting to have their thoughts on this issue even if they deny a claim.
I'm still wondering why 2 years elapsed without the shocks making noise. I cannot move my Bilstein shocks because they are tightly clamped on the bushing sleeve by the retaining bolts. If a shop installed the shocks, perhaps they noticed the gap and installed something to take up the slack and it wore out and fell off? Did you install the shocks?
Old 03-25-2021, 09:34 PM #30
Bonniem's Avatar
Bonniem's Avatar
Me and buddy did the shocks, I can only blame ourselves. Does it matter which side of the bottom shock goes on a sleeve first or it doesn’t matter.
clunking , good , link , noise , suspected
Clunking noise from rear end, trac bar makes noise when tapped with mallet thegipper 3rd gen T4Rs 2 04-18-2016 09:54 PM
"Clunking" noise from rear after lift install Mulky 3rd gen T4Rs 22 01-24-2015 06:05 PM
Rear Clunking Noise 123preston123 3rd gen T4Rs 6 10-02-2014 11:37 PM
clunking noise? acr_ted 3rd gen T4Rs 4 09-10-2014 11:18 PM
Clunking noise sdhobbs 5th gen T4Rs 9 07-24-2014 11:45 PM
