Old 03-28-2021, 08:34 PM #1
jayb52 jayb52 is offline
jayb52 is on a distinguished road
Adding usb ports up front
Has anyone ever swapped out there 12 volt power ports to a factory style usb port? I have having the little plug in adapters, they always break on me.
jayb52 is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 09:15 PM #2
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
Here are two options
Amazon.com: Cllena Quick Charge 3.0 Dual USB Port Charger Socket for Toyota
Amazon.com: YONHAN Quick Charge 3.0 Dual USB Car Charger with Switch, Waterproof 36W 12V USB Outlet Fast Charger Power Outlet for Marine Boat Motorcycle Truck Golf Cart and More: Automotive
Grape Ape is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 11:31 PM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I bought this gauge/jack on Amazon. Installation was pretty straightforward. I don’t know if it will fit in a 5th gen, but I’m sure Amazon will have one that does.
Adding usb ports up front-8e7c4102-e266-4bc8-830b-20486387bce9-jpg
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 10:50 AM #4
PhillySilver PhillySilver is offline
PhillySilver is on a distinguished road
You don't say what year your rig is but if you are looking to replace the Carplay port in the bottom of the center stack, be aware they changed the size for 2020. I have not been able to find a replacement that fits the factory opening as that mod is on my list.
PhillySilver is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 03:43 PM #5
Michael-Dallas Michael-Dallas is offline
Michael-Dallas is on a distinguished road
I have this one for my 2018. It has connectors to tie into the 12v cig port wiring, so no wire splicing necessary.
Amazon.com: MICTUNING Dual USB 6.4A QC3.0 Quick Charger with LED Light Replacement for Toyota (Surface Size 1.3 x 0.9 inches): Home Audio & Theater
Michael-Dallas is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 09:16 AM #6
Brandonium's Avatar
Brandonium Brandonium is offline
Real Name: Brandon
Brandonium will become famous soon enough
Brandonium's Avatar
Real Name: Brandon
I see this pulls power from the 12v port but does it also retain data connectivity to the head unit? If not then I see it as being useless as I also need to retain data to the head unit.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
Brandonium is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 09:35 AM #7
osugsxr osugsxr is offline
the new head unit should have a connection for the usb ,could probably use existing one as well. Pending how the retrofit is connected Id assume it would use existing
Old 05-13-2022, 10:00 AM #8
Brandonium's Avatar
Real Name: Brandon
Brandonium's Avatar
Real Name: Brandon
Well here is what I am trying to do. I would like to switch to dual port usb where the power port is and move the usb connection to the glovebox as that is where my android auto wireless dongle will stay connected to the head unit. I was thinking of using the dual port I commented on but losing data to that port is a no go and the stock spot in the center stack that has the current USB to head unit connection will be used for TPMS readout.
Old 05-13-2022, 10:34 AM #9
I think you should be able splice the wiring and run your own wires and hook it up that way.
Old 05-13-2022, 11:30 AM #10
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
If you haven't already done this as others suggested consider this.
I like to avoid as many mods as possible to minimize issues down the road.
I used this 12V adapter which provides two USB port with a digital voltage meter that way I you can keep an eye on your battery and charging voltage. It works great for me and looks good too. Leave the 12V OEM for things in the future you might want it for - never know what you might need that for.
AINOPE Car Charger Adapter, Dual QC3.0 Port 6A/36W Fast USB Car Charger All Metal Cigarette Lighter USB Charger Voltage Display Compatible with 11/11 pro/XR/X/XS/8, Galaxy Note 8/S9/S10+/S8-Black : Cell Phones & Accessories
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 05-14-2022, 05:43 AM #11
NautyBruiser19 NautyBruiser19 is offline
NautyBruiser19 will become famous soon enough
This is exactly what I did. I ordered the following Toyota part from one of my local Toyota dealerships: PT976-03201. From what I understand, this part is a factory option only in the gulf states region. It was a direct plug-in and glows blue when the ignition is on. Very happy with it!
I also moved the factory USB/AUX. port to the glove box, and now have an aftermarket switch in its place (soon to be changed to a RJ45 port for a GMRS radio microphone).
-2019 Nautical Blue ORP
NautyBruiser19 is offline   Reply With QuoteReply With Quote
Old 05-14-2022, 08:23 AM #12
did this just replace the factory usb one, would be useful for road trips. Only time I've used the 12v lighter is for a tire inflator
one below replaces factory usb outlet to make it a dual charger.
https://www.youtube.com/watch?v=CNl8hgvbZYE
Old 05-14-2022, 02:58 PM #13
Lifeline's Avatar
Lifeline Lifeline is offline
Lifeline is on a distinguished road
Lifeline's Avatar
Does this just replace the OEM cigarette lighter? If so, that’s awesome.
Lifeline is offline   Reply With QuoteReply With Quote
Old 05-14-2022, 09:07 PM #14
Every Toyota 4Runner NEEDS THIS Dual USB Port Quick Charger Socket 3.2 Amps Quick Charge Your Phone - YouTube
It replaces the 12v cigarette lighter port and doesn't affect the factory USB/AUX port at all.
Old 05-14-2022, 09:18 PM #15
Yup, gets rid of the 12v lighter port! I just took some pictures so everyone can see what it looks like:
Adding usb ports up front-usb1-jpg  Adding usb ports up front-usb2-jpg  Adding usb ports up front-usb3-jpg
adapters , adding , break , ports , usb
Adding USB ports to '12 4Runner trail ltsatch 5th gen T4Rs 15 05-03-2020 12:28 PM
No 12V power to front and rear ports tystaco 3rd gen T4Rs 3 10-16-2017 10:58 AM
Adding USB charging ports ZionXIX 3rd gen T4Rs 22 11-11-2016 11:56 PM
Adding front compononets to my 05 SR5??? kickinasphalt Engines / Suspension / Wheels / Tires / Audio / Accessories 16 01-23-2007 03:18 PM
Adding a front end skid plate to my new 06 SE orangeblast22 Off-Roading 3 12-29-2005 11:58 AM
