03-22-2021, 09:15 AM
Skid plates
Does SR5 has the same skid plates as TRD offroad(not Pro)?
Or SR5 has just plastic crap?
I mean if I go with SR5 do I need to factor in price of the skid plates, or they are standard and installed already?
Thanks!
03-22-2021, 10:27 AM
Thanks!
The SR5 comes with skid plates on the front (engine), transmission, transfer case and fuel tank. They are steel, but rather thin.
The best skid plate for the front is the Toyota TRD skid plate for it goes up higher in the front, nearly to the bottom of the front bumper.
For the rest, RCI makes a good skid plates. 2010 – 2021 4Runner – RCI Off Road
Also CBI: CBI Offroad Fab - Toyota 4Runner Full Skid Plates | 2010-2020 -
03-22-2021, 10:32 AM
Thanks!
If you're planning on taking it off road and want to protect it from getting thrashed, I would budget for skid plates regardless of which trim level you buy, including the TRD Off Road and Pro. The oem on mine were just stamped metal. I think the total weight including the gas tank skid was less than 50 lbs.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
03-22-2021, 10:39 AM
have you seen any lifestyle overland videos? Kevin's running the stock skid plates in those, yeah they are stamped metal but they aren't worthless.
03-22-2021, 11:01 AM
Real Name: Shawn (F) & Alex (M)
This ^^^ The stock TRD skid is okay for most people's scenarios but if you do get into true wheeling you'll want the added piece of mind of some 3/16" steel (or 1/4" aluminum) down there. As stated above RCI makes some good skids. C4, LFD are a couple others to mention as well.
2018 SR5P. 3" OME Lift 885/898 springs, JBA SD Highcaster UCAs, 17x8.5 SCS BR6 Matte Bronze, 285/70 Falken Wildpeaks, Victory Blitz Bumper w/high clearance, RSG Angled Sliders, C4 full skids, GOBI Ranger, Wilco Offroad Classic, VOSwitch UV800, lights and other misc. goodies... @HER_RNR
03-22-2021, 04:32 PM
Are they the same as TRD Offroad (or Trail in early 5Gen) I Understand TRD Pro is different I don't think I need that.
03-22-2021, 04:38 PM
Real Name: Chris
Real Name: Chris
They are the same skids on all of the models except for the front TRD Stamped aluminum skid on TRD Off-Road and Pro. On the SR5 and Limited you get 1/8" Front (engine) steel skid (same thickness as the rest of the OEM skids). Unless you will be immediately rock crawling, your best bet is to beat the OEM skids into submission and then upgrade (they do work). You're better off spending the skid $ on rock sliders instead IMO. None of the trucks from factory come with rocker protection, just side steps that = damage multipliers.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
03-22-2021, 05:02 PM
Yes, the SR5 and the TRD Off road have the same metal skids. The OEM skids are just fine. Sliders area better first armor choice, IMHO. For aftermarket, I like RCI's raw aluminum skid. I used the stock skids on two 4runners and got an RCI for the low 4th gen.
The stock "skid plates" are in two pieces. Most after market skid plates replace both stock pieces with one piece. Sometimes its nice and easy to have them separate. Stock skids are easier to remove for some people. The front skid needs to be remove to change the oil filter. The "other/2nd piece" stock skid plate has a removable plate to access the oil drain. The second stock skid plate usually doesn't need to be removed for oil service. I let the front one hang, instead of removing it when I need to access the filter cartridge.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
03-22-2021, 07:01 PM
I'm pretty sure he upgraded to better skids! Watch some of the more recent videos.
03-22-2021, 07:10 PM
If you are getting skids, do yourself a favor and skip the TRD Pro skid and just get the whole set from RCI, including the front.
The TRD Pro skid needs to be removed every oil change which is a hassle. Further, it's incredibly easy to strip the bolts that hold the damn thing on and then you have a bigger problem on your hands. Search for "TRD Skid Plate stripped" on this forum and you will see what I mean.
The RCI front skid has a nice little door to get the oil filter out so you don't have to take off the entire skid. So much better.
And unless you are doing real rock hopping, the aluminum is plenty. I've dragged my all over rocks and stumps and they work as intended.
03-22-2021, 09:13 PM
I can’t imagine investing that much time and effort into a 4R and not putting skid plates on it.
03-23-2021, 02:15 AM
I agree, but for those who live in places where off roading is mostly on soft soils, clays, grasslands, etc, the oem stamped metal skids might be adequate. Venturing out into places like the desert southwest with all the sharp limestone and caliche will chew them up rather quickly. I wouldn't even drive around the vacant lots in my neighborhood with those skids.
03-23-2021, 11:15 AM
Im going on 5 years of trails in CO, UT & WY and my factory skids are in great shape with scratches + rust. They are perfectly adequate for most 5th gen drivers out there.
To each their own but my build is light and efficient. With only mods Ive gone out on trips/trails to realize I need. You may have realized that you need them but trying to convince others that they cant drive almost every track out there without them is just bad advice.
03-23-2021, 04:40 PM
I'm not trying to convince anyone of anything. OP asked for opinions. As I said it depends on terrain.
You say factory skids are just fine on "almost every track out there." Sorry, totally disagree. It doesn't rain here often but when it does we get a lot of flash flooding, since the water doesn't permeate the soil. Even easy trails can get washed out and have plenty of nasty areas. It's just good insurance to have real armor even if you do your best to avoid the nasty spots. But hey, if oem works for you that's great.
03-25-2021, 08:14 AM
only after years and tens of thousands of miles offroading
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
