Old 04-01-2021, 08:11 AM #16
BarberJoeJr BarberJoeJr is offline
BarberJoeJr is on a distinguished road
Originally Posted by crawlingjunk View Post
i have 2/1 spacer on my 2021 trail and falken at3w tires and it rides great.
Pics ?
Did the 2/1 spacers change the ride on the truck at all ?
BarberJoeJr is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 08:16 AM #17
crawlingjunk's Avatar
crawlingjunk crawlingjunk is offline
crawlingjunk will become famous soon enough crawlingjunk will become famous soon enough
Originally Posted by BarberJoeJr View Post
Pics ?
The ride quality stayed the same
crawlingjunk is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 08:29 AM #18
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
Originally Posted by Saker View Post
I don’t think it was the tires!
LOL
Lmao 😂
Axix23 is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 08:52 AM #19
NEdude NEdude is offline
NEdude is on a distinguished road
Looks very nice for sure! Did you say in an earlier post which spacers and I missed it? Just curious, not even sure if it matters...
Thanks!
NEdude is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 09:14 AM #20
Garpike42 Garpike42 is offline
Garpike42 is on a distinguished road
That's a great looking rig. Bilsteins maybe with rear springs?
2010 Black TE, TRD Wheels, General Grabber ATX, Bilstein 5100 front, Eibach Pro Truck rear.
Garpike42 is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 09:49 AM #21
Thanks!
Yes 2/1 spacers
Old 04-01-2021, 11:45 AM #22
Yes 2/1 spacers
Ha! Sorry, should have been more clear... Brand/Manufacturer?
Thanks.
Old 04-03-2021, 01:20 AM #23
Skaiz Skaiz is offline
Skaiz is on a distinguished road
Seen a nightshade limited on YouTube that has stock rims with aftermarket tires with a lift.
I am new to 4runners as well off-roading but I have on order a 2021 limited nightshade coming in about a week so I am also doing some research and hope to learn more.
https://youtu.be/ugk_kOTXJp4
Skaiz is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 10:38 AM #24
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
This is my daily driver, so most likely it will spend 95% of its life on pavement.
Thinking a 2" front / 1" spacer lift and some 275/60r/20 tires and I will be good. I know most go with a 275/55r/20 but i figure i could fill in the space better with a 275/60r/20 if I am doing the spacer lift front and rear.
And, if I ever do feel the need to go off roading I have this in the garage...
Yokohama makes both a highway tire and an A/T tire in 275/60r20. The A/T tire is pretty quiet, and I have been very happy with it. If you will be almost always on pavement, you can get the highway tire.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 08:15 PM #25
https://www.youtube.com/watch?v=ugk_kOTXJp4&feature=youtu.be
Thanks for posting.
I watched that video and he is running (from what he said) 2" leveling kit front and back with a 265/60r/20 tire. I plan to run a 2' front / 1" rear Cornfed leveling setup with a Nitto Ridge Grappler LT275/60r/20E tire (I think)..
Old 04-05-2021, 10:43 AM #26
4runner2021 4runner2021 is offline
4runner2021 is on a distinguished road
The problem is that most tire shops will not install the 265/60r/20 on the nighshade stock rim/wheel that is only 7" wide. The recommended wheel width for the tires in the video is 8.0-9.5"
4runner2021 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 04:11 PM #27
But they will install a 275 ?
Correct me as I may be wrong but isn't a 275 wider then a 265 ?
Old 04-05-2021, 04:35 PM #28
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Are you going to remove the XREAS so you can lift/level? If you keep XREAS you need to use spacers. It may be possible to level/lift with springs on XREAS but those lines make it nearly impossible. 2/1 cornfed spacers and 275/55/20 all terrain KOs is my vote. Here's a pick of my stock xreas and springs with TRD rims and KO2s 265/70/17. I enjoy the xreas on the street. Im also a fan of duratracs
2021 Limited Nightshade: Looking to do a leveling kit and some larger tires-rims3-jpg
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 04:43 PM #29
This truck is 99% street / on road use so not too worried about off road. So yes, I plan to keep the XREAS.
I purchased the 2'/1" spacers from CornFed already . Just need to figure out what tires and size I want and I will go get it installed.
I was thinking to order a 275/60/20 over a 275/50/20 to gain alittle sidewall and fill up the added room in the wheel wells the lift will give. Maybe i am wrong in this thinking ?
Old 04-05-2021, 05:11 PM #30
Will 275/60/20 rub with the lift is the $100 question. I think most of the rubbing is on the front splash guard due to the width of the tire. Rubbing occurs at full lock in reverse. Its minor and doesn't bother some people. So the lift wont necessary eliminate that rub spot. I guess a 275/60/20 will rub on the front splash guard even with a lift. Hope someone with direct experience with 275/60/20s can help. Beauty is in the eye of the beholder, I like a little space in the wheel wheel and would get a shorter tire. Plus, a shorter tire helps with gearing and shifting/powerband, mpgs and speedometer accuracy. Short tires do not help with the potholes on Irving Park road, assuming they are still there, haha.
Discount Tire in Downers Grove put 275/55/20s on a buddy's limited. They may have been 275/50/20 but I think they're were 275/55/20?
Sweet hummer, Ive seen them in action. Amazing!
1999 4runner
kit , leveling , limited , nightshade , search
Leveling kit, safety and tire size and rubbing on 4runner 2021 Jtorral 5th gen T4Rs 13 06-08-2021 05:05 PM
Mud guards for 2021 Nightshade with running boards? Tedward 6th gen T4Rs 4 06-03-2021 09:20 PM
2021 TRD Pro leveling? jrcmlc 5th gen T4Rs 5 01-03-2021 11:31 PM
Can I go with larger tires with wheel spacers and front leveling? GreenRoomVision 4th Gen T4Rs 5 11-14-2016 10:47 PM
