Originally Posted by 71gs3504sp
Why install a spacer with Bilstein 5100 up front?
Just set the Bilstein 5100 at top notch to give you 2.5"
Add 1" spacer in back and you will be level.
Do a search and you will see photos how it looks.
First, I have Eibach shocks not Bilsteins. Walked in the shed after posting and had a facepalm moment.
Second you raise a good question. Are front spacers necessary?
My thought was they would compress the spring some adding a little stiffness and with the shock set at the lowest setting I would get more travel.
