Old 03-28-2021, 11:30 PM #1
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
driving with half a CV?
yo. So I broke my driver side CV joint offroading here in Moab. I then drove the 60+ miles out of the remote canyon I was in with no issues. just kept it in 2wd, and put in 4x3 only if I got really stuck. Is it possible to pull the diff side of the CV axle and leave the wheel side and drive like that? I know you can do it on some older trucks, but you have to leave the wheel end attached or the wheel bearing will fall apart and you'll lose your wheel going down the road.
anything specific to 5th gens that will make this not work?
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 09:46 AM #2
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
if you broke the cv, why not just cut it very close to the hub so it can still be driven. having a picture would be better though.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 09:59 AM #3
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
If you pull the CV axle out of the front differential, you will loose oil from the differential and get dirt into it. Could ruin the differential.
"4X3" as you call it, will not really work that way unless you have a front differential lock. I thought only the Off Road and Pro had differential lock, but only on the rear, but I could be wrong.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 10:03 AM #4
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
Now I've only helped 4Runner/Tacoma friends so my memory might be a bit rusty, but isn't the diff side of the CV axle splined into the diff? If so, then leaving it a gaping hole might allow dirt and grime to get in along with fluid out.
I'm curious as well in a trail fix like you're looking for.
EDIT: I was too slow, someone said the same thing above me.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 04:24 PM #5
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I assume you mean gutting the tulip out of the cup on the differential side and leaving the cup portion still splined into the axle?
That's doable. But as stated earlier, you'll want to cut the axle near the hub end because you need that to keep the bearing together and pre-loaded. I would not recommend the old "washers and a big bolt" method for anything other than towing/driving a vehicle across the parking lot.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 07:58 PM #6
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
What part broke? Did you blow up the bell - outer or inner?, snap the shaft?, or snap the inner star? If you have complete outer bell or enough left to hold the wheel bearing together, you could remove the shaft from the inner joint leaving only the bell in place on the inner (differential) side and the remains of the broken bell on the outer (wheel bearing/hub) side.
You could drive that way as long as you don't try to run at speed in 4wd. If you do the loose inner bell will wobble unbalanced and cause problem. I don't think it'll be an issue in 2wd at all. It shouldn't spin at all in that situation, even at highway speed.
But if you're going to strip it all apart somewhere in Moab - I think you can find a spare axle at a parts store. If you really need it - I have a couple spare axles in SLC area. I'll loan you one and you can send it back when you swap it out to a new one. I'm not sure how I'd get them to you though. I don't plan to go down to Moab until sometime late april.
Jetboy is online now   Reply With QuoteReply With Quote
Old 04-13-2021, 01:24 PM #7
fwiw I found a replacement at oreillys for $125 and swapped it in. it's noisier than the OEM one, so I'd like to swap it back to OEM or an upgraded one sooner than later.
Old 04-13-2021, 05:03 PM #8
So hypothetical here, let's say a CV grenaded itself. Tore the inner and outer bells or something.
If we kept a spare inner/outer bell with us that we could just pop into the hub/diff that would help hold the hub bearing together and keep fluid from gushing from the diff.
But nothing's holding them in right? Differential might not spin, but would the hub bell?
Just curious as a possible trail spare/bandaid idea.
Old 04-13-2021, 11:19 PM #9
Jetboy's Avatar
Jetboy's Avatar
Basically, yeah it should work. The inner side has a snap ring that will keep it in place. The outer has hub bolt. The only thing you can't do like that is go fast in 4x4 or do this at speed in a limited. The free bell in the diff at highway speed will probably wobble enough to cause problems. The little needle bearing isn't enough to stabilize it if it's unbalanced.
But... It you're going to carry those parts - might as well just keep a full spare axle assembly. They're not very expensive. I have a couple, but never needed to use them. They're the same on both sides, so one spare covers either side failure. I only have 2 because I had a cheap aftermarket one and then picked up an oem ones later. But even the $50 aftermarket one would be fine to get off the trail.
Old 04-14-2021, 01:36 AM #10
lawn_gnome lawn_gnome is offline
lawn_gnome is on a distinguished road
This isn't my area of expertise, but I watched this video a while ago, I thought it might help answer some questions. Or maybe not, who knows. It is for Tacomas/4runners.
What to do When You Break Your CV or Tie Rod Off Road
lawn_gnome is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 02:01 PM #11
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
That is a cool video.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 03:27 PM #12
Unretired Unretired is offline
Real Name: Terry
Unretired will become famous soon enough Unretired will become famous soon enough
Real Name: Terry
Don't Need a Spare CV - Need a Spare Tie Rod
Cost, size/weight, mess and the ability to limp out on 1/2 a CV is why I convinced myself that I don't need a spare CV.
That said - I'm East Coast and generally only a hour+ away from a decent enough fire road at any time.
I am going to start carrying spare tie rods though.
Not too big or messy and I've unknowingly damaged those on a couple solo trips.
Hard to limp out of anything without steering.
2016 SR5 - Wildpeak A/T3W 265/70R17SL or BFG K02 C Load 285/70R17; RSG Sliders; LFD Crossbars, Skid Plates & Hybrid Bumper; RCI Skids on Rear Diff, Lower Links & Shock Mounts; Engo SR10S Winch; Dobinson 700/701 IMS with 314/327 Coils +2.25" front +2.5" rear; Goat Armor; Redarc Brake Controller; Camping Hatch Mod; DIY Drawers & Sleeping Platform; Cheap 10" Light Bars in Grill; Front/Rear Camera Mod with Nav Input; Simple Nav/Comms - Garmin inReach Mini, iPad & Motorola FRS.
Unretired is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 11:32 PM #13
PK930's Avatar
PK930 PK930 is offline
PK930 will become famous soon enough
PK930's Avatar
Rip out the shaft itself, or pieces of if you’ve broke it. Shove a rag in either cup and tape it up — or sling grease everywhere. Yes, leave the wheel side in unless you want your tire to fall off.
It’ll get you to safety. I drove about 25 miles at highway speed like that.
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 09:07 AM #14
I agree, this is the right thing to do here. leave the wheel side in and cut the axle closes to the boot to avoid the axle from flapping around. Also, you need to bring a metal saw, the manual one.
Old 04-15-2021, 11:44 AM #15
cbielat's Avatar
cbielat cbielat is offline
Real Name: Chris
cbielat has a spectacular aura about cbielat has a spectacular aura about
cbielat's Avatar
Real Name: Chris
What exactly broke? Or was it just a torn cv boot?
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Long Travel Front, Long Travel Rear and everything in between.
cbielat is offline   Reply With QuoteReply With Quote
drive , leave , side , specific , wheel
Half C & half E load rating - ooops noisebeam Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-04-2015 05:25 PM
TJM Xray Driving Light - 220mm QH Driving zooroadbaja For Sale: Non-T4R Items 1 05-16-2013 09:35 PM
Half Denso Half NGK NWSKIUrbanRunner 4th Gen T4Rs 6 11-09-2011 11:15 PM
Driving around with half a lift kit AF808fighter 3rd gen T4Rs 1 02-17-2008 08:13 PM
