Old 03-29-2021, 03:59 PM #1
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Reversible Routes Through Firewall
There are many threads about running wires through the firewall. The three most common approaches are (1) puncturing a hole in the grommet that takes the main wire loom into the vehicle on the driver's side, (2) drilling a hole in the firewall, or (3) cutting a nipple or two in the grommet that takes some cables in on the passenger side.
The first and second approach then usually bring up trying to re-waterproof with something like silicon, which isn't durable longer-term.
The thing all three of those have in common is they are basically not reversible without significant effort, if at all. So for someone like me that's trying not to do much to the truck that can't easily be undone, not ideal.
There is one hole through the firewall that appears in a few posts and which TRD_John has publicized on YouTube, which is a bit above and to the left of the main wiring bundle on the driver's side (looking from front of vehicle):
I used it to run the cable for my Switch Pros + a battery meter and, save a few knuckles that got cut fishing wires under the dash, it worked well. The best part is if you punch a hole in the plug for the wires (which I did) you can buy a replacement for ~$1 from Toyota and reverse the whole thing in about 10 seconds.
I'd like to run one more wire into the cabin to power some lights in the cargo area. And I'd like them connected to my fuse block ideally since I want to be able to have them on when camping and sleeping in the vehicle, so constant power.
I noticed a second rubber plug on the passenger side, but haven't been able to get a wire through the hole into the passenger footwell area successfully, although I can see where the wires on the bigger grommet below come through in that space.
Has anyone ever successfully used this hole for anything?
I figure that someone must have given in a whirl at some point, so before I start taking apart the passenger side of the interior to see what's possible, I'd ask the community ...
rageandlove is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 12:23 PM #2
No one, eh?
I did find this, so for people that find this thread in the future, here's a second trick if you are running small wire.
https://www.toyota-4runner.org/1168315-post2.html
https://www.toyota-4runner.org/787111-post22.html
I'm looking at a third possibility. If it works I'll dump that here too.
Old 04-05-2021, 02:31 PM #3
PJSnow's Avatar
PJSnow PJSnow is offline
PJSnow will become famous soon enough
PJSnow's Avatar
I wish I could help with the passenger side grommet but I've had no luck.
The reason I am posting is to ask if you actually found a replacement grommet. The typical auto parts stores have "general/fit-all" grommets that don't seem to fit right. Do you have a link or part number for the factory rubber grommet?
PJSnow is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 02:36 PM #4
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
There's a part number printed on that grommet.
Reversible Routes Through Firewall-img_2386-jpeg
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 03:04 PM #5
Yup, that's it. Bought a few from my local Toyota so I could experiment with various ways of punching holes. They are used under the truck too I noticed yesterday when I was checking my slider bolts.
Old 04-05-2021, 03:26 PM #6
PJSnow's Avatar
PJSnow's Avatar
Thank you!
Old 08-15-2021, 11:16 AM #7
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Drill it out with appropriate size drill bit.
<<<< is offline   Reply With QuoteReply With Quote
Old 08-18-2021, 12:42 AM #8
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
I realize this is an old thread.....
I've been drilling holes in the firewall on various cars since I was a teenager, never once had waterproofing issue.
Loads of places sell grommet plugs. Buy some plugs, pick a clear spot, drill the correct size hole, plug it and then poke the wires through. If we are being overly anal don't forget to touch up the bare metal from the drill with some paint.
To undo it just pull the wires and slap another plug in.
nglayton is offline   Reply With QuoteReply With Quote
Old 08-19-2021, 01:39 PM #9
<<<<'s Avatar
<<<<'s Avatar
Take out and drill the rubber grommet from the picture above - not the firewall. Just make sure that opening is useful and lead somewhere accessible inside.
Old 08-20-2021, 07:56 PM #10
No one, eh?
BTW, this path worked perfectly, for those that find this thread later.
That's several power wires and a Switch Pros connector through the firewall with no drilling and completely reversible.
firewall , hole , passenger , side , wires
Reversible blackout that won't look like crap? kaitlyn2004 5th gen T4Rs 9 11-19-2020 12:41 PM
DBBB Routes and Camping tral General Discussions 2 01-27-2020 04:20 AM
Help me plan new AC Duct routes! AntleredRuin Off Topic 2 03-14-2018 12:18 PM
Reversible AC Motor Question MentalHelpNeeded Off Topic 1 05-06-2016 07:11 PM
Running Wire Through the Firewall/Rubber Gasket in Firewall ts9790147 4th Gen T4Rs 4 04-06-2010 05:39 PM
