Old 04-15-2021, 11:48 AM #16
alphabeast's Avatar
alphabeast alphabeast is offline
Real Name: Shawn
alphabeast is on a distinguished road
alphabeast's Avatar
Real Name: Shawn
Originally Posted by lawn_gnome View Post
This isn't my area of expertise, but I watched this video a while ago, I thought it might help answer some questions. Or maybe not, who knows. It is for Tacomas/4runners.
What to do When You Break Your CV or Tie Rod Off Road
Awesome video! But I have to laugh at how easy that tie rod end came off with just one tap of a hammer....
2014 TE w/ KDSS: ToyTec BOSS Suspension Kit / Toytec 1" Body Lift / JBA A-Arm's / Cooper Evolution MT 35" 12.5" / SCS Ray 10 17 X 9 / Budbuilt Bump Out Slider's / Gobi Stealth (No Rise) Rack / Hefty Fabworks Front Bumper / Ellis Precision Auto Shifter & Transfer Case Shifter/ Rigid D-Series LED Fogs / Precision LED Interior Lighting
alphabeast is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 12:02 PM #17
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
Originally Posted by cbielat View Post
What exactly broke? Or was it just a torn cv boot?
the outer/wheel side joint shattered and threw the balls everywhere. I was offroading in Moab and trying to get past a very difficult obstacle. I was very stuck, was giving it gentle throttle, it started to move, so I got optimistic and gave it more throttle. = broken axle.
a lot of responders apparently haven't read the OP or my follow-ups, but... I drove 45 miles of legit gnarly offroading and then 70 miles of pavement with the axle broken. The axle was still together, it just didn't have the balls in it to drive the wheel, so it just spun inside the joint. It was fine. I bought a new one from Oreillys and threw it in on the sidewalk. It has more play in it than the OEM one did, which is annoying, but it's fine. I've driven at least 2k miles on the Oreillys one with no issues.
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 01:02 PM #18
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Did you have Atrac or other systems on when the CV grenaded?
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 01:57 PM #19
It was in 4 low. I had the rear diff lock on. I probably had A trac on because I was really stuck, but I don't remember.
Old 04-15-2021, 03:30 PM #20
cbielat's Avatar
cbielat cbielat is offline
Real Name: Chris
cbielat has a spectacular aura about cbielat has a spectacular aura about
cbielat's Avatar
Real Name: Chris
Sounds good. Yeah, definitely keep extra parts on hand. Easy enough to switch it out.
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
cbielat is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 05:18 PM #21
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
FWIW - the common wisdom is that the aftermarket ones use inferior metalurgy and are more prone to breaking in the future. So if you can - I'd consider either swapping it back to an OEM one or buying an OEM as a spare so the next time you can change back to OEM. Unless you want to spend $$$ on RCI CVs. They're pretty robust, so it's unusual to see them broken.
The other spare part I'd consider having if you spend a lot of time in rocks is a rear drive shaft. It's a low point that tends to get a lot of rock time on mine. Haven't broken one yet - but it's pretty exposed. Moab trails aren't so bad. Other places with more boulder type rocks tend to be more prone to taking out a drive shaft.
Old 04-15-2021, 06:14 PM #22
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
If you get an RCV be careful. They may be strong enough that you move the failure point to inside the diff or ADD. I read a thread on Tacoma World where a guy blew up his ADD housing when using an RCV CV.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 06:24 PM #23
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I stumbled across a new OEM CV shaft on Facebook marketplace for $50.
I hope I never need it.
patkelly4370 is offline   Reply With QuoteReply With Quote
drive , leave , side , specific , wheel
Half C & half E load rating - ooops noisebeam Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-04-2015 05:25 PM
TJM Xray Driving Light - 220mm QH Driving zooroadbaja For Sale: Non-T4R Items 1 05-16-2013 09:35 PM
Half Denso Half NGK NWSKIUrbanRunner 4th Gen T4Rs 6 11-09-2011 11:15 PM
Driving around with half a lift kit AF808fighter 3rd gen T4Rs 1 02-17-2008 08:13 PM
