Old 03-29-2021, 04:57 PM #1
kitesurf kitesurf is offline
kitesurf is on a distinguished road
TRD PRO Roof Rack question
im used to the rack from my 2012 trail edition which just had 2 cross bars
so im trying to understand how to best use this trd rack
I want to cross bars as far apart as possible, however, I cant move them all the way back due to width of bars. the cross bar is too long, even when I put it to shortest dimension.
and in the front there is a little screw with rubber grommet in each bar,, not sure its purpose and it prevents me from putting the other crossbar all the way forward.
any thoughts on this?
kitesurf is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 05:50 PM #2
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
There are several threads on this if you search. Summary.
1) People like me that tried hard to make it useful, found it wasn't going to work, and sold it and put on an aftermarket rack.
2) People that bought an aftermarket drop-in basket that one manufacturer makes.
3) Some dude cut the first rail off and made it just 1 level and a bit more useful.
But it it's stock form, it's not really good for anything.
rageandlove is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 06:06 PM #3
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
That's not true, it's great at creating additional wind noise
ragin_cajun is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 06:23 PM #4
Ha. Ok Thank You
Can’t imagine someone would but it and don’t want to spend more money on another expensive rack
Can those 2 front screws be removed? What’s their use?
Old 03-29-2021, 07:00 PM #5
18 trd off road's Avatar
18 trd off road 18 trd off road is offline
Real Name: joe
18 trd off road will become famous soon enough
Real Name: joe
I found no good use for mine so I took it off and feel it looks better without it and no more wind noise also
18 trd off road is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 07:14 PM #6
I usedthe roof rack a lot on my 2012 for paddle boards and surfboards. I’m hoping it can work no one else out there using it for this purpose?
Old 03-29-2021, 10:28 PM #7
lugia lugia is offline
lugia is on a distinguished road
Is there any way to but a cargo box on the trd pro rack?
lugia is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 11:36 PM #8
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by kitesurf View Post
Ha. Ok Thank You
1. You can buy additional cross bars to give added support. I bought two more from the dealer. Same part number as the roof rack with CB added to the end.
2. Some people have been able to put a bar in front of the button. I haven't tried that. The purpose of the buttons is to keep you from putting bars too far forward. If you take the button off, be sure to seal the hole so water doesn't get inside.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 05:31 AM #9
Ok
Your #2 response is what I was looking for
Will remove and put bar forward
Annoying the cross bars don’t extend enough so I can use on top rail far back
Old 03-30-2021, 09:54 AM #10
Ok
To cover the hole, try hole plugs available at hardware stores. They come as small as 1/8 inch. https://www.lowes.com/search?searchTerm=hole+plug
Old 03-30-2021, 10:13 AM #11
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
This is how my rack is set up. I don’t really use the lower bars for anything other than my Hi Lift at the moment. I might install some traction boards or gas tanks on the other side; not sure yet.
I’ve used my rack to haul 3/4” plywood, 4x8” MDF, 2x4’s, 2x6’s, and other random stuff. I don’t overland, so the stock rack works fine for me. The rubber feet on top prevent things like plywood from scratching the rack and keeps them from sliding.
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 04:35 PM #12
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
What brackets are you using for the Hi-Lift on that Pro rack?
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 04:52 PM #13
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
I’m NOT hillbilly hank so the pro rack works great for carried my spare gear and a fifth wheel no problem maxtrax bolt up easy to it also plus I love the view of the night sky from my sunroof opened
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 05:12 PM #14
AgentKooper AgentKooper is offline
AgentKooper will become famous soon enough
Yes, there are several threads with photos and write ups. I currently have a Yakima Skybox 16 on mine for my and my kids’ skis. I had to grind some plastic off the back edge of the box top to keep the rear hatch from hitting it.
2021 4Runner TRD Pro (Lunar Rock)
AgentKooper is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 05:15 PM #15
If your boards fit on the crossbars of your old rack, I don’t see any reason why they wouldn’t go on the Pro crossbars.
bar , bars , cross , rack , trd
Roof rack question aigo100 5th gen T4Rs 3 10-20-2020 12:02 PM
Roof rack question Igoboe General Discussions 0 06-19-2012 07:42 PM
Roof Basket, Roof Rack, and Sliders Question andyman32392 4th Gen T4Rs 27 09-20-2010 11:46 PM
Roof rack question gixxerdk 4th Gen T4Rs 7 12-12-2008 10:32 PM
To roof rack, or not to roof rack. That is the question. rxshu 3rd gen T4Rs 21 08-07-2008 11:01 PM
