11-29-2016, 03:57 AM
Just bought an SSO Hybrid.. Which Winch?
Well I finally got my arm twisted enough with a sale to pick up an SSO Slimline Hybrid for my 2016 TEP but now I'm at a roadblock with winches.
I don't want to make this into a Warn vs the world thread and the purpose of this thread is to see what you guys are running and how much "clocking" or fab work it took to get there. Also your mount set up for the control box.
I was an avid FJC guy for many years and always ran a Warn M8000 w/Viking synthetic line. Never had an issue and would run it again (the FJC with bumpers skids, tires, racks and lights was heavy little truck) but might upgrade to a 9.5 for a little more ease of mind.
What are you guys running behind your SSO's and how do you like it? I've got a set of BP51's and JBA UCA's enroute so weight wise I'm thinking it should only be around 150#s total up front. Might add some skids too since I'm under the truck....
Miss the old FJC, but a 4Runner build should be fun!
11-29-2016, 05:08 AM
I am just tagging this post because I too have the exact same question
2016 Trail w/KDSS Metallic Black, OME BP-51 Heavy, CBI rear-bumper, ARB Summit front bumper, Warn Zeon 8s, ICON Delta UCAs, Dobinson drawers, and more scratches than I care to see
11-29-2016, 06:59 AM
Real Name: Nick
Real Name: Nick
I installed that bumper about 2 months ago. It looks great. I bought the Smittybuilt X-something 10k lb winch that SSO carries. It fit very easily. I had to mount the solenoid off the side with the included hardware, but didn't really have to modify anything.
I haven't had to use the winch yet, so no comment on its performance. Fit was great though. Also, the lower bumper cover is an ABSOLUTELY PERFECT template for cutting the bumper. Cut with confidence.
11-29-2016, 09:11 AM
Real Name: Kevin
Real Name: Kevin
Warn Zeon S-10 in my SSS bumper with a synthetic line......it mounted really nice with no extra mods!...I like the remote clutch...you do not have to manually engage or disengage it!...There are no holes needed for your hands in the radiator shroud!
White 2015 4Runner Trail premium, Black Trd wheels, Bfg ko2's.....Shrockworks sliders!....SSS winch mount bumper and Warn Zeon S-10 Platinum winch....OME BP-51 Suspension installed with 889 Springs in the rear/TC UCA'S....RCI alum skids.....Gobi Stealth roof rack,homemade lockable dual slide drawer storage box...Morimoto 2.0 LED Low beams, OEM Tacoma LED fogs
93 Mazda Rx7, LS1 Chevy powered, 6 speed, converted by myself and 3 sons!.. factory original paint, factory red interior.........lots of fun!
Reason: added more!
11-29-2016, 10:00 AM
Real Name: Charles
Real Name: Charles
Originally Posted by jkd4141
Warn Zeon 10 in my SSS with a synthetic line......it mounted really nice with no extra mods!
This is the route I went although the bumper and winch went to families house for holiday projects so I won't have 1st hand experience till then.
I am not a Warn fan boy by any means and wouldn't be shocked if this was one of those purchases that I love but may have gone a different route if I was doing it again. They appear to be quality winches with good customer service but you do pay 2-3x for that privilege on some of their products.....is it 2-3x as good, I have my doubts but most of the "premium" products you pay a large sum more for a minor gain. I really only think you can answer the question if the Warn or similar units being worth the additional costs to you and if you didn't spend that extra on the winch what would you use it for and weigh it that way.
I would say buy skids before a winch but I guess even that depends on where you spend your time off road
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
11-29-2016, 07:28 PM
This is what I'm thinking will be my finished product. I've heard good things on the Zeno series and was tempted to try a ComeUp but there's just not enough information for me to rely on.
11-29-2016, 09:11 PM
Probably almost every name brand winch today is pretty good. And most 10k winches should fit without much issue. I have a superwinch in a hidden mount and it's physically pretty compact. Fits basically in the same spot. No problem remote mounting just the switching, not the solenoid set. Leave that down on the winch if you want an easy install. Otherwise no mods necessary. Just plug and play. So far very reliable. 10 years ago - warn was the only winch I would even consider. Today I think they've all come a long way from then.
If you do want to move the solenoid set, find one with wires not buss bars. The superwinch has buss bars from the solenoid pack to the motor poles. It would be a bit more difficult to modify to remote mount the entire solenoid set.
11-29-2016, 09:57 PM
I have the exact same question. I missed the sale, but because I bought sliders from SSO instead and want to get a lift at the same time.
I was looking at the same exact winch. How did you mount the solenoid off to the side?
11-30-2016, 02:31 AM
I haven't had time to install mine yet (also need to beef up the front suspension a bit), but I ended up going with the Zeon 10-S platinum. 4Wheelparts had 175 off for black friday, plus warn is running a $200 factory rebate on them through december. Made it hard not to get the bells and whistles for about the same price as the normal 10-S.
I was a bit worried about the remote clutch, but then I noticed that even with a lot of googling I could not find someone that has had an actual problem with it in the last few years since it has been available, so that helped with the confidence.
If you check out the most recent group buy, SSO mentions that the Zeon 10-S, Smittybilt X2O, and the Mean Mother Edge: Southern Style OffRoad Slimline Hybrid for 2014+ 4Runner FALL GROUP BUY 2016
As a side note, I'm also planning on running the power through a blue sea 7713 remote relay. It's rated at 500A continuous, and I'll be able to isolate the winch from an AOB switch in the cab. Won't even need to open the hood
- 2016 Classic Silver TE - Gobi Stealth - SSO Slimline front bumper - Warn Zeon 10S plat - BFG KO2 265's - King 2.5 with SAW 1.5" rears - OPOR Sliders - ICOM 2730 Mobile HAM - Tepui Autana Ruggedized
11-30-2016, 03:30 AM
so you are going to have all this in your build thread. with part numbers, so I can just copy you
11-30-2016, 12:50 PM
The remote clutch on the Zeon 10-S Platinum is a game changer and makes it a perfect pair for this style of bumper. It even has the ability to control an additional 2 12v power sources to turn on whatever your heart desires.
11-30-2016, 01:06 PM
The Zeon Platinum line is just awesome. Upgrade from the 8K-S to the 10K-S Platinum and I don't regret it for a second.
I don't own a 4Runner anymore.
02-22-2017, 02:27 AM
Can you easily access the wireless switch?
I have an SSO bumper on the way, and I'm trying to decide on a winch. Leaning towards a Zeon 10-S Platinum. My understanding is that winch has a green switch on the back to switch the wireless function on/off. The "off" is to limit the parasitic drain if parked for a long period of time. I'd be concerned about draining my battery (depending on current draw) when camping for a few days along with a 50qt fridge.
So here are my questions:
1. With an SSO bumper and the Platinum winch, can you easily reach that green switch? Access by removing the upper radiator cover or some other way? Anyone remote mount that switch (like in the cab)?
2. Does anyone actually use that switch or just leave it on all the time? Anyone know how much current it draws?
Reason: typo
02-22-2017, 07:22 AM
if you are going to use it a lot get the zeon10 if not get an XRC10
____________________________
2015 SR5 w/3rd Row
BRO'd up Grill
2.5/2 5100s F&R, Dobinsons Rear Coils. 275 KO2s (Going 285)
GOBI Stealth, RIGID Radiance, RCI Skids, Alea Leather, Safari Snorkel, ARB Dif Breather
02-22-2017, 09:13 AM
Real Name: Will
Real Name: Will
I can't really be of much help as I've only had the Zeon 10-S and SSO bumper for just over a week. But you can easily reach the green switch with the radiator cover removed or with an access hole cut out.
My plan is to leave the switch engaged as there doesn't seem to be a way to just relocate the switch. There is a small ground wire that you might be able to interrupt and put a disconnect switch in-line. I haven't looked into it though.
Liquidmantis's modest [boring] build thread
2016 MGM TEP w/KDSS | OME BP-51 w/ 2889 rear | SSO Bumper | Warn Zeon 10-S Plat | TRD Pro wheels | BFG K02 275/70/17 | RCI sliders | RCI alu skids | Gobi Stealth No Rise | 1Up USA hitch rack
